[GRASS-SVN] r63215 - in grass/branches/releasebranch_7_0: . gui/wxpython/gui_core
svn_grass at osgeo.org
Thu Nov 27 18:33:39 PST 2014
Author: annakrat
Date: 2014-11-27 18:33:39 -0800 (Thu, 27 Nov 2014)
New Revision: 63215
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/gui/wxpython/gui_core/forms.py
wxGUI/forms: fix updating dependent widgets with wxPython 3 (merge from trunk, r63173, r63199)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,63089,63091,
63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63165,63170,63175,63187,63192-63193,63196,63200,63202,63209
+ /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62886,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,63089,
63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209
Modified: grass/branches/releasebranch_7_0/gui/wxpython/gui_core/forms.py
--- grass/branches/releasebranch_7_0/gui/wxpython/gui_core/forms.py 2014-11-27 18:02:47 UTC (rev 63214)
+++ grass/branches/releasebranch_7_0/gui/wxpython/gui_core/forms.py 2014-11-28 02:33:39 UTC (rev 63215)
@@ -1216,12 +1216,20 @@
# A gselect.Select is a combobox with two children: a textctl and a popupwindow;
# we target the textctl here
textWin = selection.GetTextCtrl()
- p['wxId'] = [ textWin.GetId(), ]
- textWin.Bind(wx.EVT_TEXT, self.OnSetValue)
+ if globalvar.CheckWxVersion([3]):
+ p['wxId'] = [selection.GetId(), ]
+ else:
+ p['wxId'] = [textWin.GetId(), ]
+ if prompt != 'vector':
+ self.FindWindowById(p['wxId'][0]).Bind(wx.EVT_TEXT, self.OnSetValue)
if prompt == 'vector':
- selection.Bind(wx.EVT_TEXT, self.OnUpdateSelection)
+ win = self.FindWindowById(p['wxId'][0])
+ # handlers should be bound in this order
+ # OnUpdateSelection depends on calling OnSetValue first which is bad
+ win.Bind(wx.EVT_TEXT, self.OnUpdateSelection)
+ win.Bind(wx.EVT_TEXT, self.OnSetValue)
# if formatSelector and p.get('age', 'old') == 'old':
# # OGR supported (read-only)
# self.hsizer = wx.BoxSizer(wx.HORIZONTAL)
