[GRASS-SVN] r63153 - grass/trunk/vector/v.vol.rst
svn_grass at osgeo.org
Wed Nov 26 09:26:33 PST 2014
Author: martinl
Date: 2014-11-26 09:26:33 -0800 (Wed, 26 Nov 2014)
New Revision: 63153
grass/trunk/vector/v.vol.rst/main.c
v.vol.rst: use standardized options (#2409)
Modified: grass/trunk/vector/v.vol.rst/main.c
--- grass/trunk/vector/v.vol.rst/main.c 2014-11-26 17:17:03 UTC (rev 63152)
+++ grass/trunk/vector/v.vol.rst/main.c 2014-11-26 17:26:33 UTC (rev 63153)
@@ -248,7 +248,7 @@
parm.input->description = NULL; /* no OGR support */
parm.cellinp = G_define_standard_option(G_OPT_R_INPUT);
- parm.cellinp->key = "cellinp";
+ parm.cellinp->key = "cross_input";
parm.cellinp->required = NO;
parm.cellinp->description =
_("Name of input surface raster map for cross-section");
@@ -258,7 +258,7 @@
parm.colnum->key = "wcolumn";
parm.colnum->required = NO;
parm.colnum->description =
- _("Name of column containing w attribute to interpolate");
+ _("Name of column containing w-values attribute to interpolate");
parm.fi = G_define_option();
parm.fi->key = "tension";
@@ -277,7 +277,7 @@
parm.rsm->guisection = _("Settings");
parm.scol = G_define_standard_option(G_OPT_DB_COLUMN);
- parm.scol->key = "scolumn";
+ parm.scol->key = "smooth_column";
parm.scol->required = NO;
parm.scol->description =
_("Name of column with smoothing parameters");
@@ -338,7 +338,7 @@
parm.dmin1->guisection = _("Settings");
parm.wmult = G_define_option();
- parm.wmult->key = "wmult";
+ parm.wmult->key = "wmultiplier";
parm.wmult->type = TYPE_DOUBLE;
parm.wmult->answer = ZMULT;
parm.wmult->required = NO;
@@ -347,7 +347,7 @@
parm.wmult->guisection = _("Settings");
parm.zmult = G_define_option();
- parm.zmult->key = "zmult";
+ parm.zmult->key = "zmultiplier";
parm.zmult->type = TYPE_DOUBLE;
parm.zmult->answer = ZMULT;
parm.zmult->required = NO;
@@ -355,13 +355,13 @@
parm.zmult->guisection = _("Settings");
parm.cellout = G_define_standard_option(G_OPT_R_OUTPUT);
- parm.cellout->key = "cellout";
+ parm.cellout->key = "cross_output";
parm.cellout->required = NO;
parm.cellout->description = _("Name for output cross-section raster map");
parm.cellout->guisection = _("Outputs");
parm.outz = G_define_standard_option(G_OPT_R3_OUTPUT);
- parm.outz->key = "elev";
+ parm.outz->key = "elevation";
parm.outz->required = NO;
parm.outz->description = _("Name for output elevation 3D raster map");
parm.outz->guisection = _("Outputs");
@@ -373,32 +373,32 @@
parm.gradient->guisection = _("Outputs");
parm.aspect1 = G_define_standard_option(G_OPT_R3_OUTPUT);
- parm.aspect1->key = "aspect1";
+ parm.aspect1->key = "aspect_horizontal";
parm.aspect1->required = NO;
parm.aspect1->description =
_("Name for output gradient horizontal angle 3D raster map");
parm.aspect1->guisection = _("Outputs");
parm.aspect2 = G_define_standard_option(G_OPT_R3_OUTPUT);
- parm.aspect2->key = "aspect2";
+ parm.aspect2->key = "aspect_vertical";
parm.aspect2->required = NO;
parm.aspect2->description = _("Name for output gradient vertical angle 3D raster map");
parm.aspect2->guisection = _("Outputs");
parm.ncurv = G_define_standard_option(G_OPT_R3_OUTPUT);
- parm.ncurv->key = "ncurv";
+ parm.ncurv->key = "ncurvature";
parm.ncurv->required = NO;
parm.ncurv->description = _("Name for output change of gradient 3D raster map");
parm.ncurv->guisection = _("Outputs");
parm.gcurv = G_define_standard_option(G_OPT_R3_OUTPUT);
- parm.gcurv->key = "gcurv";
+ parm.gcurv->key = "gcurvature";
parm.gcurv->required = NO;
parm.gcurv->description = _("Name for output Gaussian curvature 3D raster map");
parm.gcurv->guisection = _("Outputs");
parm.mcurv = G_define_standard_option(G_OPT_R3_OUTPUT);
- parm.mcurv->key = "mcurv";
+ parm.mcurv->key = "mcurvature";
parm.mcurv->required = NO;
parm.mcurv->description = _("Name for output mean curvature 3D raster map");
parm.mcurv->guisection = _("Outputs");
