[GRASS-SVN] r62821 - in grass-addons/grass7/vector: . v.mkhexgrid
svn_grass at osgeo.org
Wed Nov 19 15:17:47 PST 2014
Author: neteler
Date: 2014-11-19 15:17:47 -0800 (Wed, 19 Nov 2014)
New Revision: 62821
Added:
grass-addons/grass7/vector/v.mkhexgrid/
grass-addons/grass7/vector/v.mkhexgrid/v.mkhexgrid.html
grass-addons/grass7/vector/v.mkhexgrid/v.mkhexgrid.py
Removed:
grass-addons/grass7/vector/v.mkhexgrid/description.html
grass-addons/grass7/vector/Makefile
grass-addons/grass7/vector/v.mkhexgrid/v_mkhexgrid.png
v.mkhexgrid: added with some updates from GRASS 6 Addons
Modified: grass-addons/grass7/vector/Makefile
--- grass-addons/grass7/vector/Makefile 2014-11-19 23:12:30 UTC (rev 62820)
+++ grass-addons/grass7/vector/Makefile 2014-11-19 23:17:47 UTC (rev 62821)
@@ -24,6 +24,7 @@
v.lidar.mcc \
v.link.precip \
v.median \
+ v.mkhexgrid \
v.neighborhoodmatrix \
v.net.salesman.opt \
v.out.ply \
Deleted: grass-addons/grass7/vector/v.mkhexgrid/description.html
--- grass-addons/grass6/vector/v.mkhexgrid/description.html 2014-11-19 22:06:38 UTC (rev 62817)
+++ grass-addons/grass7/vector/v.mkhexgrid/description.html 2014-11-19 23:17:47 UTC (rev 62821)
@@ -1,36 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>v.mkhexgrid</em> is a Python script that creates a hexagonal
-grid for the selected region.
-<h2>NOTES</h2>
-This script functions by creating a number of GRASS ASCII files and
-them importing and cleaning them.
-<h2>EXAMPLE</h2>
-North Carolina sample dataset:
-<div class="code"><pre>
-v.mkhexgrid hexagon regionname=ortho_2001_t792_1m_seg \
- sidelength=400 hexarea=2000
-</pre></div>
-<center>
-<img src="v_mkhexgrid.png" alt="Hexagon grid map"><br>
-Hexagon grid map
-</center>
-<h2>SEE ALSO</h2>
-<em>
-<a href="v.mkgrid.html">v.mkgrid</a>
-</em>
-<h2>AUTHOR</h2>
-Trevor Wiens
-<h2>REFERENCES</h2>
-<p>
-<i>Last changed: $Date$</i>
Deleted: grass-addons/grass7/vector/v.mkhexgrid/v.mkhexgrid
--- grass-addons/grass6/vector/v.mkhexgrid/v.mkhexgrid 2014-11-19 22:06:38 UTC (rev 62817)
+++ grass-addons/grass7/vector/v.mkhexgrid/v.mkhexgrid 2014-11-19 23:17:47 UTC (rev 62821)
@@ -1,325 +0,0 @@
-#!/usr/bin/env python
-# MODULE: v.mkhexgrid for GRASS 6.4 (2010-11-23)
-# modified (2011-09-14)
-# - use of sql update over db.in.ogr because of
-# difficulty diagnosing error in db.in.ogr with
-# fields causing erroneous error messages
-# AUTHOR(S): Trevor Wiens
-# PURPOSE: Makes a hexagonal grid
-# REQUIREMENTS: GRASS 6.4 and above
-# COPYRIGHT: (C) 2010 GRASS Development Team
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-# EXAMPLE:
-# v.mkhexgrid output=test regionname=default at PERMANENT sidelength=1000
-#%Module
-#% description: creates a hexagonal grid
-#% keywords: vector
-#% keywords: grid
-#% keywords: hexagon
-#% keywords: attribute table
-#%End
-#%option
-#% key: output
-#% type: string
-#% gisprompt: new,vector,vector
-#% label: Output Vector Name
-#% description: Name of hexagon grid file to create
-#% required : yes
-#%end
-#%option
-#% key: regionname
-#% type: string
-#% gisprompt: old,windows,region
-#% label: Named region to set size of output grid
-#% description: Named region for geographic extent of region to survey
-#% required: yes
-#%end
-#%option
-#% key: size_method
-#% type: string
-#% options: side_length,area
-#% answer: area
