[GRASS-SVN] r63210 - in grass/branches/releasebranch_7_0: . lib/gis
svn_grass at osgeo.org
Thu Nov 27 09:20:36 PST 2014
Author: martinl
Date: 2014-11-27 09:20:36 -0800 (Thu, 27 Nov 2014)
New Revision: 63210
Added:
grass/branches/releasebranch_7_0/lib/gis/renamed_options
grass/branches/releasebranch_7_0/lib/gis/Makefile
grass/branches/releasebranch_7_0/lib/gis/parser.c
grass/branches/releasebranch_7_0/lib/gis/parser_local_proto.h
add oldkey:newkey lookup table (#2049)
(merge r63209 from trunk)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,63089,63091,
63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63165,63170,63175,63187,63192-63193,63196
+ /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,63089,63091,
63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63165,63170,63175,63187,63192-63193,63196,63200,63202,63209
Modified: grass/branches/releasebranch_7_0/lib/gis/Makefile
--- grass/branches/releasebranch_7_0/lib/gis/Makefile 2014-11-27 17:05:44 UTC (rev 63209)
+++ grass/branches/releasebranch_7_0/lib/gis/Makefile 2014-11-27 17:20:36 UTC (rev 63210)
@@ -20,7 +20,7 @@
COLORSRC := $(filter-out colors/CVS,$(wildcard colors/[abcdefghijklmnopqrstuvwxyz]*))
COLORFILES := $(patsubst colors/%,$(ETC)/colors/%,$(COLORSRC))
-default: lib $(FMODE_OBJ) $(PROJFILES) $(COLORFILES) $(ETC)/colors.desc
+default: lib $(FMODE_OBJ) $(PROJFILES) $(COLORFILES) $(ETC)/colors.desc $(ETC)/renamed_options
ifdef MINGW
$(FMODE_OBJ): $(OBJDIR)/fmode.o
Modified: grass/branches/releasebranch_7_0/lib/gis/parser.c
--- grass/branches/releasebranch_7_0/lib/gis/parser.c 2014-11-27 17:05:44 UTC (rev 63209)
+++ grass/branches/releasebranch_7_0/lib/gis/parser.c 2014-11-27 17:20:36 UTC (rev 63210)
@@ -1,5 +1,5 @@
- * \file gis/parser.c
+ * \file lib/gis/parser.c
* \brief GIS Library - Argument parsing functions.
@@ -64,7 +64,7 @@
* that the "map" option is required and also that the number 12 is
* out of range. The acceptable range (or list) will be printed.
- * (C) 2001-2009, 2011 by the GRASS Development Team
+ * (C) 2001-2014 by the GRASS Development Team
* This program is free software under the GNU General Public License
* (>=v2). Read the file COPYING that comes with GRASS for details.
@@ -119,6 +119,7 @@
static void split_gisprompt(const char *, char *, char *, char *);
static void module_gui_wx(void);
static void append_error(const char *);
+static const char *get_renamed_option(const char *);
* \brief Disables the ability of the parser to operate interactively.
@@ -985,13 +986,32 @@
return;
+ /* First, check if key has been renamed in GRASS 7 */
+ if (found == 0) {
+ const char *renamed_key = NULL;
+ renamed_key = get_renamed_option(the_key);
+ if (renamed_key) {
+ for (at_opt = &st->first_option; at_opt; at_opt = at_opt->next_opt) {
+ if (strcmp(renamed_key, at_opt->key) == 0) {
+ G_warning(_("Please update the interface of the module: "
+ "option <%s> has been renamed to <%s>"),
+ the_key, renamed_key);
+ opt = at_opt;
+ found = 1;
+ break;
/* If there is no match, complain */
if (found == 0) {
- G_asprintf(&err, _("Sorry, <%s> is not a valid parameter"), the_key);
- append_error(err);
- return;
+ G_asprintf(&err, _("Sorry, <%s> is not a valid parameter"), the_key);
+ append_error(err);
+ return;
/* Allocate memory where answer is stored */
if (opt->count++) {
if (!opt->multiple) {
@@ -1463,6 +1483,35 @@
st->error[st->n_errors++] = G_store(msg);
+const char *get_renamed_option(const char *key)
+ const char *pgm, *key_new;
+ char *pgm_key;
+ if (!st->renamed_options) {
+ /* read renamed options from file (renamed_options) */
+ char path[GPATH_MAX];
+ G_snprintf(path, GPATH_MAX, "%s/etc/renamed_options", G_gisbase());
+ st->renamed_options = G_read_key_value_file(path);
+ /* try to check global changes first */
+ key_new = G_find_key_value(key, st->renamed_options);
+ if (key_new)
+ return key_new;
+ /* then check module-relevant changes */
+ pgm = G_program_name();
+ pgm_key = (char *) G_malloc (strlen(pgm) + strlen(key) + 2);
+ G_asprintf(&pgm_key, "%s|%s", pgm, key);
+ key_new = G_find_key_value(pgm_key, st->renamed_options);
+ G_free(pgm_key);
+ return key_new;
\brief Get separator string from the option.
