[GRASS-SVN] r63170 - in grass/trunk: display/d.colorlist imagery/i.biomass imagery/i.evapo.mh imagery/i.evapo.pt raster/r.to.rast3 raster3d/r3.gradient temporal/t.rast3d.extract vector/v.mkgrid vector/v.surf.rst vector/v.vol.rst
svn_grass at osgeo.org
Wed Nov 26 15:20:52 PST 2014
Author: neteler
Date: 2014-11-26 15:20:52 -0800 (Wed, 26 Nov 2014)
New Revision: 63170
grass/trunk/display/d.colorlist/main.c
grass/trunk/imagery/i.biomass/main.c
grass/trunk/imagery/i.evapo.mh/main.c
grass/trunk/imagery/i.evapo.pt/main.c
grass/trunk/raster/r.to.rast3/main.c
grass/trunk/raster3d/r3.gradient/main.c
grass/trunk/raster3d/r3.gradient/r3.gradient.html
grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py
grass/trunk/vector/v.mkgrid/main.c
grass/trunk/vector/v.surf.rst/main.c
grass/trunk/vector/v.vol.rst/main.c
use standardized options (#2409)
Modified: grass/trunk/display/d.colorlist/main.c
--- grass/trunk/display/d.colorlist/main.c 2014-11-26 23:20:48 UTC (rev 63169)
+++ grass/trunk/display/d.colorlist/main.c 2014-11-26 23:20:52 UTC (rev 63170)
@@ -39,12 +39,9 @@
"separator (default is comma).";
/* set up option */
- sep = G_define_option();
- sep->key = "fs";
- sep->type = TYPE_STRING;
- sep->required = NO;
+ sep = G_define_standard_option(G_OPT_F_SEP);
+ sep->key = "separator";
sep->description = "Character for separation of list items";
- sep->answer = ",";
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
Modified: grass/trunk/imagery/i.biomass/main.c
--- grass/trunk/imagery/i.biomass/main.c 2014-11-26 23:20:48 UTC (rev 63169)
+++ grass/trunk/imagery/i.biomass/main.c 2014-11-26 23:20:52 UTC (rev 63170)
@@ -60,7 +60,7 @@
input1->description = _("Name of fPAR raster map");
input2 = G_define_standard_option(G_OPT_R_INPUT);
- input2->key = "lightuseefficiency";
+ input2->key = "lightuse_efficiency";
input2->description =
_("Name of light use efficiency raster map (UZB:cotton=1.9)");
@@ -73,12 +73,12 @@
input4->description = _("Name of Day of Year raster map [1-366]");
input5 = G_define_standard_option(G_OPT_R_INPUT);
- input5->key = "transmissivitysingleway";
+ input5->key = "transmissivity_singleway";
input5->description =
_("Name of single-way transmissivity raster map [0.0-1.0]");
input6 = G_define_standard_option(G_OPT_R_INPUT);
- input6->key = "wateravailability";
+ input6->key = "water_availability";
input6->description =
_("Value of water availability raster map [0.0-1.0]");
Modified: grass/trunk/imagery/i.evapo.mh/main.c
--- grass/trunk/imagery/i.evapo.mh/main.c 2014-11-26 23:20:48 UTC (rev 63169)
+++ grass/trunk/imagery/i.evapo.mh/main.c 2014-11-26 23:20:52 UTC (rev 63170)
@@ -74,19 +74,19 @@
/* Define different options */
input_RNET = G_define_standard_option(G_OPT_R_INPUT);
- input_RNET->key = "netradiationdiurnal";
+ input_RNET->key = "netradiation_diurnal";
input_RNET->description = _("Name of input diurnal net radiation raster map [W/m2/d]");
input_TEMPKAVG = G_define_standard_option(G_OPT_R_INPUT);
- input_TEMPKAVG->key = "averagetemperature";
+ input_TEMPKAVG->key = "average_temperature";
input_TEMPKAVG->description = _("Name of input average air temperature raster map [C]");
input_TEMPKMIN = G_define_standard_option(G_OPT_R_INPUT);
- input_TEMPKMIN->key = "minimumtemperature";
+ input_TEMPKMIN->key = "minimum_temperature";
input_TEMPKMIN->description = _("Name of input minimum air temperature raster map [C]");
input_TEMPKMAX = G_define_standard_option(G_OPT_R_INPUT);
