[GRASS-SVN] r63049 - grass/trunk/raster/r.resamp.rst
svn_grass at osgeo.org
Wed Nov 26 06:01:43 PST 2014
Author: martinl
Date: 2014-11-26 06:01:43 -0800 (Wed, 26 Nov 2014)
New Revision: 63049
grass/trunk/raster/r.resamp.rst/main.c
r.resamp.rst: use standardized options (#2409)
Modified: grass/trunk/raster/r.resamp.rst/main.c
--- grass/trunk/raster/r.resamp.rst/main.c 2014-11-26 13:54:19 UTC (rev 63048)
+++ grass/trunk/raster/r.resamp.rst/main.c 2014-11-26 14:01:43 UTC (rev 63049)
@@ -167,68 +167,52 @@
parm.res_ns->required = YES;
parm.res_ns->description = _("Desired north-south resolution");
- parm.elev = G_define_option();
- parm.elev->key = "elev";
- parm.elev->type = TYPE_STRING;
+ parm.elev = G_define_standard_option(G_OPT_R_ELEV);
parm.elev->required = NO;
parm.elev->gisprompt = "new,cell,raster";
- parm.elev->description = _("Output z-file (elevation) map");
+ parm.elev->description = _("Name for output elevation raster map");
parm.elev->guisection = _("Output");
- parm.slope = G_define_option();
+ parm.slope = G_define_standard_option(G_OPT_R_OUTPUT);
parm.slope->key = "slope";
- parm.slope->type = TYPE_STRING;
parm.slope->required = NO;
- parm.slope->gisprompt = "new,cell,raster";
- parm.slope->description = _("Output slope map (or fx)");
+ parm.slope->description = _("Name for output slope map (or fx)");
parm.slope->guisection = _("Output");
- parm.aspect = G_define_option();
+ parm.aspect = G_define_standard_option(G_OPT_R_OUTPUT);
parm.aspect->key = "aspect";
- parm.aspect->type = TYPE_STRING;
parm.aspect->required = NO;
- parm.aspect->gisprompt = "new,cell,raster";
- parm.aspect->description = _("Output aspect map (or fy)");
+ parm.aspect->description = _("Name for output aspect map (or fy)");
parm.aspect->guisection = _("Output");
- parm.pcurv = G_define_option();
- parm.pcurv->key = "pcurv";
- parm.pcurv->type = TYPE_STRING;
+ parm.pcurv = G_define_standard_option(G_OPT_R_OUTPUT);
+ parm.pcurv->key = "pcurvature";
parm.pcurv->required = NO;
- parm.pcurv->gisprompt = "new,cell,raster";
- parm.pcurv->description = _("Output profile curvature map (or fxx)");
+ parm.pcurv->description = _("Name for output profile curvature map (or fxx)");
parm.pcurv->guisection = _("Output");
- parm.tcurv = G_define_option();
- parm.tcurv->key = "tcurv";
- parm.tcurv->type = TYPE_STRING;
+ parm.tcurv = G_define_standard_option(G_OPT_R_OUTPUT);
+ parm.tcurv->key = "tcurvature";
parm.tcurv->required = NO;
- parm.tcurv->gisprompt = "new,cell,raster";
- parm.tcurv->description = _("Output tangential curvature map (or fyy)");
+ parm.tcurv->description = _("Name for output tangential curvature map (or fyy)");
parm.tcurv->guisection = _("Output");
- parm.mcurv = G_define_option();
- parm.mcurv->key = "mcurv";
- parm.mcurv->type = TYPE_STRING;
+ parm.mcurv = G_define_standard_option(G_OPT_R_OUTPUT);
+ parm.mcurv->key = "mcurvature";
parm.mcurv->required = NO;
- parm.mcurv->gisprompt = "new,cell,raster";
- parm.mcurv->description = _("Output mean curvature map (or fxy)");
+ parm.mcurv->description = _("Name for output mean curvature map (or fxy)");
parm.mcurv->guisection = _("Output");
- parm.smooth = G_define_option();
+ parm.smooth = G_define_standard_option(G_OPT_R_INPUT);
parm.smooth->key = "smooth";
- parm.smooth->type = TYPE_STRING;
parm.smooth->required = NO;
- parm.smooth->gisprompt = "old,cell,raster";
- parm.smooth->description = _("Name of raster map containing smoothing");
+ parm.smooth->description = _("Name of input raster map containing smoothing");
parm.smooth->guisection = _("Settings");
- parm.maskmap = G_define_option();
+ parm.maskmap = G_define_standard_option(G_OPT_R_INPUT);
parm.maskmap->key = "maskmap";
- parm.maskmap->type = TYPE_STRING;
parm.maskmap->required = NO;
- parm.maskmap->gisprompt = "old,cell,raster";
- parm.maskmap->description = _("Name of raster map to be used as mask");
+ parm.maskmap->description = _("Name of input raster map to be used as mask");
parm.maskmap->guisection = _("Settings");
parm.overlap = G_define_option();
@@ -240,7 +224,7 @@
parm.overlap->guisection = _("Settings");
parm.zmult = G_define_option();
- parm.zmult->key = "zmult";
+ parm.zmult->key = "zmultiplier";
parm.zmult->type = TYPE_DOUBLE;
parm.zmult->answer = ZMULT;
parm.zmult->required = NO;
