[GRASS-SVN] r62939 - grass/branches/releasebranch_7_0/display/d.rast.arrow
Tue Nov 25 06:36:43 PST 2014
Author: martinl
Date: 2014-11-25 06:36:43 -0800 (Tue, 25 Nov 2014)
New Revision: 62939
   grass/branches/releasebranch_7_0/display/d.rast.arrow/d.rast.arrow.html
   grass/branches/releasebranch_7_0/display/d.rast.arrow/main.c
d.rast.arrow: sync'ed with trunk
Modified: grass/branches/releasebranch_7_0/display/d.rast.arrow/d.rast.arrow.html
--- grass/branches/releasebranch_7_0/display/d.rast.arrow/d.rast.arrow.html	2014-11-25 14:31:41 UTC (rev 62938)
+++ grass/branches/releasebranch_7_0/display/d.rast.arrow/d.rast.arrow.html	2014-11-25 14:36:43 UTC (rev 62939)
@@ -16,6 +16,9 @@
 <em>d.rast.arrow</em> draws a question mark over the displayed cells
 of that category.
 Cells containing null data will be marked with an "X".
+You can disable drawing of null data and unknown aspect values by
+setting its color to "<tt>none</tt>".
 <p>If you specify the <em>magnitude_map</em> option, arrow lengths
 denoting magnitude will be extracted from the cell values of the specified
 map. In this case the tail of the arrow will be centered on the source cell.
Modified: grass/branches/releasebranch_7_0/display/d.rast.arrow/main.c
--- grass/branches/releasebranch_7_0/display/d.rast.arrow/main.c	2014-11-25 14:31:41 UTC (rev 62938)
+++ grass/branches/releasebranch_7_0/display/d.rast.arrow/main.c	2014-11-25 14:36:43 UTC (rev 62939)
@@ -110,39 +110,28 @@
     opt2->options = "grass,compass,agnps,answers";
     opt2->description = _("Type of existing raster aspect map");
-    opt3 = G_define_option();
-    opt3->key = "arrow_color";
-    opt3->type = TYPE_STRING;
-    opt3->required = NO;
+    opt3 = G_define_standard_option(G_OPT_C_FG);
+    opt3->key = "color";
     opt3->answer = "green";
-    opt3->gisprompt = "old_color,color,color";
-    opt3->description = _("Color for drawing arrows");
+    opt3->label = _("Color for drawing arrows");
     opt3->guisection = _("Colors");
-    opt4 = G_define_option();
+    opt4 = G_define_standard_option(G_OPT_C_BG);
     opt4->key = "grid_color";
-    opt4->required = NO;
     opt4->answer = "gray";
-    opt4->gisprompt = "old,color_none,color";
-    opt4->description = _("Color for drawing grid or \"none\"");
+    opt4->label = _("Color for drawing drawing grid");
     opt4->guisection = _("Colors");
-    opt5 = G_define_option();
-    opt5->key = "x_color";
-    opt5->type = TYPE_STRING;
-    opt5->required = NO;
+    opt5 = G_define_standard_option(G_OPT_C_BG);
+    opt5->key = "null_color";
     opt5->answer = DEFAULT_FG_COLOR;
-    opt5->gisprompt = "old,color_none,color";
-    opt5->description = _("Color for drawing X's (null values)");
+    opt5->label = _("Color for drawing null values (X symbol)");
     opt5->guisection = _("Colors");
-    opt6 = G_define_option();
+    opt6 = G_define_standard_option(G_OPT_C_BG);
     opt6->key = "unknown_color";
-    opt6->type = TYPE_STRING;
-    opt6->required = NO;
     opt6->answer = "red";
-    opt6->gisprompt = "old,color_none,color";
-    opt6->description = _("Color for showing unknown information");
+    opt6->label = _("Color for showing unknown information (? symbol)");
     opt6->guisection = _("Colors");
     opt9 = G_define_option();
@@ -181,15 +170,27 @@
     layer_name = opt1->answer;
     arrow_color = D_translate_color(opt3->answer);
-    x_color = D_translate_color(opt5->answer);
-    unknown_color = D_translate_color(opt6->answer);
+    /* Convert none (transparent) to -1 which in this module means
+       that we will not draw things having this color (-1).
+       We don't do that for arrow because we always want them.
+       (This is specified by the gisprompt ('type') of the options.)
     if (strcmp("none", opt4->answer) == 0)
 	grid_color = -1;
     else
 	grid_color = D_translate_color(opt4->answer);
+    if (strcmp("none", opt5->answer) == 0)
+	x_color = -1;
+    else
+	x_color = D_translate_color(opt5->answer);
+    if (strcmp("none", opt6->answer) == 0)
+	unknown_color = -1;
+    else
+	unknown_color = D_translate_color(opt6->answer);
     if (strcmp("grass", opt2->answer) == 0)
 	map_type = 1;
     else if (strcmp("agnps", opt2->answer) == 0)
@@ -390,9 +391,12 @@
 		D_use_color(arrow_color);
 		if (Rast_is_null_value(ptr, raster_type)) {
-		    D_use_color(x_color);
-		    draw_x();
-		    D_use_color(arrow_color);
+		    /* don't draw anything if x_color is none (transparent) */
+		    if (x_color > 0) {
+			D_use_color(x_color);
+			draw_x();
+			D_use_color(arrow_color);
 		else if (aspect_f >= 0.0 && aspect_f <= 360.0) {
 		    if (opt7->answer)
@@ -400,7 +404,8 @@
 		    else
 			arrow_360(aspect_f);
-		else {
+		else if (unknown_color > 0) {
+		    /* don't draw if unknown_color is none (transparent) */
 		    D_use_color(unknown_color);
 		    unknown_();
@@ -413,9 +418,12 @@
 		switch (aspect_c) {
 		case 0:
-		    draw_x();
+		    /* only draw if x_color is not none (transparent) */
+			draw_x();
 		    break;
 		case 1:
 		    arrow_n();
@@ -442,9 +450,12 @@
 		    arrow_nw();
 		    break;
 		default:
-		    D_use_color(unknown_color);
-		    unknown_();
+		    /* only draw if unknown_color is not none */
+		    if (unknown_color > 0) {
+			D_use_color(unknown_color);
+			unknown_();
 		    break;
@@ -456,11 +467,15 @@
 		if (aspect_c >= 15 && aspect_c <= 360)	/* start at zero? */
 		    arrow_360((double)aspect_c);
 		else if (aspect_c == 400) {
-		    unknown_();
+			unknown_();
-		else {
+		else if (x_color > 0) {
 		    draw_x();
@@ -473,9 +488,12 @@
-		    draw_x();
+			/* only draw if x_color is not none */
+			draw_x();
 		    if (opt7->answer)
@@ -483,7 +501,8 @@
 		    else
 			arrow_360(90 - aspect_f);
-		else {
 		    unknown_();