- input_TEMPKMAX->key = "maximumtemperature";
+ input_TEMPKMAX->key = "maximum_temperature";
input_TEMPKMAX->description = _("Name of input maximum air temperature raster map [C]");
input_P = G_define_standard_option(G_OPT_R_INPUT);
Modified: grass/trunk/imagery/i.evapo.pt/main.c
--- grass/trunk/imagery/i.evapo.pt/main.c 2014-11-26 23:20:48 UTC (rev 63169)
+++ grass/trunk/imagery/i.evapo.pt/main.c 2014-11-26 23:20:52 UTC (rev 63170)
@@ -71,23 +71,23 @@
- input_RNET->key = "netradiation";
+ input_RNET->key = "net_radiation";
input_RNET->description = _("Name of input net radiation raster map [W/m2]");
input_G0 = G_define_standard_option(G_OPT_R_INPUT);
- input_G0->key = "soilheatflux";
+ input_G0->key = "soil_heatflux";
input_G0->description = _("Name of input soil heat flux raster map [W/m2]");
input_TEMPKA = G_define_standard_option(G_OPT_R_INPUT);
- input_TEMPKA->key = "airtemperature";
+ input_TEMPKA->key = "air_temperature";
input_TEMPKA->description = _("Name of input air temperature raster map [K]");
input_PATM = G_define_standard_option(G_OPT_R_INPUT);
- input_PATM->key = "atmosphericpressure";
+ input_PATM->key = "atmospheric_pressure";
input_PATM->description = _("Name of input atmospheric pressure raster map [millibars]");
input_PT = G_define_option();
- input_PT->key = "priestleytaylorcoef";
+ input_PT->key = "priestley_taylor_coef";
input_PT->type = TYPE_DOUBLE;
input_PT->required = YES;
input_PT->description = _("Priestley-Taylor coefficient");
Modified: grass/trunk/raster/r.to.rast3/main.c
--- grass/trunk/raster/r.to.rast3/main.c 2014-11-26 23:20:48 UTC (rev 63169)
+++ grass/trunk/raster/r.to.rast3/main.c 2014-11-26 23:20:52 UTC (rev 63170)
@@ -76,7 +76,7 @@
void set_params()
param.input = G_define_standard_option(G_OPT_R_INPUTS);
- param.input->description = _("2d raster maps which represent the slices");
+ param.input->description = _("2D raster maps which represent the slices");
param.output = G_define_standard_option(G_OPT_R3_OUTPUT);
@@ -223,11 +223,11 @@
rows = Rast_window_rows();
cols = Rast_window_cols();
- G_debug(2, "Check the 2d and 3d region settings");
+ G_debug(2, "Check the 2D and 3D region settings");
/*If not equal, set the 2D windows correct */
if (rows != region.rows || cols != region.cols) {
- G_message(_("The 2D and 3D region settings are different. I will use the 3D region settings to adjust the 2D region."));
+ G_message(_("The 2D and 3D region settings are different. Using the 3D region settings to adjust the 2D region."));
G_get_set_window(&window2d);
window2d.ns_res = region.ns_res;
window2d.ew_res = region.ew_res;
Modified: grass/trunk/raster3d/r3.gradient/main.c
--- grass/trunk/raster3d/r3.gradient/main.c 2014-11-26 23:20:48 UTC (rev 63169)
+++ grass/trunk/raster3d/r3.gradient/main.c 2014-11-26 23:20:52 UTC (rev 63170)
@@ -56,7 +56,7 @@
output_opt->description = _("Name for output 3D raster map(s)");
block_opt = G_define_option();
- block_opt->key = "block_size";
+ block_opt->key = "blocksize";
block_opt->multiple = TRUE;
block_opt->answer = "30,30,20"; /* based on testing */
block_opt->key_desc = "size_x,size_y,size_z";
Modified: grass/trunk/raster3d/r3.gradient/r3.gradient.html
--- grass/trunk/raster3d/r3.gradient/r3.gradient.html 2014-11-26 23:20:48 UTC (rev 63169)
+++ grass/trunk/raster3d/r3.gradient/r3.gradient.html 2014-11-26 23:20:52 UTC (rev 63170)
@@ -1,11 +1,14 @@
<h2>DESCRIPTION</h2>
-Module <em>r3.gradient</em> computes gradient from a 3D raster map.
