[GRASS-SVN] r62778 - grass/branches/releasebranch_7_0/lib/gis
Mon Nov 17 14:55:43 PST 2014
Author: neteler
Date: 2014-11-17 14:55:43 -0800 (Mon, 17 Nov 2014)
New Revision: 62778
   grass/branches/releasebranch_7_0/lib/gis/gislib_cmdline_parsing.dox
doxygen minor fix
Modified: grass/branches/releasebranch_7_0/lib/gis/gislib_cmdline_parsing.dox
--- grass/branches/releasebranch_7_0/lib/gis/gislib_cmdline_parsing.dox	2014-11-17 22:43:30 UTC (rev 62777)
+++ grass/branches/releasebranch_7_0/lib/gis/gislib_cmdline_parsing.dox	2014-11-17 22:55:43 UTC (rev 62778)
@@ -865,7 +865,7 @@
 Yes. There are a few conventions. Options which identify a single input map
 are usually "map=", not "raster=" or "vector=". In the case of an
 input and output map the convention is: "input=xx output=yy". By passing
-the 'help' option to existing GRASS commands, it is likely that you will
+the '--help' flag to existing GRASS commands, it is likely that you will
 find other conventions. The desire is to make it as easy as possible for the
 user to remember (or guess correctly) what the command line syntax is for a
 given command.
