[GRASS-SVN] r63204 - in grass/trunk/gui/wxpython: mapdisp vdigit
Thu Nov 27 07:27:32 PST 2014
Author: annakrat
Date: 2014-11-27 07:27:32 -0800 (Thu, 27 Nov 2014)
New Revision: 63204
   grass/trunk/gui/wxpython/mapdisp/main.py
   grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.py
wxGUI/vdigit: fix closing digitizer window problem due to not implemented giface progressbar interface
Modified: grass/trunk/gui/wxpython/mapdisp/main.py
--- grass/trunk/gui/wxpython/mapdisp/main.py	2014-11-27 15:22:50 UTC (rev 63203)
+++ grass/trunk/gui/wxpython/mapdisp/main.py	2014-11-27 15:27:32 UTC (rev 63204)
@@ -334,7 +334,10 @@
     def GetMapWindow(self):
         return self._mapframe.GetMapWindow()
+    def GetProgress(self):
+        return self._mapframe.GetProgressBar()
 class DMonFrame(MapFrame):
     def OnZoomToMap(self, event):
         layers = self.MapWindow.GetMap().GetListOfLayers()
Modified: grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.py
--- grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.py	2014-11-27 15:22:50 UTC (rev 63203)
+++ grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.py	2014-11-27 15:27:32 UTC (rev 63204)
@@ -43,7 +43,7 @@
 from core.globalvar import CheckWxVersion
 from core.utils import _, GuiModuleMain
 from mapdisp.frame import MapFrame
-from core.giface import StandaloneGrassInterface
+from mapdisp.main import DMonGrassInterface
 from core.settings import UserSettings
 from vdigit.main import haveVDigit, errorMsg
 from grass.exceptions import CalledModuleError
@@ -51,9 +51,10 @@
 class VDigitMapFrame(MapFrame):
     def __init__(self, vectorMap):
-        MapFrame.__init__(self, parent = None, giface = StandaloneGrassInterface(),
+        MapFrame.__init__(self, parent = None, giface = DMonGrassInterface(None),
                           title = _("GRASS GIS Vector Digitizer"), size = (850, 600))
+        # this giface issue not solved yet, we must set mapframe aferwards
+        self._giface._mapframe = self
         # load vector map
         mapLayer = self.GetMap().AddLayer(ltype = 'vector',
                                           command = ['d.vect', 'map=%s' % vectorMap],
