[GRASS-SVN] r63151 - grass/trunk/vector/v.vect.stats
svn_grass at osgeo.org
Wed Nov 26 09:15:21 PST 2014
Author: martinl
Date: 2014-11-26 09:15:21 -0800 (Wed, 26 Nov 2014)
New Revision: 63151
grass/trunk/vector/v.vect.stats/main.c
v.vect.stats: use standardized options (#2409)
Modified: grass/trunk/vector/v.vect.stats/main.c
--- grass/trunk/vector/v.vect.stats/main.c 2014-11-26 17:12:53 UTC (rev 63150)
+++ grass/trunk/vector/v.vect.stats/main.c 2014-11-26 17:15:21 UTC (rev 63151)
@@ -150,11 +150,11 @@
point_type_opt->required = NO;
point_field_opt = G_define_standard_option(G_OPT_V_FIELD);
- point_field_opt->key = "player";
+ point_field_opt->key = "points_layer";
point_field_opt->label = _("Layer number for points map");
area_field_opt = G_define_standard_option(G_OPT_V_FIELD);
- area_field_opt->key = "alayer";
+ area_field_opt->key = "areas_layer";
area_field_opt->label = _("Layer number for area map");
method_opt = G_define_option();
@@ -174,7 +174,7 @@
method_opt->description = _("Method for aggregate statistics");
point_column_opt = G_define_standard_option(G_OPT_DB_COLUMN);
- point_column_opt->key = "pcolumn";
+ point_column_opt->key = "points_column";
point_column_opt->required = NO;
point_column_opt->multiple = NO;
point_column_opt->label =
@@ -182,7 +182,7 @@
point_column_opt->description = _("Column of points map must be numeric");
count_column_opt = G_define_option();
- count_column_opt->key = "ccolumn";
+ count_column_opt->key = "count_column";
count_column_opt->type = TYPE_STRING;
count_column_opt->required = NO;
count_column_opt->multiple = NO;
@@ -191,7 +191,7 @@
_("Column to hold points count, must be of type integer, will be created if not existing");
stats_column_opt = G_define_option();
- stats_column_opt->key = "scolumn";
+ stats_column_opt->key = "stats_column";
stats_column_opt->type = TYPE_STRING;
stats_column_opt->required = NO;
stats_column_opt->multiple = NO;
