[GRASS-SVN] r62888 - grass/trunk/raster/r.uslek
svn_grass at osgeo.org
Mon Nov 24 09:00:06 PST 2014
Author: neteler
Date: 2014-11-24 09:00:06 -0800 (Mon, 24 Nov 2014)
New Revision: 62888
grass/trunk/raster/r.uslek/main.c
grass/trunk/raster/r.uslek/tex2usle_k.c
r.uslek: organic matter range fix; fp precision fix
Modified: grass/trunk/raster/r.uslek/main.c
--- grass/trunk/raster/r.uslek/main.c 2014-11-24 16:50:51 UTC (rev 62887)
+++ grass/trunk/raster/r.uslek/main.c 2014-11-24 17:00:06 UTC (rev 62888)
@@ -1,4 +1,3 @@
* MODULE: r.uslek
@@ -19,6 +18,7 @@
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
+#include <math.h>
#include <grass/gis.h>
#include <grass/raster.h>
#include <grass/glocale.h>
@@ -136,17 +136,19 @@
else {
/* In case some map input not standard */
- if ((d_sand + d_clay + d_silt) != 1.0)
+ if (fabs(d_sand + d_clay + d_silt - 1.0) > GRASS_EPSILON )
Rast_set_d_null_value(&outrast[col], 1);
/* if OM==NULL then make it 0.0 */
- else if (Rast_is_d_null_value(&d_om))
- d_om = 0.0;
else {
+ if (Rast_is_d_null_value(&d_om))
+ d_om = 0.0;
/* convert to usle_k */
d = (double)prct2tex(d_sand, d_clay, d_silt);
- d = tex2usle_k((int)d, d_om);
- outrast[col] = d;
+ if(d > 11.0) /* 11 is highest class */
+ Rast_set_d_null_value(&outrast[col], 1);
+ else
+ outrast[col] = tex2usle_k((int)d, d_om);
Modified: grass/trunk/raster/r.uslek/tex2usle_k.c
--- grass/trunk/raster/r.uslek/tex2usle_k.c 2014-11-24 16:50:51 UTC (rev 62887)
+++ grass/trunk/raster/r.uslek/tex2usle_k.c 2014-11-24 17:00:06 UTC (rev 62888)
@@ -7,8 +7,8 @@
double usle_k = 200.0; /* Initial value */
- G_debug(1, "texture=%i, om=%5.3f",texture, om_in);
- if (om_in < 0.5) {
+ G_verbose_message("tex2usle_k: texture=%i, om=%5.3f", texture, om_in);
+ if (om_in < 0.05) {
if (texture == 0) /* G_message("clay"); */
usle_k = 0.29; /*Took max value @0.2 */
else if (texture == 1) /* G_message("sandy clay"); */
@@ -36,7 +36,7 @@
else /*G_message("Unable to allocate class"); */
usle_k = 500.0;/*change value to show it was processed */
- else if (om_in >= 0.5 && om_in < 0.2) {
+ else if (om_in >= 0.05 && om_in < 0.2) {
usle_k = 0.29; /*Range=[0.13-0.29]@0.2, took max */