Modified: grass/branches/releasebranch_7_0/lib/gis/parser_local_proto.h
--- grass/branches/releasebranch_7_0/lib/gis/parser_local_proto.h 2014-11-27 17:05:44 UTC (rev 63209)
+++ grass/branches/releasebranch_7_0/lib/gis/parser_local_proto.h 2014-11-27 17:20:36 UTC (rev 63210)
@@ -39,6 +39,8 @@
char **error;
int n_errors;
+ struct Key_Value *renamed_options;
extern struct state *st;
Copied: grass/branches/releasebranch_7_0/lib/gis/renamed_options (from rev 63209, grass/trunk/lib/gis/renamed_options)
--- grass/branches/releasebranch_7_0/lib/gis/renamed_options (rev 0)
+++ grass/branches/releasebranch_7_0/lib/gis/renamed_options 2014-11-27 17:20:36 UTC (rev 63210)
@@ -0,0 +1,487 @@
+### Renamed options in GRASS 7.0
+### Global
+fs:separator
+nv:null_value
+dt:dtime
+dp:precision
+### Display module changes
+# d.barscale
+d.barscale|background_color:bgcolor
+# d.correlate
+d.correlate|layers:map
+# d.erase
+d.erase|background:bgcolor
+# d.legend
+d.legend|map:rast
+# d.rast
+d.rast|catlist:values
+d.rast|vallist:values
+# d.rast.leg
+d.rast.leg|rast:raster
+# d.vect
+d.vect|wcolumn:width_column
+d.vect|wscale:width_scale
+d.vect|rot_column:rotation_column
+d.vect|attrcolumn:attribute_column
+# d.colortable
+d.colortable|cols:columns
+# d.geodetic
+d.geodetic|lcolor:line_color
+d.geodetic|tcolor:text_color
+# d.grid
+d.grid|bordercolor:border_color
+d.grid|textcolor:text_color
+# d.polar
+d.polar|eps:output
+# d.profile
+d.profile|input:map
+d.profile|profile:coordinates
+# d.rast.arrow
+d.rast.arrow|arrow_color:color
+d.rast.arrow|x_color:null_color
+# d.rhumbline
+d.rhumbline|coord:coordinates
+d.rhumbline|lcolor:line_color
+# d.vect
+d.vect|fcolor:fill_color
+d.vect|llayer:label_layer
+d.vect|lcolor:label_color
+d.vect|bgcolor:label_bgcolor
+d.vect|bcolor:label_boundary_color
+d.vect|lsize:label_size
+# d.thematic.area
+d.thematic.area|bcolor:boundary_color
+d.thematic.area|bwidth:boundary_width
+# d.vect.chart
+d.vect.chart|ctype:chart_type
+d.vect.chart|ocolor:outline_color
+d.vect.chart|sizecol:size_column
+### Database management module changes
+# db.out.ogr
+db.out.ogr|db_table:table
+# db.select
+db.select|vs:vertical_separator
+### General map management module changes
+# g.mapsets
+g.mapsets|addmapset:operation
+g.mapsets|removemapset:operation
+g.mapsets|measure:method
+# g.pnmcomp
+g.pnmcomp|background:bgcolor
+# g.mapset
+g.mapset|gisdbase:dbase
+### Image processing module changes
+# i.atcorr
+i.atcorr|iimg:input
+i.atcorr|iscl:range
+i.atcorr|ialt:elevation
+i.atcorr|ivis:visibility
+i.atcorr|icnd:parameters
+i.atcorr|oimg:output
+i.atcorr|oscl:rescale
+i.atcorr|input:map
+# i.biomass
+i.biomass|lightuseefficiency:lightuse_efficiency
+i.biomass|transmissivitysingleway:transmissivity_singleway
+i.biomass|wateravailability:water_availability
+# i.evapo.mh
+i.evapo.mh|averagetemperature:average_temperature
+i.evapo.mh|maximumtemperature:maximum_temperature
+i.evapo.mh|minimumtemperature:minimum_temperature
+i.evapo.mh|netradiationdiurnal:netradiation_diurnal
