[GRASS-SVN] r63056 - grass/branches/releasebranch_7_0/raster/r.spreadpath
svn_grass at osgeo.org
Wed Nov 26 06:21:49 PST 2014
Author: martinl
Date: 2014-11-26 06:21:49 -0800 (Wed, 26 Nov 2014)
New Revision: 63056
grass/branches/releasebranch_7_0/raster/r.spreadpath/main.c
r.spreadpath: use standardized options (#2409) - (merge r63055 from trunk)
Modified: grass/branches/releasebranch_7_0/raster/r.spreadpath/main.c
--- grass/branches/releasebranch_7_0/raster/r.spreadpath/main.c 2014-11-26 14:20:53 UTC (rev 63055)
+++ grass/branches/releasebranch_7_0/raster/r.spreadpath/main.c 2014-11-26 14:21:49 UTC (rev 63056)
@@ -63,7 +63,7 @@
int main(int argc, char **argv)
- int n, verbose = 1,
+ int n,
backrow, backcol,
col, row,
len, flag,
@@ -79,7 +79,6 @@
struct Cell_head window;
double east, north;
struct Option *opt1, *opt2, *opt3, *opt4;
- struct Flag *flag1;
struct GModule *module;
G_gisinit(argv[0]);
@@ -93,41 +92,23 @@
_("Recursively traces the least cost path backwards to "
"cells from which the cumulative cost was determined.");
- opt1 = G_define_option();
+ opt1 = G_define_standard_option(G_OPT_R_INPUT);
opt1->key = "x_input";
- opt1->type = TYPE_STRING;
- opt1->required = YES;
- opt1->gisprompt = "old,cell,raster";
opt1->description =
_("Name of raster map containing back-path easting information");
- opt2 = G_define_option();
+ opt2 = G_define_standard_option(G_OPT_R_INPUT);
opt2->key = "y_input";
- opt2->type = TYPE_STRING;
- opt2->required = YES;
- opt2->gisprompt = "old,cell,raster";
opt2->description =
_("Name of raster map containing back-path northing information");
- opt3 = G_define_option();
- opt3->key = "coordinate";
- opt3->type = TYPE_STRING;
+ opt3 = G_define_standard_option(G_OPT_M_COORDS);
opt3->multiple = YES;
- opt3->key_desc = "x,y";
opt3->description =
_("The map E and N grid coordinates of starting points");
- opt4 = G_define_option();
- opt4->key = "output";
- opt4->type = TYPE_STRING;
- opt4->required = YES;
- opt4->gisprompt = "new,cell,raster";
- opt4->description = _("Name of spread path raster map");
+ opt4 = G_define_standard_option(G_OPT_R_OUTPUT);
- flag1 = G_define_flag();
- flag1->key = 'v';
- flag1->description = _("Run verbosely");
/* Do command line parsing */
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -140,8 +121,6 @@
/* Get database window parameters */
G_get_window(&window);
- verbose = flag1->answer;
/* Check if backrow layer exists in data base */
search_mapset = "";
@@ -179,9 +158,7 @@
srows = nrows / 4 + 1;
scols = ncols / 4 + 1;
- if (verbose)
- G_message
- ("\nReading the input map -%s- and -%s- and creating some temporary files...",
+ G_verbose_message(_("\eading the input map -%s- and -%s- and creating some temporary files..."),
backrow_layer, backcol_layer);
/* Create segmented files for back cell and output layers */
@@ -301,8 +278,7 @@
/* loop over the starting points to find the least cost paths */
- if (verbose)
- G_message("\nFinding the least cost paths ...");
+ G_verbose_message(_("Finding the least cost paths ..."));
PRES_PT = head_start_pt;
while (PRES_PT != NULL) {
@@ -317,8 +293,7 @@
/* Write pending updates by Segment_put() to outputmap */
Segment_flush(&out_seg);
- if (verbose)
- G_message("\nWriting the output map -%s-...", path_layer);
+ G_verbose_message(_("Writing the output map -%s-..."), path_layer);
path_fd = Rast_open_c_new(path_layer);
for (row = 0; row < nrows; row++) {
@@ -326,9 +301,6 @@
Rast_put_row(path_fd, cell, CELL_TYPE);
- if (verbose)
- G_message("finished.");
Segment_release(&in_row_seg); /* release memory */
Segment_release(&in_col_seg);
Segment_release(&out_seg);