-#% description: Method to calculate size
-#% multiple: no
-#% required: no
-#%end
-#%option
-#% key: sidelength
-#% type: double
-#% label: Side length
-#% answer: 100.0
-#% description: Size of side length in map units
-#% required: no
-#%end
-#%option
-#% key: hexarea
-#% type: double
-#% label: Hexagon Area
-#% answer: 200.0
-#% description: Area of hexagon in map units
-#% required: no
-#%end
-import sys
-import os
-import subprocess
-import time
-import csv
-import math
-from grass.script import core as grass
-from grass.script import vector as gvect
-from grass.script import db as gdb
-# WriteHexGridVectors - Using basic trig and the fact that hexagons are constructed from 6 equalateral triangles
-# hexagons are created
-def WriteHexGridVectors(vf, sf, table_name, side_len, xstart, ystart, xlimit, ylimit):
- # basic trig
- angle_a = math.radians(30)
- hyp = side_len
- side_b = hyp * math.cos(angle_a)
- side_a = hyp * math.sin(angle_a)
- # adjust starting line so that entire grid shape is convex
- x = xstart + side_len + side_a
- y = ystart + side_b
- row = 1
- col = 1
- cat = 1
- while y + (2*side_b) < ylimit:
- while x + (2*side_len) < xlimit:
- name = 'x%f_y%f' % (x,y)
- outstring = CreateHexagon((x, y), side_len, cat)
- vf.write(outstring)
- outstring = "UPDATE %s SET row_num = %d, col_num = %d, row_col = '%d_%d' WHERE cat = %d;\n" % \
- (table_name,row,col,row,col,cat)
- sf.write(outstring)
- cat = cat + 1
- x = x + (2*side_len) + (2*side_a)
- col = col + 1
- y = y + side_b
- row = row + 1
- if row % 2 <> 0:
- else:
- x = xstart
- col = 1
-# CreateHexagonGrid - creates hexagons based on six equalateral triangles
-def CreateHexagon(origin, side_len, cat):
- # Get the x and y from the tuple
- orgx = origin[0]
- orgy = origin[1]
- # basic trig
- hyp = side_len
- cx = orgx + (hyp / 2.0)
- cy = orgy + side_b
- # create coordinate string
- outstring = """B 2
-%f %f
-%f %f
-B 2
-%f %f
-%f %f
-B 2
-%f %f
-%f %f
-B 2
-%f %f
-%f %f
-B 2
-%f %f
-%f %f
-B 2
-%f %f
-%f %f
-C 1 1
-%f %f
-1 %d\n""" % (
- orgx, orgy,
- orgx + hyp, orgy,
- orgx + hyp, orgy,
- orgx + hyp + side_a, orgy + side_b,
- orgx + hyp, orgy + (2 * side_b),
- orgx, orgy + (2 * side_b),
- orgx - side_a, orgy + side_b,
- orgx, orgy, cx, cy, cat)
- return(outstring)
-# WriteGrassHeader - writes GRASS header to temporary text file
-def WriteGrassHeader(f,outfile,xstart,ystart,xmax,ymax):
- today = time.strftime("%Y.%m.%d %H:%M:%S",time.localtime())
- outtext = """ORGANIZATION: n/a
-DIGIT DATE: %s
-DIGIT NAME: v.mkhexgrid
-MAP NAME: %s
-MAP DATE: %s
-MAP SCALE:
-OTHER INFO: Hexagon Grid
-ZONE: 0
-WEST EDGE: %s
-EAST EDGE: %s
-SOUTH EDGE: %s
-NORTH EDGE: %s
-MAP THRESH: 0.000000
-VERTI:\n""" % (today,outfile,today,xstart,xmax,ystart,ymax)
- f.write(outtext)
- return()
-# calc_side_length()
-def calc_side_length(hexarea):
- tarea = hexarea/6.0
- # area of an equilateral triangle = length^2 * sqrt(3)/4
- # sqrt(3)/4 * area = length^2
- # sqrt( sqrt(3)/4 * area) = length
- retval = math.sqrt( tarea / (math.sqrt(3.0)/4.0) )
- return(retval)
-def main():
- if options['size_method'] == 'area':
- try:
- side_len = calc_side_length(float(options['hexarea']))
- except:
- msgtext="An error occured in calculating side length for specified area. \n"
- grass.message(msgtext, flag='e')
- return(-1)