+# i.evapo.pt
+i.evapo.pt|airtemperature:air_temperature
+i.evapo.pt|atmosphericpressure:atmospheric_pressure
+i.evapo.pt|netradiation:net_radiation
+i.evapo.pt|soilheatflux:soil_heatflux
+i.evapo.pt|priestley_taylor_coef:priestley_taylor_coef
+# i.image.mosaic
+i.image.mosaic|images:input
+# i.in.spotvgt
+i.in.spotvgt|file:input
+i.in.spotvgt|rast:output
+# i.maxlik
+i.maxlik|sigfile:signaturefile
+i.maxlik|class:output
+# i.spectral
+i.spectral|raster:input
+i.spectral|coord:coordinates
+# i.tasscap
+i.tasscap|outprefix:basename
+# i.pansharpen
+i.pansharpen|ms1:blue
+i.pansharpen|ms2:green
+i.pansharpen|ms3:red
+i.pansharpen|output_prefix:output
+i.pansharpen|sharpen:method
+# i.fft
+i.fft|input_image:input
+i.fft|real_image:real
+i.fft|imaginary_image:imaginary
+# i.his.rgb
+i.his.rgb|hue_input:hue
+i.his.rgb|intensity_input:intensity
+i.his.rgb|saturation_input:saturation
+i.his.rgb|red_output:red
+i.his.rgb|green_output:green
+i.his.rgb|blue_output:blue
+# i.fft
+i.fft|output_image:output
+# i.landsat.acca
+i.landsat.acca|input_prefix:input
+# i.landsat.toar
+i.landsat.toar|input_prefix:input
+i.landsat.toar|output_prefix:output
+# i.pca
+i.pca|output_prefix:output
+# i.rectify
+i.rectify|res:resolution
+# i.rgb.his
+i.rgb.his|red_input:red
+i.rgb.his|green_input:green
+i.rgb.his|blue_input:blue
+i.rgb.his|hue_output:hue
+i.rgb.his|intensity_output:intensity
+i.rgb.his|saturation_output:saturation
+# i.tasscap
+i.tasscap|sattelite:sensor
+# i.vi
+i.vi|chan5:band5
+i.vi|chan7:band7
+### Raster module changes
+# r.basins.fill
+r.basins.fill|c_map:cnetwork
+r.basins.fill|t_map:tnetwork
+r.basins.fill|result:output
+# r.blend
+r.blend|output:output_prefix
+# r.colors.stddev
+r.colors.stddev|input:map
+# r.cost
+r.cost|coordinate:start_coordinates
+# r.distance
+r.distance|maps:map
+# r.drain
+r.drain|voutput:vector_output
+r.drain|coordinates:start_coordinates
+r.drain|vector_points:start_points
+# r.fill.dir
+r.fill.dir|elevation:input
+r.fill.dir|depressionless:output
+r.fill.dir|outdir:direction
+r.fill.dir|type:format
+# r.flow
+r.flow|elevin:elevation
+r.flow|aspin:aspect
+r.flow|barin:barrier
+r.flow|flout:flowline
+r.flow|lgout:flowpath
+r.flow|dsout:density
+# r.horizon
+r.horizon|elevin:elevation
+r.horizon|horizonstep:step
+# r.in.wms
+r.in.wms|mapserver:url
+# r.lake
+r.lake|wl:water_level
+r.lake|xy:coordinates
+# r.li.*
+r.li.*|map:input
+# r.los
+r.los|coodinate:coordinates
+# r.plane
+r.plane|name:output
+# r.resamp.bspline
+r.resamp.bspline|se:ew_step
+r.resamp.bspline|sn:ns_step
+# r.sim.sediment
+r.sim.sediment|elevin:elevation
+r.sim.sediment|dxin:dx
+r.sim.sediment|dyin:dy
+r.sim.sediment|detin:det
+r.sim.sediment|tranin:tran
+r.sim.sediment|tauin:tau
+r.sim.sediment|manin:man
+r.sim.sediment|maninval:man_value
+# r.sim.water
+r.sim.water|elevin:elevation
+r.sim.water|dxin:dx
+r.sim.water|dyin:dy
+r.sim.water|rain_val:rain_value
+r.sim.water|infil:infil
+r.sim.water|infil_val:infil_value
+r.sim.water|manin:man
