[GRASS-SVN] r63115 - grass/branches/releasebranch_7_0/raster/r.info
svn_grass at osgeo.org
Wed Nov 26 08:33:21 PST 2014
Author: neteler
Date: 2014-11-26 08:33:21 -0800 (Wed, 26 Nov 2014)
New Revision: 63115
grass/branches/releasebranch_7_0/raster/r.info/r.info.html
r.info manual: example updated
Modified: grass/branches/releasebranch_7_0/raster/r.info/r.info.html
--- grass/branches/releasebranch_7_0/raster/r.info/r.info.html 2014-11-26 16:33:05 UTC (rev 63114)
+++ grass/branches/releasebranch_7_0/raster/r.info/r.info.html 2014-11-26 16:33:21 UTC (rev 63115)
@@ -15,10 +15,10 @@
The user can save the tabular output to a file
by using the UNIX redirection mechanism (>); for example, the user
might save a report on the <em>soils</em> map layer in a file called
-<em>soil.rpt</em> by typing:
+<em>soil.txt</em> by typing:
<div class="code"><pre>
-r.info map=soils > soil.rpt
+r.info map=soils > soil.txt
</pre></div>
<h2>NOTES</h2>
@@ -28,45 +28,45 @@
<p>
Some standards (ISO-C90) and compilers do not support the 'long long' type
-as a 64-bit type. In the case that GRASS was built with such a compiler,
+as a 64-bit type. In the case that GRASS GIS was built with such a compiler,
an accuracy message may be displayed in the output of <em>r.info</em>
-after Total Cells:
+after Total Cells.
-<p>
<h2>EXAMPLES</h2>
Below is a full report produced by <em>r.info</em> for the raster map
-<i>slope</i> in the Spearfish sample data base:
+<i>slope</i> in the North Carolina sample data base:
+r.info slope
- | Layer: slope Date: Mon Nov 5 10:55:57 2001 |
- | Mapset: PERMANENT Login of Creator: neteler |
- | DataBase: /home/neteler/grassdaten |
- | Title: slope in degrees ( slope ) |
- | Timestamp: 20 Mar 1984 10:30 -0600 / 21 Mar 2020 10:30 -0600 |
+ | Map: slope Date: Tue Nov 7 01:11:23 2006 |
+ | Mapset: PERMANENT Login of Creator: helena |
+ | Location: nc_spm_08_grass7 |
+ | DataBase: /grassdata |
+ | Title: South-West Wake county: slope in degrees ( slope_ned10m ) |
+ | Timestamp: none |
| Type of Map: raster Number of Categories: 255 |
| Data Type: FCELL |
- | Rows: 477 |
- | Columns: 634 |
- | Total Cells: 302418 |
- | Projection: UTM (zone 13) |
- | N: 4928010 S: 4913700 Res: 30 |
- | E: 609000 W: 589980 Res: 30 |
- | Range of data: min = 0.000000 max = 52.520164 |
+ | Rows: 1350 |
+ | Columns: 1500 |
+ | Total Cells: 2025000 |
+ | Projection: Lambert Conformal Conic |
+ | N: 228500 S: 215000 Res: 10 |
+ | E: 645000 W: 630000 Res: 10 |
+ | Range of data: min = 0 max = 38.68939 |
| Data Source: |
- | raster elevation file elevation.dem |
+ | raster elevation file elev_ned10m |
| Data Description: |
| generated by r.slope.aspect |
| Comments: |
- | slope map elev = elevation.dem |
+ | slope map elev = elev_ned10m |
| zfactor = 1.00 format = degrees |
| min_slp_allowed = 0.000000 |
@@ -76,41 +76,65 @@
Alternatively, the output from <em>r.info</em> may be confined to a more terse
subset of the available information by passing various flags to the module:
-<div class="code"><pre>
-GRASS> r.info -g slope
-north=4928030
-south=4913690
-east=609000
-west=589980
-nsres=30
-ewres=30
-rows=477
-cols=634
-cells=302418
+<p>
+Output in shell script style, useful for eval (<tt>eval `r.info -g slope`</tt>):
+<div class="code"><pre>
+r.info -g slope
+north=228500
+south=215000
+east=645000
+west=630000
+nsres=10
+ewres=10
+rows=1350
+cols=1500
+cells=2025000
datatype=FCELL
+ncats=255
+</pre></div>
-GRASS> r.info -r slope
-min=0.000000
-max=52.520164
+<p>
+Output the map data range:
+r.info -r slope
+min=0
+max=38.68939
+</pre></div>
-GRASS> r.info -e slope
-title=slope in degrees (slope)
+<p>
+Output the extended map data metadata in shell style:
+r.info -e slope
+map=slope
+mapset=PERMANENT
+location=nc_spm_08_grass7
+database=/grassdata
+date="Tue Nov 7 01:11:23 2006"
+creator="helena"
+title="South-West Wake county: slope in degrees (slope_ned10m)"
+timestamp="none"
units="none"
-vertical_datum="none"
-timestamp="none"
+vdatum="none"
+source1="raster elevation file elev_ned10m"
+source2=""
+description="generated by r.slope.aspect"
+comments="slope map elev = elev_ned10mzfactor = 1.00 format = degreesmin_slp_allowed = 0.000000"
</pre></div>
<h2>SEE ALSO</h2>
-<em><a href="g.mapsets.html">g.mapsets</a>,</em>
-<em><a href="r.coin.html">r.coin</a>,</em>
-<em><a href="r.describe.html">r.describe</a>,</em>
-<em><a href="r.report.html">r.report</a>,</em>
-<em><a href="r.stats.html">r.stats</a>,</em>
-<em><a href="r.support.html">r.support</a>,</em>
-<em><a href="r.univar.html">r.univar</a>,</em>
-<em><a href="r.what.html">r.what</a></em>
+<em>
+<a href="g.mapsets.html">g.mapsets</a>,
+<a href="r.coin.html">r.coin</a>,
+<a href="r.describe.html">r.describe</a>,
+<a href="r.report.html">r.report</a>,
+<a href="r.stats.html">r.stats</a>,
+<a href="r.support.html">r.support</a>,
+<a href="r.univar.html">r.univar</a>,
+<a href="r.what.html">r.what</a>
+</em>
<h2>AUTHOR</h2>
