[GRASS-SVN] r63147 - grass/trunk/vector/v.to.rast
Wed Nov 26 09:08:23 PST 2014
Author: martinl
Date: 2014-11-26 09:08:23 -0800 (Wed, 26 Nov 2014)
New Revision: 63147
   grass/trunk/vector/v.to.rast/main.c
v.to.rast: use standardized options (#2409)
Modified: grass/trunk/vector/v.to.rast/main.c
--- grass/trunk/vector/v.to.rast/main.c	2014-11-26 17:06:02 UTC (rev 63146)
+++ grass/trunk/vector/v.to.rast/main.c	2014-11-26 17:08:23 UTC (rev 63147)
@@ -82,19 +82,19 @@
     use_opt->descriptions = desc;
     col = G_define_standard_option(G_OPT_DB_COLUMN);
-    col->key = "attrcolumn";
+    col->key = "attribute_column";
     col->description =
 	_("Name of column for 'attr' parameter (data type must be numeric)");
     col->guisection = _("Attributes");
     rgbcol_opt = G_define_standard_option(G_OPT_DB_COLUMN);
-    rgbcol_opt->key = "rgbcolumn";
+    rgbcol_opt->key = "rgb_column";
     rgbcol_opt->description =
 	_("Name of color definition column (with RRR:GGG:BBB entries)");
     rgbcol_opt->guisection = _("Attributes");
     label_opt = G_define_standard_option(G_OPT_DB_COLUMN);
-    label_opt->key = "labelcolumn";
+    label_opt->key = "label_column";
     label_opt->description =
 	_("Name of column used as raster category labels");
     label_opt->guisection = _("Attributes");
