[GRASS-SVN] r63128 - in grass/branches/releasebranch_7_0: . vector/v.outlier
Wed Nov 26 08:44:05 PST 2014
Author: martinl
Date: 2014-11-26 08:44:05 -0800 (Wed, 26 Nov 2014)
New Revision: 63128
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/vector/v.outlier/main.c
v.outlier: use standardized options (#2409) - (merge r63125 from trunk)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60817,61096,61141,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62856,62879,62881,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,63089,63091,63093,63095,
 63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123
   + /grass/trunk:60817,61096,61141,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62856,62879,62881,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,63089,63091,63093,63095,
 63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125
Modified: grass/branches/releasebranch_7_0/vector/v.outlier/main.c
--- grass/branches/releasebranch_7_0/vector/v.outlier/main.c	2014-11-26 16:43:46 UTC (rev 63127)
+++ grass/branches/releasebranch_7_0/vector/v.outlier/main.c	2014-11-26 16:44:05 UTC (rev 63128)
@@ -115,7 +115,7 @@
     stepN_opt->guisection = _("Settings");
     lambda_f_opt = G_define_option();
-    lambda_f_opt->key = "lambda_i";
+    lambda_f_opt->key = "lambda";
     lambda_f_opt->type = TYPE_DOUBLE;
     lambda_f_opt->required = NO;
     lambda_f_opt->description = _("Tykhonov regularization weight");
@@ -123,7 +123,7 @@
     lambda_f_opt->guisection = _("Settings");
     Thres_O_opt = G_define_option();
-    Thres_O_opt->key = "thres_o";
+    Thres_O_opt->key = "threshold";
     Thres_O_opt->type = TYPE_DOUBLE;
     Thres_O_opt->required = NO;
     Thres_O_opt->description = _("Threshold for the outliers");
