[GRASS-SVN] r62836 - grass/branches/releasebranch_7_0/scripts/r.reclass.area
Thu Nov 20 03:08:55 PST 2014
Author: neteler
Date: 2014-11-20 03:08:55 -0800 (Thu, 20 Nov 2014)
New Revision: 62836
   grass/branches/releasebranch_7_0/scripts/r.reclass.area/r.reclass.area.py
r.reclass.area: minor code cleanup of location check
Modified: grass/branches/releasebranch_7_0/scripts/r.reclass.area/r.reclass.area.py
--- grass/branches/releasebranch_7_0/scripts/r.reclass.area/r.reclass.area.py	2014-11-20 11:07:25 UTC (rev 62835)
+++ grass/branches/releasebranch_7_0/scripts/r.reclass.area/r.reclass.area.py	2014-11-20 11:08:55 UTC (rev 62836)
@@ -191,14 +191,12 @@
     diagonal = flags['d']
     islesser = False
+    # check for unsupported locations
     in_proj = grass.parse_command('g.proj', flags='g')
-    # check non supported location
     if in_proj['unit'].lower() == 'degree':
-        grass.fatal(_("Latitude-Longitude locations are not supported"))
+        grass.fatal(_("Latitude-longitude locations are not supported"))
     if in_proj['name'].lower() == 'xy_location_unprojected':
         grass.fatal(_("xy-locations are not supported"))
-        grass.fatal(_("Need projected data with grids in metric units"))
     # check lesser and greater parameters
     if not lesser and not greater:
@@ -229,9 +227,11 @@
     TMPRAST.reverse()  # reclassed map first
     for mapp in TMPRAST:
         if METHOD == 'rmarea':
-            grass.run_command("g.remove", type='vect', name=mapp, quiet=True, flags='f')
+            grass.run_command("g.remove", flags='f', type='vect', name=mapp,
+                              quiet=True)
         else:
-            grass.run_command("g.remove", type='rast', name=mapp, quiet=True, flags='f')
+            grass.run_command("g.remove", flags='f', type='rast', name=mapp,
+                              quiet=True)
 if __name__ == "__main__":
     options, flags = grass.parser()
