[GRASS-SVN] r63198 - in grass/branches/releasebranch_7_0: . scripts/i.pansharpen scripts/r.blend scripts/r.rgb
Thu Nov 27 06:36:37 PST 2014
Author: martinl
Date: 2014-11-27 06:36:37 -0800 (Thu, 27 Nov 2014)
New Revision: 63198
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.py
   grass/branches/releasebranch_7_0/scripts/r.blend/r.blend.py
   grass/branches/releasebranch_7_0/scripts/r.rgb/r.rgb.py
fix script to use G_OPT_R_BASENAME_OUTPUT
    (merge r63196 from trunk)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,63089,63091,
 63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63165,63170,63175,63187
   + /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,63089,63091,
 63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63165,63170,63175,63187,63192-63193,63196
Modified: grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.py
--- grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.py	2014-11-27 14:35:12 UTC (rev 63197)
+++ grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.py	2014-11-27 14:36:37 UTC (rev 63198)
@@ -100,7 +100,7 @@
     ms2       = options['green'] # green channel
     ms3       = options['red'] # red channel
     pan       = options['pan'] # high res pan channel
-    out       = options['basename'] # prefix for output RGB maps
+    out       = options['output'] # prefix for output RGB maps
     bladjust  = flags['l'] # adjust blue channel
     sproc     = flags['s'] # serial processing
Modified: grass/branches/releasebranch_7_0/scripts/r.blend/r.blend.py
--- grass/branches/releasebranch_7_0/scripts/r.blend/r.blend.py	2014-11-27 14:35:12 UTC (rev 63197)
+++ grass/branches/releasebranch_7_0/scripts/r.blend/r.blend.py	2014-11-27 14:36:37 UTC (rev 63198)
@@ -52,7 +52,7 @@
 def main():
     first = options['first']
     second = options['second']
-    output = options['output_prefix']
+    output = options['output']
     percent = options['percent']
     mapset = grass.gisenv()['MAPSET']
Modified: grass/branches/releasebranch_7_0/scripts/r.rgb/r.rgb.py
--- grass/branches/releasebranch_7_0/scripts/r.rgb/r.rgb.py	2014-11-27 14:35:12 UTC (rev 63197)
+++ grass/branches/releasebranch_7_0/scripts/r.rgb/r.rgb.py	2014-11-27 14:36:37 UTC (rev 63198)
@@ -30,7 +30,7 @@
 def main():
     input = options['input']
-    output = options['basename']
     if not grass.find_file(input)['file']:
 	grass.fatal(_("Raster map <%s> not found") % input)
