[GRASS-SVN] r62826 - in grass/trunk: gui/wxpython/dbmgr gui/wxpython/mapdisp lib/python/script
svn_grass at osgeo.org
Wed Nov 19 19:32:50 PST 2014
Author: annakrat
Date: 2014-11-19 19:32:50 -0800 (Wed, 19 Nov 2014)
New Revision: 62826
grass/trunk/gui/wxpython/dbmgr/vinfo.py
grass/trunk/gui/wxpython/mapdisp/frame.py
grass/trunk/lib/python/script/vector.py
pythonlib/wxGUI: better error handling of vector_what
Modified: grass/trunk/gui/wxpython/dbmgr/vinfo.py
--- grass/trunk/gui/wxpython/dbmgr/vinfo.py 2014-11-20 02:47:52 UTC (rev 62825)
+++ grass/trunk/gui/wxpython/dbmgr/vinfo.py 2014-11-20 03:32:50 UTC (rev 62826)
@@ -20,7 +20,7 @@
import wx
from gui_core.gselect import VectorDBInfo as VectorDBInfoBase
-from core.gcmd import RunCommand
+from core.gcmd import RunCommand, GError
from core.settings import UserSettings
from core.utils import _
import grass.script as grass
@@ -92,9 +92,14 @@
line = None
nselected = 0
- data = grass.vector_what(map = self.map,
- coord = (float(queryCoords[0]), float(queryCoords[1])),
- distance = float(qdist))
+ try:
+ data = grass.vector_what(map=self.map,
+ coord=(float(queryCoords[0]), float(queryCoords[1])),
+ distance=float(qdist))
+ except grass.ScriptError:
+ GError(parent=None,
+ message=_("Failed to query vector map <{map}>. "
+ "Check database settings and topology.").format(map=self.map))
if len(data) < 1 or all(('Table' not in record) for record in data):
return None
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py 2014-11-20 02:47:52 UTC (rev 62825)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py 2014-11-20 03:32:50 UTC (rev 62826)
@@ -868,8 +868,13 @@
rastQuery = grass.raster_what(map=rast, coord=(east, north))
if vect:
encoding = UserSettings.Get(group='atm', key='encoding', subkey='value')
- vectQuery = grass.vector_what(map=vect, coord=(east, north), distance=qdist,
- encoding=encoding)
+ try:
+ vectQuery = grass.vector_what(map=vect, coord=(east, north), distance=qdist,
+ encoding=encoding)
+ GError(parent=self,
+ message=_("Failed to query vector map(s) <{maps}>. "
+ "Check database settings and topology.").format(maps=','.join(vect)))
self._QueryMapDone()
if 'Id' in vectQuery:
self._queryHighlight(vectQuery)
Modified: grass/trunk/lib/python/script/vector.py
--- grass/trunk/lib/python/script/vector.py 2014-11-20 02:47:52 UTC (rev 62825)
+++ grass/trunk/lib/python/script/vector.py 2014-11-20 03:32:50 UTC (rev 62826)
@@ -24,6 +24,7 @@
from utils import parse_key_val
from core import *
+from grass.exceptions import CalledModuleError
def vector_db(map, **args):
@@ -348,8 +349,11 @@
if ttype:
cmdParams['type'] = ','.join(ttype)
- ret = read_command('v.what',
- **cmdParams).strip()
+ try:
+ ret = read_command('v.what',
+ **cmdParams).strip()
+ except CalledModuleError, e:
+ raise ScriptError(e.msg)
if "LC_ALL" in os.environ:
os.environ["LC_ALL"] = locale
@@ -377,7 +381,10 @@
if sys.version_info[0:2] > (2, 6):
kwargs['object_pairs_hook'] = orderedDict
- result = json.loads(ret, **kwargs)
+ try:
+ result = json.loads(ret, **kwargs)
+ except ValueError:
+ raise ScriptError(_("v.what output is not valid JSON format:\n {ret}").format(ret=ret))
for vmap in result['Maps']:
cats = vmap.pop('Categories', None)