-Results are three 3D raster maps describing the x, y, z components of the computed gradient field.
+Module <em>r3.gradient</em> computes gradient from a 3D raster map.
+Results are three 3D raster maps describing the x, y, z components of
+the computed gradient field.
<h2>EXAMPLES</h2>
<div class="code"><pre>
# create a 3D raster
-g.region s=0 n=100 w=0 e=100 b=0 t=100
+g.region s=0 n=100 w=0 e=100 b=0 t=100 -p
r3.mapcalc "test_gradient = sqrt(row()*row() +col()*col()+ depth()*depth())"
# compute gradient
@@ -13,13 +16,16 @@
</pre></div>
<h2>SEE ALSO</h2>
<em>
<a href="r3.flow.html">r3.flow</a>,
<a href="r.flow.html">r.flow</a>
</em>
<h2>AUTHORS</h2>
-Anna Petrasova, <a href="http://geospatial.ncsu.edu/osgeorel/">NCSU OSGeoREL</a>, developed during GSoC 2014.
+Anna Petrasova, <a href="http://geospatial.ncsu.edu/osgeorel/">NCSU OSGeoREL</a>,
+developed during GSoC 2014.
<p>
<i>Last changed: $Date$</i>
Modified: grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py
--- grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py 2014-11-26 23:20:48 UTC (rev 63169)
+++ grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py 2014-11-26 23:20:52 UTC (rev 63170)
@@ -40,7 +40,7 @@
#%option
#% key: basename
#% type: string
-#% description: Base name of the new created 3D raster maps
+#% description: Basename of the new generated 3D raster maps
#% required: no
#% multiple: no
#%end
Modified: grass/trunk/vector/v.mkgrid/main.c
--- grass/trunk/vector/v.mkgrid/main.c 2014-11-26 23:20:48 UTC (rev 63169)
+++ grass/trunk/vector/v.mkgrid/main.c 2014-11-26 23:20:52 UTC (rev 63170)
@@ -99,12 +99,7 @@
_("use 'coor' and 'box' options"));
position_opt->descriptions = desc;
- coord = G_define_option();
- coord->key = "coor";
- coord->key_desc = "x,y";
- coord->type = TYPE_DOUBLE;
- coord->required = NO;
- coord->multiple = NO;
+ coord = G_define_standard_option(G_OPT_M_COORDS);
coord->description =
_("Lower left easting and northing coordinates of map");
Modified: grass/trunk/vector/v.surf.rst/main.c
--- grass/trunk/vector/v.surf.rst/main.c 2014-11-26 23:20:48 UTC (rev 63169)
+++ grass/trunk/vector/v.surf.rst/main.c 2014-11-26 23:20:52 UTC (rev 63170)
@@ -221,7 +221,7 @@
parm.mcurv->guisection = _("Outputs");
parm.devi = G_define_standard_option(G_OPT_V_OUTPUT);
- parm.devi->key = "devi";
+ parm.devi->key = "deviations";
parm.devi->required = NO;
parm.devi->description = _("Name for output deviations vector point map");
parm.devi->guisection = _("Outputs");
Modified: grass/trunk/vector/v.vol.rst/main.c
--- grass/trunk/vector/v.vol.rst/main.c 2014-11-26 23:20:48 UTC (rev 63169)
+++ grass/trunk/vector/v.vol.rst/main.c 2014-11-26 23:20:52 UTC (rev 63170)
@@ -286,7 +286,7 @@
parm.wheresql = G_define_standard_option(G_OPT_DB_WHERE);
