[GRASS-SVN] r62957 - grass/branches/releasebranch_7_0/lib/gis
svn_grass at osgeo.org
Wed Nov 26 01:00:46 PST 2014
Author: neteler
Date: 2014-11-26 01:00:46 -0800 (Wed, 26 Nov 2014)
New Revision: 62957
grass/branches/releasebranch_7_0/lib/gis/basename.c
grass/branches/releasebranch_7_0/lib/gis/mapset_nme.c
grass/branches/releasebranch_7_0/lib/gis/nme_in_mps.c
Minor doxygen sync to trunk
Modified: grass/branches/releasebranch_7_0/lib/gis/basename.c
--- grass/branches/releasebranch_7_0/lib/gis/basename.c 2014-11-26 08:48:02 UTC (rev 62956)
+++ grass/branches/releasebranch_7_0/lib/gis/basename.c 2014-11-26 09:00:46 UTC (rev 62957)
@@ -1,17 +1,15 @@
- * \file basename.c
+ * \file lib/gis/basename.c
* \brief GIS Library - Program basename routines.
- * (C) 2001-2008 by the GRASS Development Team
+ * (C) 2001-2014 by the GRASS Development Team
* This program is free software under the GNU General Public License
* (>=v2). Read the file COPYING that comes with GRASS for details.
* \author GRASS GIS Development Team
- * \date 1999-2007
#include <grass/gis.h>
@@ -23,7 +21,7 @@
#include <stdlib.h>
* \brief Truncates filename to the base part (before the last '.')
* if it matches the extension, otherwise leaves it unchanged.
@@ -31,12 +29,12 @@
* (case insensitive) and if so, truncates the string to the
* base file name (cf. basename Unix command)
- * \param[in] filename string containing filename
- * \param[in] desired_ext string containing extension to look for (case
+ * \param filename string containing filename
+ * \param desired_ext string containing extension to look for (case
* insensitive)
- * \return Pointer to filename
+ * \return pointer to filename
char *G_basename(char *filename, const char *desired_ext)
/* Find the last . in the filename */
@@ -106,9 +104,13 @@
- * \brief Return the environmental basename variable or the default value
+ * \brief Return the environmental basename variable or the default
+ * value
+ * return pointer to basename separator
-char *G_get_basename_separator(){
+char *G_get_basename_separator()
char *envvar = "GRASS_BASENAME_SEPARATOR";
char *envsep;
Modified: grass/branches/releasebranch_7_0/lib/gis/mapset_nme.c
--- grass/branches/releasebranch_7_0/lib/gis/mapset_nme.c 2014-11-26 08:48:02 UTC (rev 62956)
+++ grass/branches/releasebranch_7_0/lib/gis/mapset_nme.c 2014-11-26 09:00:46 UTC (rev 62957)
@@ -30,7 +30,7 @@
static void new_mapset(const char *);
- \brief Get name of the n'th mapset from the mapset_name[] list.
+ \brief Get name of the n'th mapset from the current mapset search path.
The first call will initialize the list.
@@ -97,8 +97,6 @@
\brief Define alternative mapset search path
- \return 0
void G_create_alt_search_path(void)
@@ -110,8 +108,6 @@
\brief Switch mapset search path
- \return 0
void G_switch_search_path(void)
@@ -130,8 +126,6 @@
\brief Reset number of mapsets
- \return 0
void G_reset_mapsets(void)
Modified: grass/branches/releasebranch_7_0/lib/gis/nme_in_mps.c
--- grass/branches/releasebranch_7_0/lib/gis/nme_in_mps.c 2014-11-26 08:48:02 UTC (rev 62956)
+++ grass/branches/releasebranch_7_0/lib/gis/nme_in_mps.c 2014-11-26 09:00:46 UTC (rev 62957)
@@ -122,10 +122,10 @@
- <i>name, xname</i> are char array of size GNAME_MAX
- <i>mapset, xmapset</i> are char array of size GMAPSET_MAX
- \param fullname map name
- \param map mapset to check or NULL
- \param[out] name map name
- \param[out] mapset mapset name
+ \param name map name
+ \param mapset mapset to check or NULL
+ \param[out] xname map name
+ \param[out] xmapset mapset name
\return 1 if input map name is fully qualified
\return 0 if name is not fully qualified
