[GRASS-SVN] r62806 - in grass/branches/releasebranch_7_0: . scripts/r.rgb
svn_grass at osgeo.org
Tue Nov 18 09:57:35 PST 2014
Author: neteler
Date: 2014-11-18 09:57:35 -0800 (Tue, 18 Nov 2014)
New Revision: 62806
Added:
grass/branches/releasebranch_7_0/scripts/r.rgb/r_rgb_elevation.png
grass/branches/releasebranch_7_0/scripts/r.rgb/r.rgb.html
r.rgb: example screenshot
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:60817,61096,61141,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803
+ /grass/trunk:60817,61096,61141,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805
Modified: grass/branches/releasebranch_7_0/scripts/r.rgb/r.rgb.html
--- grass/branches/releasebranch_7_0/scripts/r.rgb/r.rgb.html 2014-11-18 17:56:49 UTC (rev 62805)
+++ grass/branches/releasebranch_7_0/scripts/r.rgb/r.rgb.html 2014-11-18 17:57:35 UTC (rev 62806)
@@ -6,12 +6,40 @@
<h2>EXAMPLE</h2>
<div class="code"><pre>
+g.region rast=elevation -p
r.rgb input=elevation
</pre></div>
+<p>
In this case <em>r.rgb</em> produces in the current mapset three new
raster maps - 'elevation.r', 'elevation.g', 'elevation.b'.
+<p>
+d.split.frame frames=4
+d.frame -s uno
+d.rast elevation
+d.font Vera
+echo " elevation" | d.text col=black
+d.frame -s dos
+d.rast elevation.r
+d.font Vera
+echo " elevation.r" | d.text col=black
+d.frame -s tres
+d.rast elevation.g
+d.font Vera
+echo " elevation.g" | d.text col=black
+d.frame -s cuatro
+d.rast elevation.b
+d.font Vera
+echo " elevation.b" | d.text col=black
+<center>
+<img src="r_rgb_elevation.png"><br>
+</center>
<h2>SEE ALSO</h2>
<em>
Copied: grass/branches/releasebranch_7_0/scripts/r.rgb/r_rgb_elevation.png (from rev 62805, grass/trunk/scripts/r.rgb/r_rgb_elevation.png)
(Binary files differ)
