[GRASS-SVN] r62841 - in grass/trunk/temporal: . t.connect t.info t.list t.merge t.rast.accumulate t.rast.export t.register t.remove t.vect.list t.vect.what.strds
Thu Nov 20 13:29:59 PST 2014
Author: neteler
Date: 2014-11-20 13:29:59 -0800 (Thu, 20 Nov 2014)
New Revision: 62841
   grass/trunk/temporal/t.connect/t.connect.html
   grass/trunk/temporal/t.info/t.info.html
   grass/trunk/temporal/t.list/t.list.html
   grass/trunk/temporal/t.merge/t.merge.html
   grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.html
   grass/trunk/temporal/t.rast.export/t.rast.export.html
   grass/trunk/temporal/t.register/t.register.html
   grass/trunk/temporal/t.remove/t.remove.html
   grass/trunk/temporal/t.vect.list/t.vect.list.html
   grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.html
   grass/trunk/temporal/temporalintro.html
temporal manual: minor updates
Modified: grass/trunk/temporal/t.connect/t.connect.html
--- grass/trunk/temporal/t.connect/t.connect.html	2014-11-20 21:07:11 UTC (rev 62840)
+++ grass/trunk/temporal/t.connect/t.connect.html	2014-11-20 21:29:59 UTC (rev 62841)
@@ -6,12 +6,15 @@
 Values are stored in the mapset's <tt>VAR</tt> file; the connection is
 not tested for validity. <p>The <b>-d</b> flag will set the default
-TGIS connection parameters. A sqlite3 database "tgis/sqlite.db" will be
-created in the PERMANET directory of the current location. It will be
-located in the "tgis" sub-directory to not interfere with the sqlite3
-database used for vector attribute storage. <p>The <b>-p</b> flag will
-display the current TGIS connection parameters. <p>The <b>-pg</b> flag
-will display the current TGIS connection parameters using shell style.
+TGIS connection parameters.
+<!-- TODO: really always PERMANENT? - see http://trac.osgeo.org/grass/ticket/2258 -->
+A SQLite3 database "tgis/sqlite.db" will be created in the PERMANENT directory
+of the current location. It will be located in the "tgis" sub-directory to not
+interfere with the sqlite3 database used for vector attribute storage.
+<p>The <b>-p</b> flag will display the current TGIS connection parameters.
+<p>The <b>-pg</b> flag will display the current TGIS connection parameters
+using shell style.
 <p>The <b>-c</b> flag will silently check if the TGIS connection
 parameters have been set, and if not will set them to use GRASS's
 default values.
@@ -20,7 +23,7 @@
 The default TGIS database of type sqlite3 is located in the PERMANENT
 mapset directory. Temporal GIS content from all created mapsets will be
-stored here. In case you have thousends of maps to register in the
+stored here. In case you have thousands of maps to register in the
 temporal database or you need concurrent read and write access in the
 TGIS database, consider to use a postgresql database instead.
@@ -36,10 +39,8 @@
 The SQLite database is created automatically when used the first time.
 <h3>PostgreSQL</h3>
-In case you use a PostgreSQL database, you will need to specify the
-TGIS database connection for each mapset.
+In case you use a PostgreSQL database, you will need to specify the TGIS database connection
+for each mapset.
 <div class="code"><pre>
 t.connect driver=pg database="dbname=grass_test user=soeren password=abcdefgh"
 t.connect -p
Modified: grass/trunk/temporal/t.info/t.info.html
--- grass/trunk/temporal/t.info/t.info.html	2014-11-20 21:07:11 UTC (rev 62840)
+++ grass/trunk/temporal/t.info/t.info.html	2014-11-20 21:29:59 UTC (rev 62841)
@@ -28,6 +28,7 @@
 stdout.
