[GRASS-SVN] r63108 - in grass/branches/releasebranch_7_0: . vector/v.external.out
svn_grass at osgeo.org
Wed Nov 26 08:24:49 PST 2014
Author: martinl
Date: 2014-11-26 08:24:49 -0800 (Wed, 26 Nov 2014)
New Revision: 63108
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/vector/v.external.out/args.c
v.external.out: use standardized options (#2409) - (merge r63107 from trunk)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:60817,61096,61141,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62856,62879,62881,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,63089,63091,63093,63095,
63098,63100,63102,63105
+ /grass/trunk:60817,61096,61141,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62856,62879,62881,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,63089,63091,63093,63095,
63098,63100,63102,63105,63107
Modified: grass/branches/releasebranch_7_0/vector/v.external.out/args.c
--- grass/branches/releasebranch_7_0/vector/v.external.out/args.c 2014-11-26 16:24:20 UTC (rev 63107)
+++ grass/branches/releasebranch_7_0/vector/v.external.out/args.c 2014-11-26 16:24:49 UTC (rev 63108)
@@ -9,7 +9,7 @@
struct _options *options, struct _flags *flags)
options->dsn = G_define_option();
- options->dsn->key = "dsn";
+ options->dsn->key = "input";
options->dsn->type = TYPE_STRING;
options->dsn->label = _("Name of input OGR or PostGIS data source");
options->dsn->description = _("Examples:\n"
@@ -47,11 +47,13 @@
options->opts->guisection = _("Settings");
options->input = G_define_standard_option(G_OPT_F_INPUT);
+ options->input->key = "loadsettings";
options->input->required = NO;
options->input->description = _("Name of input file to read settings from");
options->input->guisection = _("Settings");
options->output = G_define_standard_option(G_OPT_F_OUTPUT);
+ options->output->key = "savesettings";
options->output->required = NO;
options->output->description = _("Name for output file where to save current settings");