+r.sim.water|manin_val:man_value
+# r.sun
+r.sun|elevin:elevation
+r.sun|aspin:aspect
+r.sun|slopein:slope
+r.sun|linkein:linke
+r.sun|lin:linke_value
+r.sun|albin:albedo
+r.sun|alb:albedo_value
+r.sun|latin:lat
+r.sun|longin:long
+r.sun|coefbh:coef_bh
+r.sun|coefdh:coef_dh
+r.sun|horizonstep:horizon_step
+r.sun|declin:declination
+r.sun|dist:distance_step
+r.sun|numpartitions:num_partitions
+r.sun|civiltime:civil_time
+# r.surf.area
+r.surf.area|input:map
+# r.texture
+r.texture|measure:method
+# r.to.vect
+r.to.vect|feature:type
+# r.topmodel
+r.topmodel|elevation:
+r.topmodel|basin:
+r.topmodel|depressionless:
+r.topmodel|direction:
+r.topmodel|belevation:
+r.topmodel|nidxclass:ntopidxclasses
+r.topmodel|idxstats:topidxstats
+r.topmodel|idxclass:topidxclass
+r.topmodel|qobs:
+# r.uslek
+r.uslek|usle_k:output
+# r.walk
+r.walk|coordinate:start_coordinates
+# r.water.outlet
+r.water.outlet|drainage:input
+r.water.outlet|basin:output
+# r.watershed
+r.watershed|disturbed.land:disturbed_land
+r.watershed|half.basin:half_basin
+r.watershed|length.slope:length_slope
+r.watershed|slope.steepness:slope_steepness
+r.watershed|max.slope.length:max_slope_length
+# r.what
+r.what|east_north:coordinates
+# r.rgb:
+r.rgb:|output_prefix:output
+# r.blend
+r.blend|output_prefix:output
+# r.category
+r.category|vals:values
+# r.circle
+r.circle|coordinate:coordinates
+r.circle|mult:multiplier
+# r.coin
+r.coin|map1:first
+r.coin|map2:second
+# r.composite
+r.composite|lev_red:level_red
+r.composite|lev_green:level_green
+r.composite|lev_blue:level_blue
+# r.drain
+r.drain|indir:direction
+r.drain|vector_output:drain
+# r.fill.dir
+# r.horizon
+r.horizon|output:file
+r.horizon|basename:output
+r.horizon|coordinate:coordinates
+# r.out.mpeg
+r.out.mpeg|qual:quality
+# r.out.vrml
+r.out.vrml|elev:elevation
+r.out.vrml|exag:exaggeration
+# r.param.scale
+r.param.scale|s_tol:slope_tol
+r.param.scale|c_tol:curvature_tol
+r.param.scale|exp:exponent
+# r.random
+r.random|raster_output:raster
+r.random|vector_output:vector
+# r.reclass.area
+r.reclass.area|lesser,greater:value, mode
+# r.report
+r.report|pl:page_length
+r.report|pw:page_width
+r.report|null:null_value
+# r.resamp.rst
+r.resamp.rst|elev:elevation
+r.resamp.rst|pcurv:pcurvature
+r.resamp.rst|mcurv:mcurvature
+r.resamp.rst|tcurv:trucravture
+r.resamp.rst|zmult:zmultiplier
+# r.slope.aspect
+r.slope.aspect|pcurv:pcurvature
+r.slope.aspect|tcurv:tcurvature
+r.slope.aspect|zfactor:zmultiplier
+r.slope.aspect|min_slp_allowed:min_slope
+# r.spreadpath
+r.spreadpath|coordinate:coordinates
+# r.terraflow
+r.terraflow|stream_dir:directory
+# r.out.vtk
+r.out.vtk|elevscale:zmultiplier
+### Raster 3D module changes
+# r3.gwflow
+r3.gwflow|q:sink
+r3.gwflow|s:yield
+r3.gwflow|r:recharge
+r3.gwflow|vx:velocity_x
+r3.gwflow|vy:velocity_y
+r3.gwflow|vz:velocity_z
+# r3.out.ascii
+r3.out.ascii|null:null_value
+# r3.out.vtk
+r3.out.vtk|elevscale:zmultiplier
+### Vector module changes
+# v.clean
+v.clean|thresh:threshold
+# v.drape
