[GRASS-SVN] r62908 - sandbox/martinl
svn_grass at osgeo.org
Tue Nov 25 01:01:50 PST 2014
Author: martinl
Date: 2014-11-25 01:01:50 -0800 (Tue, 25 Nov 2014)
New Revision: 62908
Added:
sandbox/martinl/d.frame/
sandbox/martinl/print_module_parameters.py
sandbox/martinl/print_module_parameters_csv.py
print_module_parameters: fix getting labels
Modified: sandbox/martinl/print_module_parameters.py
--- sandbox/martinl/print_module_parameters.py 2014-11-25 08:54:03 UTC (rev 62907)
+++ sandbox/martinl/print_module_parameters.py 2014-11-25 09:01:50 UTC (rev 62908)
@@ -5,6 +5,12 @@
from grass.script import task as gtask
from grass.script.core import get_commands
+def get_label(p):
+ label = p.get('label')
+ if label:
+ return label
+ return p.get('description')
def main():
print '-' * 80
for cmd in sorted(get_commands()[0]):
@@ -13,9 +19,9 @@
for f in task.get_options()['flags']:
if len(f.get('name')) > 1: # skip overwrite, ...
continue
- print '\t' + f.get('name') + ': ' + f.get('description')
+ print '\t' + f.get('name') + ': ' + get_label(f)
for p in task.get_options()['params']:
- print '\t' + p.get('name') + ': ' + p.get('description')
+ print '\t' + p.get('name') + ': ' + get_label(p)
print '-' * 80
if __name__ == "__main__":
Modified: sandbox/martinl/print_module_parameters_csv.py
--- sandbox/martinl/print_module_parameters_csv.py 2014-11-25 08:54:03 UTC (rev 62907)
+++ sandbox/martinl/print_module_parameters_csv.py 2014-11-25 09:01:50 UTC (rev 62908)
@@ -7,6 +7,12 @@
from grass.exceptions import ScriptError
+def get_label(p):
+ if label:
+ return label
def main():
# print '-' * 80
@@ -20,9 +26,9 @@
if len(f.get('name')) > 1: # skip --overwrite, ...
continue
- print task.get_name() + '€' + f.get('name') + '€' + f.get('description')
+ print task.get_name() + '€' + f.get('name') + '€' + get_label(f)
- print task.get_name() + '€' + p.get('name') + '€' + p.get('description')
+ print task.get_name() + '€' + p.get('name') + '€' + get_label(p)
main()
