[GRASS-SVN] r62945 - grass/trunk/display/d.vect
svn_grass at osgeo.org
Tue Nov 25 07:07:12 PST 2014
Author: martinl
Date: 2014-11-25 07:07:12 -0800 (Tue, 25 Nov 2014)
New Revision: 62945
grass/trunk/display/d.vect/main.c
d.vect: use standardized options (#2409)
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c 2014-11-25 15:05:46 UTC (rev 62944)
+++ grass/trunk/display/d.vect/main.c 2014-11-25 15:07:12 UTC (rev 62945)
@@ -112,25 +112,15 @@
/* Colors */
- color_opt = G_define_option();
- color_opt->key = "color";
- color_opt->type = TYPE_STRING;
- color_opt->answer = DEFAULT_FG_COLOR;
+ color_opt = G_define_standard_option(G_OPT_C_FG);
color_opt->label = _("Feature color");
color_opt->guisection = _("Colors");
- color_opt->gisprompt = "old,color_none,color";
- color_opt->description =
- _("Either a standard GRASS color, R:G:B triplet, or \"none\"");
- fcolor_opt = G_define_option();
- fcolor_opt->key = "fcolor";
- fcolor_opt->type = TYPE_STRING;
+ fcolor_opt = G_define_standard_option(G_OPT_C_BG);
+ fcolor_opt->key = "fill_color";
fcolor_opt->answer = "200:200:200";
fcolor_opt->label = _("Area fill color");
fcolor_opt->guisection = _("Colors");
- fcolor_opt->gisprompt = "old,color_none,color";
- fcolor_opt->description =
rgbcol_opt = G_define_standard_option(G_OPT_DB_COLUMN);
rgbcol_opt->key = "rgb_column";
@@ -201,10 +191,10 @@
/* Labels */
lfield_opt = G_define_standard_option(G_OPT_V_FIELD);
- lfield_opt->key = "llayer";
+ lfield_opt->key = "label_layer";
lfield_opt->required = NO;
lfield_opt->guisection = _("Labels");
- lfield_opt->description =
+ lfield_opt->label =
_("Layer number for labels (default: the given layer number)");
attrcol_opt = G_define_standard_option(G_OPT_DB_COLUMN);
@@ -213,37 +203,27 @@
attrcol_opt->guisection = _("Labels");
attrcol_opt->description = _("Name of column to be displayed as a label");
- lcolor_opt = G_define_option();
- lcolor_opt->key = "lcolor";
- lcolor_opt->type = TYPE_STRING;
+ lcolor_opt = G_define_standard_option(G_OPT_C_FG);
+ lcolor_opt->key = "label_color";
lcolor_opt->answer = "red";
lcolor_opt->label = _("Label color");
lcolor_opt->guisection = _("Labels");
- lcolor_opt->gisprompt = "old_color,color,color";
- lcolor_opt->description = _("Either a standard color name or R:G:B triplet");
- bgcolor_opt = G_define_option();
- bgcolor_opt->key = "bgcolor";
- bgcolor_opt->type = TYPE_STRING;
+ bgcolor_opt = G_define_standard_option(G_OPT_C_BG);
+ bgcolor_opt->key = "label_bgcolor";
bgcolor_opt->answer = "none";
bgcolor_opt->guisection = _("Labels");
bgcolor_opt->label = _("Label background color");
- bgcolor_opt->gisprompt = "old,color_none,color";
- bgcolor_opt->description =
- bcolor_opt = G_define_option();
- bcolor_opt->key = "bcolor";
+ bcolor_opt = G_define_standard_option(G_OPT_C_BG);
+ bcolor_opt->key = "label_bcolor";
bcolor_opt->type = TYPE_STRING;
bcolor_opt->answer = "none";
bcolor_opt->guisection = _("Labels");
bcolor_opt->label = _("Label border color");
- bcolor_opt->gisprompt = "old,color_none,color";
- bcolor_opt->description =
lsize_opt = G_define_option();
- lsize_opt->key = "lsize";
+ lsize_opt->key = "label_size";
lsize_opt->type = TYPE_INTEGER;
lsize_opt->answer = "8";
lsize_opt->guisection = _("Labels");
