[GRASS-SVN] r63015 - in grass/trunk: db/db.select raster/r.describe
svn_grass at osgeo.org
Wed Nov 26 03:27:03 PST 2014
Author: martinl
Date: 2014-11-26 03:27:03 -0800 (Wed, 26 Nov 2014)
New Revision: 63015
grass/trunk/db/db.select/main.c
grass/trunk/raster/r.describe/main.c
use G_OPT_M_NULL_VALUE
Modified: grass/trunk/db/db.select/main.c
--- grass/trunk/db/db.select/main.c 2014-11-26 11:21:37 UTC (rev 63014)
+++ grass/trunk/db/db.select/main.c 2014-11-26 11:27:03 UTC (rev 63015)
@@ -232,11 +232,7 @@
vs->answer = NULL;
vs->guisection = _("Format");
- nv = G_define_option();
- nv->key = "nv";
- nv->type = TYPE_STRING;
- nv->required = NO;
- nv->description = _("Null value indicator");
+ nv = G_define_standard_option(G_OPT_M_NULL_VALUE);
nv->guisection = _("Format");
output = G_define_standard_option(G_OPT_F_OUTPUT);
Modified: grass/trunk/raster/r.describe/main.c
--- grass/trunk/raster/r.describe/main.c 2014-11-26 11:21:37 UTC (rev 63014)
+++ grass/trunk/raster/r.describe/main.c 2014-11-26 11:27:03 UTC (rev 63015)
@@ -59,13 +59,8 @@
/* define different options */
option.map = G_define_standard_option(G_OPT_R_MAP);
- option.nv = G_define_option();
- option.nv->key = "nv";
- option.nv->type = TYPE_STRING;
- option.nv->required = NO;
- option.nv->multiple = NO;
+ option.nv = G_define_standard_option(G_OPT_M_NULL_VALUE);
option.nv->answer = "*";
- option.nv->description = _("String representing no data cell value");
option.nsteps = G_define_option();
option.nsteps->key = "nsteps";