- else:
- side_len = options['sidelength']
- errpipe = subprocess.PIPE
- outpipe = subprocess.PIPE
- grass.message('Creating GRASS ascii file with hexagons')
- # assign name to temporary text file
- tempname= 'tempgrid%d' % os.getpid()
- vectorfile = tempname + '.asc'
- sqlfile = tempname + '.sql'
- # set region
- try:
- r = grass.run_command('g.region', region='%s' % options['regionname'])
- if r <> 0:
- raise
- except:
- msgtext="An error occured when selecting the specified region. \n"
- return(-1)
- current_region = grass.region()
- xstart = current_region['w']
- ystart = current_region['s']
- xmax = current_region['e']
- ymax = current_region['n']
- #print "filename: %s\nx: %s, y: %s\nxmax: %s, ymax: %s\nside_length: %s" % (outfile, xstart, ystart, xmax, ymax, side_len)
- vf = open(vectorfile, "w")
- sf = open(sqlfile, "w")
- sf.write("BEGIN TRANSACTION;\n")
- WriteGrassHeader(vf,vectorfile,xstart,ystart,xmax,ymax)
- tname = options['output'].split('@')[0]
- schema = gdb.db_connection()['schema']
- if schema.strip() == '':
- table_name = tname
- else:
- table_name = schema + '.' + tname
- WriteHexGridVectors(vf, sf, table_name, float(side_len), float(xstart), float(ystart), float(xmax), float(ymax))
- vf.close()
- sf.write("COMMIT;\n")
- sf.close()
- # now import and clean up the vector
- grass.message('Importing GRASS ascii file')
- try:
- r = grass.run_command('v.in.ascii', input=vectorfile, output=tempname, format='standard', fs=',')
- if r <> 0:
- raise
- except:
- msgtext="An error occured when importing ascii file. \n"
- return(-1)
- grass.message('Cleaning and building topology')
- try:
- r = grass.run_command('v.clean', input=tempname, output=tname, type='point,line,boundary,centroid,area', tool='rmdupl')
- if r <> 0:
- raise
- except:
- msgtext="An error occured when cleaning grid layer. \n"
- return(-1)
- grass.message('Importing and linking attributes')
- grass.message('Creating table')
- # import attributes
- grass.message(vectorfile)
- try:
- # add attribute table
- r = grass.run_command('v.db.addtable', map=tname, table=table_name, layer=1, columns='cat integer, row_num integer, col_num integer, row_col varchar(255)' )
- if r <> 0:
- raise
- except:
- msgtext="An error occured when importing creating attribute table. \n"
- return(-1)
- grass.message('Updating attributes')
- try:
- # link to proper table
- r = grass.run_command('db.execute', input=sqlfile)
- # drop temp vector
- if r <> 0:
- raise
- except:
- msgtext="An error occured connecting attribute table. \n"
- return(-1)
- grass.message('Removing temporary files')
- try:
- r = grass.run_command('g.remove', vect=tempname)
- if r <> 0:
- raise
- except:
- msgtext="An error occured when removing temporary layer. \n"
- return(-1)
- os.remove(vectorfile)
- os.remove(sqlfile)
-if __name__ == "__main__":
- options, flags = grass.parser()
- sys.exit(main())
Copied: grass-addons/grass7/vector/v.mkhexgrid/v.mkhexgrid.html (from rev 62817, grass-addons/grass6/vector/v.mkhexgrid/description.html)
--- grass-addons/grass7/vector/v.mkhexgrid/v.mkhexgrid.html (rev 0)
+++ grass-addons/grass7/vector/v.mkhexgrid/v.mkhexgrid.html 2014-11-19 23:17:47 UTC (rev 62821)
@@ -0,0 +1,41 @@
+<h2>DESCRIPTION</h2>
+<em>v.mkhexgrid</em> creates a hexagonal grid vector map for the
+selected region.