 t.info -s
  +------------------- Temporal DBMI backend information ----------------------+
  | DBMI Python interface:...... sqlite3
Modified: grass/trunk/temporal/t.list/t.list.html
--- grass/trunk/temporal/t.list/t.list.html	2014-11-20 21:07:11 UTC (rev 62840)
+++ grass/trunk/temporal/t.list/t.list.html	2014-11-20 21:29:59 UTC (rev 62841)
@@ -13,9 +13,10 @@
 <h2>EXAMPLE</h2>
-In this example we will create 3 raster maps and register them first
+In this example we will create three raster maps and register them first
 only in the temporal database an then in the newly created space time
-raster dataset. We use t.list to show what maps are already in the
+raster dataset. We use <em>t.list</em> to show what maps are already
+in the temporal database:
 # Generate data
@@ -41,7 +42,6 @@
 t.list strds
  precipitation_daily at soeren
 </pre></div>
 <h2>SEE ALSO</h2>
Modified: grass/trunk/temporal/t.merge/t.merge.html
--- grass/trunk/temporal/t.merge/t.merge.html	2014-11-20 21:07:11 UTC (rev 62840)
+++ grass/trunk/temporal/t.merge/t.merge.html	2014-11-20 21:29:59 UTC (rev 62841)
@@ -196,6 +196,7 @@
  |     output="precipitation_daily_3"
 </pre></div>
 <h2>SEE ALSO</h2>
Modified: grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.html
--- grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.html	2014-11-20 21:07:11 UTC (rev 62840)
+++ grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.html	2014-11-20 21:29:59 UTC (rev 62841)
@@ -65,7 +65,7 @@
 mkdir -p /tmp/grassdata/LL
 # Start GRASS and create a new location with PERMANENT mapset
-grass70  -c EPSG:4326 /tmp/grassdata/LL/PERMANENT
+grass71  -c EPSG:4326 /tmp/grassdata/LL/PERMANENT
 # Import the temperature data
 t.rast.import in=temperature_mean_1990_2000_daily_celsius.tar.gz \
Modified: grass/trunk/temporal/t.rast.export/t.rast.export.html
--- grass/trunk/temporal/t.rast.export/t.rast.export.html	2014-11-20 21:07:11 UTC (rev 62840)
+++ grass/trunk/temporal/t.rast.export/t.rast.export.html	2014-11-20 21:29:59 UTC (rev 62841)
@@ -30,7 +30,6 @@
 some files that are created:
 MAPS="map_1 map_2 map_3 map_4 map_5 map_6 map_7"
 for map in ${MAPS} ; do
Modified: grass/trunk/temporal/t.register/t.register.html
--- grass/trunk/temporal/t.register/t.register.html	2014-11-20 21:07:11 UTC (rev 62840)
+++ grass/trunk/temporal/t.register/t.register.html	2014-11-20 21:29:59 UTC (rev 62841)
@@ -28,7 +28,7 @@
 <h2>Note</h2>
-The timestamps of registred maps will be stored in the temporal
+The timestamps of registered maps will be stored in the temporal
 database and in the metadata of the grass maps in the spatial database.
 This assures that timestamps can always be accessed with
 <em>(r|r3|v).timestamp</em> and the temporal modules. Timestamps should
Modified: grass/trunk/temporal/t.remove/t.remove.html
--- grass/trunk/temporal/t.remove/t.remove.html	2014-11-20 21:07:11 UTC (rev 62840)
+++ grass/trunk/temporal/t.remove/t.remove.html	2014-11-20 21:29:59 UTC (rev 62841)
@@ -47,6 +47,7 @@
 <em>
 <a href="t.create.html">t.create</a>,
+<a href="t.info.html">t.info</a>,
 <a href="t.register.html">t.register</a>
 </em>
Modified: grass/trunk/temporal/t.vect.list/t.vect.list.html
--- grass/trunk/temporal/t.vect.list/t.vect.list.html	2014-11-20 21:07:11 UTC (rev 62840)
+++ grass/trunk/temporal/t.vect.list/t.vect.list.html	2014-11-20 21:29:59 UTC (rev 62841)
@@ -3,7 +3,7 @@
 This module provides the same functionality as
 <a href="t.rast.list.html">t.rast.list</a>, the only difference is the
 vector map layer metadata. Please refer to the manual page of
-<a  href="t.rast.list.html">t.rast.list</a>.
+<a href="t.rast.list.html">t.rast.list</a>.
 <h2>EXAMPLE</h2>
Modified: grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.html
--- grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.html	2014-11-20 21:07:11 UTC (rev 62840)
+++ grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.html	2014-11-20 21:29:59 UTC (rev 62841)
@@ -17,13 +17,7 @@
 <a href="v.univar.html">v.univar</a>,
 <a href="v.what.rast.html">v.what.rast</a>,
 <a href="v.what.rast3.html">v.what.rast3</a>,
-<a href="v.what.vect.html">v.what.vect</a>
-</em>
-<h2>SEE ALSO</h2>
-<em>
+<a href="v.what.vect.html">v.what.vect</a>,
 </em>
Modified: grass/trunk/temporal/temporalintro.html
--- grass/trunk/temporal/temporalintro.html	2014-11-20 21:07:11 UTC (rev 62840)
+++ grass/trunk/temporal/temporalintro.html	2014-11-20 21:29:59 UTC (rev 62841)
@@ -38,7 +38,7 @@
 Space time datasets are stored in a temporal database. SQLite3 or
 PostgreSQL are supported as SQL database back end.
 Connection settings are performed with <a href="t.connect.html">t.connect</a>.
-<!-- todo: really always PERMANENT? -> see http://trac.osgeo.org/grass/ticket/2258 -->
 As default a sqlite3 database will be created in the PERMANENT mapset that
 stores all space time datasets and registered time series maps from all
 mapsets in the location.
