[GRASS-SVN] r63158 - in grass/branches/releasebranch_7_0: . scripts/v.what.vect
Wed Nov 26 09:32:50 PST 2014
Author: martinl
Date: 2014-11-26 09:32:50 -0800 (Wed, 26 Nov 2014)
New Revision: 63158
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/scripts/v.what.vect/v.what.vect.py
v.vect.vect: use standardized options (#2409) - (merge r63157 from trunk)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60817,61096,61141,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62856,62879,62881,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,63089,63091,63093,63095,
 63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153
   + /grass/trunk:60817,61096,61141,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62856,62879,62881,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,63089,63091,63093,63095,
 63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153,63157
Modified: grass/branches/releasebranch_7_0/scripts/v.what.vect/v.what.vect.py
--- grass/branches/releasebranch_7_0/scripts/v.what.vect/v.what.vect.py	2014-11-26 17:32:21 UTC (rev 63157)
+++ grass/branches/releasebranch_7_0/scripts/v.what.vect/v.what.vect.py	2014-11-26 17:32:50 UTC (rev 63158)
@@ -31,15 +31,15 @@
 #% required: yes
 #%end
 #%option G_OPT_V_MAP
-#% key: qmap
+#% key: query_map
 #% label: Name of vector map to be queried
 #% required : yes
 #%end
 #%option G_OPT_V_FIELD
-#% key: qlayer
+#% key: query_layer
 #%end
 #%option G_OPT_DB_COLUMN
-#% key: qcolumn
+#% key: query_column
 #% description: Name of attribute column to be queried
 #% required: yes
 #%end
