[GRASS-SVN] r63125 - grass/trunk/vector/v.outlier
svn_grass at osgeo.org
Wed Nov 26 08:43:32 PST 2014
Author: martinl
Date: 2014-11-26 08:43:32 -0800 (Wed, 26 Nov 2014)
New Revision: 63125
grass/trunk/vector/v.outlier/main.c
v.outlier: use standardized options (#2409)
Modified: grass/trunk/vector/v.outlier/main.c
--- grass/trunk/vector/v.outlier/main.c 2014-11-26 16:43:10 UTC (rev 63124)
+++ grass/trunk/vector/v.outlier/main.c 2014-11-26 16:43:32 UTC (rev 63125)
@@ -115,7 +115,7 @@
stepN_opt->guisection = _("Settings");
lambda_f_opt = G_define_option();
- lambda_f_opt->key = "lambda_i";
+ lambda_f_opt->key = "lambda";
lambda_f_opt->type = TYPE_DOUBLE;
lambda_f_opt->required = NO;
lambda_f_opt->description = _("Tykhonov regularization weight");
@@ -123,7 +123,7 @@
lambda_f_opt->guisection = _("Settings");
Thres_O_opt = G_define_option();
- Thres_O_opt->key = "thres_o";
+ Thres_O_opt->key = "threshold";
Thres_O_opt->type = TYPE_DOUBLE;
Thres_O_opt->required = NO;
Thres_O_opt->description = _("Threshold for the outliers");