+<h2>NOTES</h2>
+This module functions by internally creating a number of GRASS ASCII
+files and then importing and cleaning them.
+<h2>EXAMPLE</h2>
+North Carolina sample dataset:
+<div class="code"><pre>
+g.list region
+v.mkhexgrid map=hexagon regionname=wake_30m hexarea=20000000 \
+ method=area
+</pre></div>
+<center>
+<img src="v_mkhexgrid.png" alt="Hexagon grid map"><br>
+Hexagon grid map
+</center>
+<p>
+v.mkhexgrid map=hexagon regionname=wake_30m sidelength=5000 \
+ method=sidelength
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="v.mkgrid.html">v.mkgrid</a>
+</em>
+<h2>AUTHOR</h2>
+Trevor Wiens
+<p>
+<i>Last changed: $Date$</i>
Copied: grass-addons/grass7/vector/v.mkhexgrid/v.mkhexgrid.py (from rev 62817, grass-addons/grass6/vector/v.mkhexgrid/v.mkhexgrid)
--- grass-addons/grass7/vector/v.mkhexgrid/v.mkhexgrid.py (rev 0)
+++ grass-addons/grass7/vector/v.mkhexgrid/v.mkhexgrid.py 2014-11-19 23:17:47 UTC (rev 62821)
@@ -0,0 +1,316 @@
+#!/usr/bin/env python
+# MODULE: v.mkhexgrid
+# derived from v.mkhexgrid for GRASS 6.4 (2010-11-23)
+# modified (2011-09-14)
+# - use of sql update over db.in.ogr because of
+# difficulty diagnosing error in db.in.ogr with
+# fields causing erroneous error messages
+# AUTHOR(S): Trevor Wiens
+# Some GRASS GIS 7 updates by Markus Neteler
+# PURPOSE: Makes a hexagonal grid
+# COPYRIGHT: (C) 2010-2014 GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+# EXAMPLE:
+# v.mkhexgrid map=test regionname=default at PERMANENT sidelength=1000
+#%Module
+#% description: Creates a hexagonal grid.
