[GRASS-SVN] r62780 - grass/branches/releasebranch_7_0/tools
svn_grass at osgeo.org
Mon Nov 17 15:03:00 PST 2014
Author: neteler
Date: 2014-11-17 15:03:00 -0800 (Mon, 17 Nov 2014)
New Revision: 62780
grass/branches/releasebranch_7_0/tools/thumbnails.py
thumbnails tool: minor sync to trunk
Modified: grass/branches/releasebranch_7_0/tools/thumbnails.py
--- grass/branches/releasebranch_7_0/tools/thumbnails.py 2014-11-17 23:01:01 UTC (rev 62779)
+++ grass/branches/releasebranch_7_0/tools/thumbnails.py 2014-11-17 23:03:00 UTC (rev 62780)
@@ -30,9 +30,11 @@
if tmp_img:
grass.try_remove(tmp_img)
if tmp_grad_rel:
- grass.run_command('g.remove', type = 'rast', name = tmp_grad_rel, quiet = True, flags = 'f')
+ grass.run_command('g.remove', flags = 'f', type = 'rast',
+ name = tmp_grad_rel, quiet = True)
if tmp_grad_abs:
- grass.run_command('g.remove', type = 'rast', name = tmp_grad_abs, quiet = True, flags = 'f')
+ name = tmp_grad_abs, quiet = True)
# def rotate(src, dst):
# grass.call(["convert", "-rotate", "90", src, dst])
