[GRASS-SVN] r62941 - in grass/branches/releasebranch_7_0: . display/d.rhumbline
svn_grass at osgeo.org
Tue Nov 25 06:44:38 PST 2014
Author: martinl
Date: 2014-11-25 06:44:38 -0800 (Tue, 25 Nov 2014)
New Revision: 62941
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/display/d.rhumbline/main.c
d.rhumbline: use standardized options (#2409)
(merge r62940 from trunk)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:60817,61096,61141,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62856,62879,62881,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935
+ /grass/trunk:60817,61096,61141,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62856,62879,62881,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940
Modified: grass/branches/releasebranch_7_0/display/d.rhumbline/main.c
--- grass/branches/releasebranch_7_0/display/d.rhumbline/main.c 2014-11-25 14:43:11 UTC (rev 62940)
+++ grass/branches/releasebranch_7_0/display/d.rhumbline/main.c 2014-11-25 14:44:38 UTC (rev 62941)
@@ -42,31 +42,23 @@
module = G_define_module();
G_add_keyword(_("display"));
G_add_keyword(_("distance"));
+ G_add_keyword(_("rhumbline"));
module->description =
_("Displays the rhumbline joining two longitude/latitude coordinates.");
- parm.coor = G_define_option();
- parm.coor->key = "coor";
+ parm.coor = G_define_standard_option(G_OPT_M_COORDS);
parm.coor->key_desc = "lon1,lat1,lon2,lat2";
- parm.coor->type = TYPE_STRING;
parm.coor->required = YES;
parm.coor->description = _("Starting and ending coordinates");
- parm.lcolor = G_define_option();
- parm.lcolor->key = "lcolor";
- parm.lcolor->type = TYPE_STRING;
- parm.lcolor->required = NO;
- parm.lcolor->description = _("Line color");
- parm.lcolor->gisprompt = "old_color,color,color";
- parm.lcolor->answer = DEFAULT_FG_COLOR;
+ parm.lcolor = G_define_standard_option(G_OPT_C_FG);
+ parm.lcolor->key = "line_color";
+ parm.lcolor->label = _("Line color");
#ifdef CAN_DO_DISTANCES
- parm.tcolor = G_define_option();
- parm.tcolor->key = "tcolor";
- parm.tcolor->type = TYPE_STRING;
- parm.tcolor->required = NO;
- parm.tcolor->description = _("Text color");
- parm.tcolor->gisprompt = "old_color,color,color";
+ parm.tcolor = G_define_option(G_OPT_M_COORDS);
+ parm.tcolor->key = "text_color";
+ parm.tcolor->label = _("Text color");
#endif
if (G_parser(argc, argv))