+#% keywords: vector
+#% keywords: geometry
+#% keywords: grid
+#% keywords: hexagon
+#%End
+#%option G_OPT_V_OUTPUT
+#% key: map
+#%end
+#%option
+#% key: regionname
+#% type: string
+#% gisprompt: old,windows,region
+#% label: Named region to set size of output grid
+#% description: Named region for geographic extent of region to survey
+#% required: yes
+#%end
+#%option
+#% key: method
+#% type: string
+#% options: sidelength,area
+#% answer: area
+#% description: Method to calculate size
+#% multiple: no
+#% required: no
+#%end
+#%option
+#% key: sidelength
+#% type: double
+#% label: Side length
+#% answer: 100.0
+#% description: Size of side length in map units
+#% required: no
+#%end
+#%option
+#% key: hexarea
+#% type: double
+#% label: Hexagon Area
+#% answer: 200.0
+#% description: Area of hexagon in map units
+#% required: no
+#%end
+import sys
+import os
+import subprocess
+import time
+import math
+from grass.script import core as grass
+from grass.script import db as gdb
+from grass.script.utils import try_rmdir
+# WriteHexGridVectors - Using basic trig and the fact that hexagons are constructed from 6 equalateral triangles
+# hexagons are created
+def WriteHexGridVectors(vf, sf, table_name, side_len, xstart, ystart, xlimit, ylimit):
+ # basic trig
+ angle_a = math.radians(30)
+ hyp = side_len
+ side_b = hyp * math.cos(angle_a)
+ side_a = hyp * math.sin(angle_a)
+ # adjust starting line so that entire grid shape is convex
+ x = xstart + side_len + side_a
+ y = ystart + side_b
+ row = 1
+ col = 1
+ cat = 1
+ while y + (2*side_b) < ylimit:
+ while x + (2*side_len) < xlimit:
+ name = 'x%f_y%f' % (x,y)
+ outstring = CreateHexagon((x, y), side_len, cat)
+ vf.write(outstring)
+ outstring = "UPDATE %s SET row_num = %d, col_num = %d, row_col = '%d_%d' WHERE cat = %d;\n" % \
+ (table_name,row,col,row,col,cat)
+ sf.write(outstring)
+ cat = cat + 1
+ x = x + (2*side_len) + (2*side_a)
+ col = col + 1
+ y = y + side_b
+ row = row + 1
+ if row % 2 <> 0:
+ else:
+ x = xstart
+ col = 1
+# CreateHexagonGrid - creates hexagons based on six equalateral triangles
+def CreateHexagon(origin, side_len, cat):
+ # Get the x and y from the tuple
+ orgx = origin[0]
+ orgy = origin[1]
+ # basic trig
+ hyp = side_len
+ cx = orgx + (hyp / 2.0)
+ cy = orgy + side_b
+ # create coordinate string
+ outstring = """B 2
+%f %f
+%f %f
+B 2
+%f %f
+%f %f
+B 2
+%f %f
+%f %f
+B 2
+%f %f
+%f %f
+B 2
+%f %f
+%f %f
+B 2
+%f %f
+%f %f
+C 1 1
+%f %f
+1 %d\n""" % (
+ orgx, orgy,
+ orgx + hyp, orgy,
+ orgx + hyp, orgy,
+ orgx + hyp + side_a, orgy + side_b,
+ orgx + hyp, orgy + (2 * side_b),
+ orgx, orgy + (2 * side_b),
+ orgx - side_a, orgy + side_b,
+ orgx, orgy, cx, cy, cat)
+ return(outstring)
+# WriteGrassHeader - writes GRASS header to temporary text file
+def WriteGrassHeader(f,outfile,xstart,ystart,xmax,ymax):
+ today = time.strftime("%Y.%m.%d %H:%M:%S",time.localtime())
+ outtext = """ORGANIZATION: n/a
+DIGIT DATE: %s
+DIGIT NAME: v.mkhexgrid
+MAP NAME: %s
+MAP DATE: %s
+MAP SCALE:
+OTHER INFO: Hexagon Grid
+ZONE: 0
+WEST EDGE: %s
+EAST EDGE: %s
+SOUTH EDGE: %s
+NORTH EDGE: %s
+MAP THRESH: 0.000000
+VERTI:\n""" % (today,outfile,today,xstart,xmax,ystart,ymax)
+ f.write(outtext)
+ return()
+# calc_side_length()
+def calc_side_length(hexarea):
+ tarea = hexarea/6.0
+ # area of an equilateral triangle = length^2 * sqrt(3)/4
+ # sqrt(3)/4 * area = length^2
+ # sqrt( sqrt(3)/4 * area) = length
+ retval = math.sqrt( tarea / (math.sqrt(3.0)/4.0) )
+ return(retval)
+def main():
+ if options['method'] == 'area':
+ try:
+ side_len = calc_side_length(float(options['hexarea']))
+ except:
+ grass.message('An error occured in calculating side length for specified area', flag='e')
+ return(-1)
+ else:
+ side_len = options['sidelength']
+ errpipe = subprocess.PIPE
+ outpipe = subprocess.PIPE
+ grass.message('Creating GRASS GIS ASCII file with hexagons...')