+v.drape|rast:elevation
+# v.edit
+v.edit|measure:method
+v.edit|thresh:threshold
+# v.extract
+v.extract|list:cats
+# v.in.e00
+v.in.e00|file:input
+v.in.e00|vect:output
+# v.in.gns
+v.in.gns|file:input
+v.in.gns|vect:output
+# v.in.wfs
+v.in.wfs|wfs:url
+v.in.wfs|input:map
+# v.lrs.create
+v.lrs.create|thresh:threshold
+# v.lrs.where
+v.lrs.where|thresh:threshold
+# v.mkgrid
+v.mkgrid|coor:coordinates
+# v.net
+v.net|thresh:threshold
+# v.outlier
+v.outlier|soe:ew_step
+v.outlier|son:ns_step
+# v.rast.stats
+v.rast.stats|colprefix:column_prefix
+v.rast.stats|input:map
+# v.support
+v.support|thresh:threshold
+# v.surf.bspline
+v.surf.bspline|sie:ew_step
+v.surf.bspline|sin:ns_step
+# v.surf.rst
+v.surf.rst|devi:deviations
+v.surf.rst|maskmap:mask
+v.surf.rst|treefile:treeseg
+v.surf.rst|overfile:overwin
+v.surf.rst|elev:elevation
+# v.what.vect
+v.what.vect|vector:map
+v.what.vect|qvector:query_map
+v.what.vect|qlayer:query_layer
+v.what.vect|qcolumn:query_column
+# v.label
+v.label|background:bgcolor
+# v.lrs.label
+v.lrs.label|background:bgcolor
+# v.buffer
+v.buffer|bufcolumn:column
+# v.db.join
+v.db.join|otable:other_table
+v.db.join|ocolumn:other_column
+v.db.join|scolumns:subset_columns
+# v.db.select
+v.db.select|vs:vertical separator
+# v.db.update
+v.db.update|qcolumn:query_column
+# v.extrude
+v.extrude|hcolumn:height_column
+# v.kcv
+v.kcv|k:npartitions
+# v.kernel
+v.kernel|mult:multiplier
+# v.out.ogr
+v.out.ogr|dsn:output
+v.out.ogr|olayer:output_layer
+v.out.ogr|otype:output_type
+# v.out.postgis
+v.out.postgis|dsn:output
+v.out.postgis|olayer:output_layer
+v.out.postgis|olink:output_link
+# v.out.vtk
+v.out.vtk|scale:zmultiplier
+# v.qcount
+v.qcount|n:nquadrants
+v.qcount|r:radius
+# v.sample
+v.sample|z:zmultiplier
+# v.segments
+v.segments|file:segments
+# v.surf.rst
+v.surf.rst|pcurv:pcurvature
+v.surf.rst|tcurv:tcurvature
+v.surf.rst|mcurv:mcurvature
+v.surf.rst|scolumn:smooth_column
+v.surf.rst|zmulti:zmultiplier
+# v.to.db
+v.to.db|qlayer:query_layer
+v.to.db|qcolumn:query_column
+# v.to.points
+v.to.points|llayer:layer
+# v.transform
+v.transform|attrcolumn:attribute_column
+v.transform|rgbcolumn:rgb_column
+v.transform|labelcolumn:label_column
+# v.transform
+v.transform|zrot:zrotation
+# v.vect.stats
+v.vect.stats|player:points_layer
+v.vect.stats|alayer:areas_layer
+v.vect.stats|pcolumn:points_column
+v.vect.stats|ccolumn:count_column
+v.vect.stats|scolumn:stats_column
+# v.vol.rst
+v.vol.rst|cellinp:cross_input
+v.vol.rst|devi:deviations
+v.vol.rst|scolumn:smooth_column
+v.vol.rst|wmulti:wmultiplier
+v.vol.rst|zmulti:zmultiplier
+v.vol.rst|cellout:cross_output
+v.vol.rst|elev:elevation
+v.vol.rst|aspect1:aspect_horizontal
+v.vol.rst|aspect2:aspect_vertical
+v.vol.rst|ncurv:ncurvature
+v.vol.rst|gcurv:gcurvature
+v.vol.rst|mcurv:mcurvature
+# v.what.vect
+v.what.vect|qmap:query_map
+### Miscellaneous module changes
+# m.measure
+m.measure|coords:coordinates
+# m.cogo
+m.cogo|coords:coordinates
+# m.transform
+m.transform|coords:input
