[GRASS-SVN] r63026 - grass/trunk/raster/r.param.scale
svn_grass at osgeo.org
Wed Nov 26 05:05:47 PST 2014
Author: martinl
Date: 2014-11-26 05:05:47 -0800 (Wed, 26 Nov 2014)
New Revision: 63026
grass/trunk/raster/r.param.scale/interface.c
r.param.scale use standardized options (#2409)
Modified: grass/trunk/raster/r.param.scale/interface.c
--- grass/trunk/raster/r.param.scale/interface.c 2014-11-26 13:04:12 UTC (rev 63025)
+++ grass/trunk/raster/r.param.scale/interface.c 2014-11-26 13:05:47 UTC (rev 63026)
@@ -74,14 +74,14 @@
rast_out->description =
_("Name for output raster map containing morphometric parameter");
- tol1_val->key = "s_tol";
+ tol1_val->key = "slope_tol";
tol1_val->description =
_("Slope tolerance that defines a 'flat' surface (degrees)");
tol1_val->type = TYPE_DOUBLE;
tol1_val->required = NO;
tol1_val->answer = "1.0";
- tol2_val->key = "c_tol";
+ tol2_val->key = "curvature_tol";
tol2_val->description =
_("Curvature tolerance that defines 'planar' surface");
tol2_val->type = TYPE_DOUBLE;
@@ -105,7 +105,7 @@
"elev,slope,aspect,profc,planc,longc,crosc,minic,maxic,feature";
parameter->answer = "elev";
- expon->key = "exp";
+ expon->key = "exponent";
expon->description = _("Exponent for distance weighting (0.0-4.0)");
expon->type = TYPE_DOUBLE;
expon->required = NO;