+ # assign name to temporary text file
+ tempname= 'tempgrid%d' % os.getpid()
+ tmp_dir = grass.tempdir()
+ grass.debug('tmp_dir = %s' % tmp_dir)
+ vectorfile = os.path.join(tmp_dir, tempname) + '.asc'
+ sqlfile = os.path.join(tmp_dir, tempname) + '.sql'
+ # set region
+ try:
+ r = grass.run_command('g.region', region='%s' % options['regionname'])
+ if r <> 0:
+ raise
+ except:
+ grass.message("An error occured when selecting the specified region", flag='e')
+ return(-1)
+ current_region = grass.region()
+ xstart = current_region['w']
+ ystart = current_region['s']
+ xmax = current_region['e']
+ ymax = current_region['n']
+ #print "filename: %s\nx: %s, y: %s\nxmax: %s, ymax: %s\nside_length: %s" % (outfile, xstart, ystart, xmax, ymax, side_len)
+ vf = open(vectorfile, "w")
+ sf = open(sqlfile, "w")
+ sf.write("BEGIN TRANSACTION;\n")
+ WriteGrassHeader(vf,vectorfile,xstart,ystart,xmax,ymax)
+ tname = options['map'].split('@')[0]
+ schema = gdb.db_connection()['schema']
+ if schema.strip() == '':
+ table_name = tname
+ else:
+ table_name = schema + '.' + tname
+ WriteHexGridVectors(vf, sf, table_name, float(side_len), float(xstart), float(ystart), float(xmax), float(ymax))
+ vf.close()
+ sf.write("COMMIT;\n")
+ sf.close()
+ # now import and clean up the vector
+ grass.message('Importing GRASS GIS ASCII file...')
+ try:
+ r = grass.run_command('v.in.ascii', input=vectorfile, output=tempname, format='standard', separator=',')
+ if r <> 0:
+ raise
+ except:
+ grass.message("An error occured when importing ASCII file", flag='e')
+ return(-1)
+ grass.message('Cleaning and building topology...')
+ try:
+ r = grass.run_command('v.clean', input=tempname, output=tname, type='point,line,boundary,centroid,area', tool='rmdupl')
+ if r <> 0:
+ raise
+ except:
+ grass.message("An error occured when cleaning grid layer", flag='e')
+ return(-1)
+ grass.message('Importing and linking attributes...')
+ grass.message('Creating table...')
+ # import attributes
+ grass.debug(vectorfile)
+ try:
+ # add attribute table
+ r = grass.run_command('v.db.addtable', map=tname, table=table_name, layer=1, columns='cat integer, row_num integer, col_num integer, row_col varchar(255)' )
+ if r <> 0:
+ raise
+ except:
+ grass.message("An error occured when importing creating attribute table", flag='e')
+ return(-1)
+ grass.message('Updating attributes...')
+ try:
+ # link to proper table
+ r = grass.run_command('db.execute', input=sqlfile)
+ # drop temp vector
+ if r <> 0:
+ raise
+ except:
+ grass.message("An error occured connecting attribute table", flag='e')
+ return(-1)
+ grass.message('Removing temporary files')
+ try:
+ r = grass.run_command('g.remove', type='vect', name=tempname, quiet=True, flags='f')
+ if r <> 0:
+ raise
+ except:
+ grass.message("An error occured when removing temporary layer", flag='e')
+ return(-1)
+ os.remove(vectorfile)
+ os.remove(sqlfile)
+ try_rmdir(tmp_dir)
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
Property changes on: grass-addons/grass7/vector/v.mkhexgrid/v.mkhexgrid.py
___________________________________________________________________
Added: svn:executable
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
Modified: grass-addons/grass7/vector/v.mkhexgrid/v_mkhexgrid.png
(Binary files differ)
