[GRASS-SVN] r62830 - grass/trunk/imagery/i.segment
svn_grass at osgeo.org
Wed Nov 19 23:39:15 PST 2014
Author: mmetz
Date: 2014-11-19 23:39:15 -0800 (Wed, 19 Nov 2014)
New Revision: 62830
grass/trunk/imagery/i.segment/i.segment.html
i.segment: update manual
Modified: grass/trunk/imagery/i.segment/i.segment.html
--- grass/trunk/imagery/i.segment/i.segment.html 2014-11-20 04:23:34 UTC (rev 62829)
+++ grass/trunk/imagery/i.segment/i.segment.html 2014-11-20 07:39:15 UTC (rev 62830)
@@ -104,6 +104,13 @@
the set size, thus forcing very small segments to merge with their
most similar neighbor.
+<h3>Goodness of Fit</h3>
+The <b>goodness</b> of fit for each pixel is calculated as 1 - distance
+of the pixel to the object it belongs to. The distance is calculated
+with the selected <b>similarity</b> method. A value of 1 means
+identical values, perfect fit, and a value of 0 means maximum possible
+distance, worst possible fit.
<h2>EXAMPLE</h2>
This example uses the ortho photograph included in the NC Sample
Dataset. Set up an imagery group:
