[GRASS-SVN] r63208 - grass/trunk/lib/python/pygrass/modules/interface
Thu Nov 27 08:20:32 PST 2014
Author: zarch
Date: 2014-11-27 08:20:32 -0800 (Thu, 27 Nov 2014)
New Revision: 63208
   grass/trunk/lib/python/pygrass/modules/interface/module.py
pygrass: disable mdebug decorator
Modified: grass/trunk/lib/python/pygrass/modules/interface/module.py
--- grass/trunk/lib/python/pygrass/modules/interface/module.py	2014-11-27 16:18:48 UTC (rev 63207)
+++ grass/trunk/lib/python/pygrass/modules/interface/module.py	2014-11-27 16:20:32 UTC (rev 63208)
@@ -67,7 +67,7 @@
     number of parallel processes it will wait for all processes to finish,
     sets the stdout and stderr of the Module object and removes it
     from the queue when its finished.
     To finish the queue before the maximum number of parallel
     processes was reached call wait() .
@@ -77,13 +77,13 @@
     Usage:
     Check with a queue size of 3 and 5 processes
     >>> import copy
     >>> from grass.pygrass.modules import Module, ParallelModuleQueue
     >>> mapcalc_list = []
     Setting run_ to False is important, otherwise a parallel processing is not possible
     >>> mapcalc = Module("r.mapcalc", overwrite=True, run_=False)
     >>> queue = ParallelModuleQueue(nprocs=3)
     >>> for i in xrange(5):
@@ -105,7 +105,7 @@
     0
     Check with a queue size of 8 and 5 processes
     >>> queue = ParallelModuleQueue(nprocs=8)
     >>> mapcalc_list = []
     >>> for i in xrange(5):
@@ -127,7 +127,7 @@
     0
     Check with a queue size of 8 and 4 processes
     >>> mapcalc_list = []
     >>> new_mapcalc = copy.deepcopy(mapcalc)
@@ -257,11 +257,11 @@
         :returns: the number fo Module processes running/finished in the queue
-        return self._proc_count
+        return self._proc_count
     def get_max_num_procs(self):
         """Return the maximum number of parallel Module processes
         :returns: the maximum number of parallel Module processes
         return self._num_procs
@@ -697,7 +697,7 @@
                 args.append(str(self.flags[flg]))
         return args
-    @mdebug(1, extra=_get_bash)
+    # @mdebug(1, extra=_get_bash)
     def run(self):
         """Run the module
@@ -711,6 +711,7 @@
         termination. The handling of stdout and stderr must then be done
         outside of this function.
+        get_msgr().debug(1, self.get_bash())
         if self.inputs['stdin'].value:
             self.stdin = self.inputs['stdin'].value
             self.stdin_ = PIPE
