[GRASS-SVN] r62846 - grass/branches/releasebranch_7_0/scripts/db.droptable
svn_grass at osgeo.org
Fri Nov 21 03:27:35 PST 2014
Author: lucadelu
Date: 2014-11-21 03:27:35 -0800 (Fri, 21 Nov 2014)
New Revision: 62846
grass/branches/releasebranch_7_0/scripts/db.droptable/db.droptable.py
db.droptable: fix it using the new behaviour of db_table_in_vector
Modified: grass/branches/releasebranch_7_0/scripts/db.droptable/db.droptable.py
--- grass/branches/releasebranch_7_0/scripts/db.droptable/db.droptable.py 2014-11-21 04:00:29 UTC (rev 62845)
+++ grass/branches/releasebranch_7_0/scripts/db.droptable/db.droptable.py 2014-11-21 11:27:35 UTC (rev 62846)
@@ -75,7 +75,7 @@
# check if table is used somewhere (connected to vector map)
used = grass.db.db_table_in_vector(table)
- if len(used) > 0:
+ if used:
grass.warning(_("Deleting table <%s> which is attached to following map(s):") % table)
for vect in used:
grass.warning("%s" % vect)
