[GRASS-SVN] r62949 - grass/trunk/display/d.vect.chart
svn_grass at osgeo.org
Tue Nov 25 07:15:37 PST 2014
Author: martinl
Date: 2014-11-25 07:15:36 -0800 (Tue, 25 Nov 2014)
New Revision: 62949
grass/trunk/display/d.vect.chart/main.c
d.vect.chart: use standardized options (#2409)
Modified: grass/trunk/display/d.vect.chart/main.c
--- grass/trunk/display/d.vect.chart/main.c 2014-11-25 15:10:59 UTC (rev 62948)
+++ grass/trunk/display/d.vect.chart/main.c 2014-11-25 15:15:36 UTC (rev 62949)
@@ -77,7 +77,7 @@
field_opt->guisection = _("Selection");
ctype_opt = G_define_option();
- ctype_opt->key = "ctype";
+ ctype_opt->key = "chart_type";
ctype_opt->type = TYPE_STRING;
ctype_opt->required = NO;
ctype_opt->multiple = NO;
@@ -90,9 +90,8 @@
columns_opt->required = YES;
columns_opt->description = _("Attribute columns containing data");
- sizecol_opt = G_define_option();
- sizecol_opt->key = "sizecol";
- sizecol_opt->type = TYPE_STRING;
+ sizecol_opt = G_define_standard_option(G_OPT_DB_COLUMN);
+ sizecol_opt->key = "size_column";
sizecol_opt->required = NO;
sizecol_opt->description = _("Column used for pie chart size");
sizecol_opt->guisection = _("Chart properties");
@@ -112,20 +111,15 @@
scale_opt->description = _("Scale for size (to get size in pixels)");
scale_opt->guisection = _("Chart properties");
- ocolor_opt = G_define_option();
- ocolor_opt->key = "ocolor";
- ocolor_opt->type = TYPE_STRING;
- ocolor_opt->answer = DEFAULT_FG_COLOR;
- ocolor_opt->description = _("Outline color");
- ocolor_opt->gisprompt = "old_color,color,color";
+ ocolor_opt = G_define_standard_option(G_OPT_C_FG);
+ ocolor_opt->key = "outline_color";
+ ocolor_opt->label = _("Outline color");
ocolor_opt->guisection = _("Chart properties");
- colors_opt = G_define_option();
+ colors_opt = G_define_standard_option(G_OPT_C_FG);
colors_opt->key = "colors";
- colors_opt->type = TYPE_STRING;
- colors_opt->required = NO;
colors_opt->multiple = YES;
- colors_opt->description = _("Colors used to fill charts");
+ colors_opt->label = _("Colors used to fill charts");
colors_opt->gisprompt = "old_color,color,color";
colors_opt->guisection = _("Chart properties");
