[GRASS-SVN] r62985 - grass/trunk/misc/m.cogo
svn_grass at osgeo.org
Wed Nov 26 02:07:49 PST 2014
Author: martinl
Date: 2014-11-26 02:07:49 -0800 (Wed, 26 Nov 2014)
New Revision: 62985
grass/trunk/misc/m.cogo/main.c
m.cogo use standardized options (#2409)
Modified: grass/trunk/misc/m.cogo/main.c
--- grass/trunk/misc/m.cogo/main.c 2014-11-26 10:07:04 UTC (rev 62984)
+++ grass/trunk/misc/m.cogo/main.c 2014-11-26 10:07:49 UTC (rev 62985)
@@ -208,7 +208,6 @@
struct Option *output;
struct Option *coords;
struct Flag *format;
- struct Flag *quiet;
struct Flag *reverse;
struct Flag *close;
struct GModule *module;
@@ -216,7 +215,6 @@
struct survey_record record, first_record;
const char *cptr;
char *ss;
- int verbose = TRUE;
unsigned long linenum = 0, dataline = 0;
int (*parse_line) (const char *, struct survey_record *);
void (*print_func) (FILE *, struct survey_record *);
@@ -234,10 +232,6 @@
format->key = 'l';
format->description = _("Lines are labelled");
- quiet = G_define_flag();
- quiet->key = 'q';
- quiet->description = _("Suppress warnings");
reverse = G_define_flag();
reverse->key = 'r';
reverse->description =
@@ -256,11 +250,7 @@
output->required = NO;
output->answer = "-";
- coords = G_define_option();
- coords->key = "coord";
- coords->key_desc = "x,y";
- coords->type = TYPE_DOUBLE;
- coords->required = NO;
+ coords = G_define_standard_option(G_OPT_M_COORDS);
coords->description = _("Starting coordinate pair");
coords->answer = "0.0,0.0";
@@ -295,9 +285,6 @@
record.haslabel = NO;
- if (quiet->answer)
- verbose = FALSE;
if (reverse->answer) {
parse_line = parse_reverse;
print_func = print_cogo;
@@ -328,8 +315,7 @@
if (!parse_line(cptr, &record)) {
- if (verbose)
- G_warning(_("Input parse error on line %lu"), linenum);
+ G_warning(_("Input parse error on line %lu"), linenum);
continue;
