[GRASS-SVN] r63226 - in grass/trunk: general/g.list general/g.remove general/g.rename lib/manage raster/r.reclass
svn_grass at osgeo.org
Fri Nov 28 01:30:10 PST 2014
Author: martinl
Date: 2014-11-28 01:30:10 -0800 (Fri, 28 Nov 2014)
New Revision: 63226
grass/trunk/general/g.list/main.c
grass/trunk/general/g.remove/main.c
grass/trunk/general/g.rename/main.c
grass/trunk/lib/manage/do_copy.c
grass/trunk/lib/manage/do_remove.c
grass/trunk/lib/manage/do_rename.c
grass/trunk/lib/manage/option.c
grass/trunk/raster/r.reclass/reclass.c
fix managelib and modules to understand new element names
Modified: grass/trunk/general/g.list/main.c
--- grass/trunk/general/g.list/main.c 2014-11-28 09:19:18 UTC (rev 63225)
+++ grass/trunk/general/g.list/main.c 2014-11-28 09:30:10 UTC (rev 63226)
@@ -385,11 +385,11 @@
if ((list = G__ls(path, &count)) == NULL)
return;
- if (strcmp(alias, "rast") == 0)
+ if (strcmp(alias, "raster") == 0)
type = TYPE_RAST;
- else if (strcmp(alias, "rast3d") == 0)
+ else if (strcmp(alias, "3draster") == 0)
type = TYPE_RAST3D;
- else if (strcmp(alias, "vect") == 0)
+ else if (strcmp(alias, "vector") == 0)
type = TYPE_VECT;
else
type = TYPE_OTHERS;
Modified: grass/trunk/general/g.remove/main.c
--- grass/trunk/general/g.remove/main.c 2014-11-28 09:19:18 UTC (rev 63225)
+++ grass/trunk/general/g.remove/main.c 2014-11-28 09:30:10 UTC (rev 63226)
@@ -235,7 +235,7 @@
if (access(path, 0) != 0)
continue;
- rast = !G_strcasecmp(elem->alias, "rast");
+ rast = !G_strcasecmp(elem->alias, "raster");
files = G__ls(path, &num_files);
for (j = 0; j < num_files; j++) {
Modified: grass/trunk/general/g.rename/main.c
--- grass/trunk/general/g.rename/main.c 2014-11-28 09:19:18 UTC (rev 63225)
+++ grass/trunk/general/g.rename/main.c 2014-11-28 09:30:10 UTC (rev 63226)
@@ -93,7 +93,7 @@
result = EXIT_FAILURE;
- if (!renamed && strcmp(parm[n]->key, "rast") == 0 &&
+ if (!renamed && strcmp(parm[n]->key, "raster") == 0 &&
Rast_is_reclassed_to(old, mapset, &nrmaps, &rmaps) > 0) {
int ptr, l;
char buf1[256], buf2[256], buf3[256], *str;
Modified: grass/trunk/lib/manage/do_copy.c
--- grass/trunk/lib/manage/do_copy.c 2014-11-28 09:19:18 UTC (rev 63225)
+++ grass/trunk/lib/manage/do_copy.c 2014-11-28 09:30:10 UTC (rev 63226)
@@ -34,7 +34,7 @@
int M_do_copy(int n, const char *old, const char *mapset, const char *new)
- int i, ret, len;
+ int i, ret;
char path[GPATH_MAX], path2[GPATH_MAX];
int result = 0;
@@ -43,10 +43,8 @@
G_message(_("Copy %s <%s> to current mapset as <%s>"),
list[n].maindesc, G_fully_qualified_name(old, mapset), new);
- len = M__get_description_len(n);
M__hold_signals(1);
- if (G_strcasecmp(list[n].alias, "vect") == 0) {
+ if (G_strcasecmp(list[n].alias, "vector") == 0) {
ret = Vect_copy(old, mapset, new);
if (ret == -1) {
G_warning(_("Unable to copy <%s> to current mapset as <%s>"),
Modified: grass/trunk/lib/manage/do_remove.c
--- grass/trunk/lib/manage/do_remove.c 2014-11-28 09:19:18 UTC (rev 63225)
+++ grass/trunk/lib/manage/do_remove.c 2014-11-28 09:30:10 UTC (rev 63226)
@@ -52,7 +52,7 @@
old = xname;
if ((mapset = G_find_vector2(old, "")) == NULL) {
G_warning(_("Vector map <%s> not found"), old);
@@ -68,12 +68,12 @@
else {
- if (G_strcasecmp(list[n].alias, "rast") == 0) {
+ if (G_strcasecmp(list[n].alias, "raster") == 0) {
if ((mapset = G_find_raster2(old, "")) == NULL)
G_warning(_("Raster map <%s> not found"), old);
- if (G_strcasecmp(list[n].alias, "rast3d") == 0) {
+ if (G_strcasecmp(list[n].alias, "3draster") == 0) {
if ((mapset = G_find_raster3d(old, "")) == NULL)
G_warning(_("3D raster map <%s> not found"), old);
Modified: grass/trunk/lib/manage/do_rename.c
--- grass/trunk/lib/manage/do_rename.c 2014-11-28 09:19:18 UTC (rev 63225)
+++ grass/trunk/lib/manage/do_rename.c 2014-11-28 09:30:10 UTC (rev 63226)
@@ -49,7 +49,7 @@
M__hold_signals(1);
@@ -66,12 +66,12 @@
else {
Modified: grass/trunk/lib/manage/option.c
--- grass/trunk/lib/manage/option.c 2014-11-28 09:19:18 UTC (rev 63225)
+++ grass/trunk/lib/manage/option.c 2014-11-28 09:30:10 UTC (rev 63226)
@@ -47,10 +47,11 @@
G_asprintf(&str, _("%s to be %s"),
list[n].text, desc);
p->description = str;
- if (strcmp(p->key, "rast") == 0 || strcmp(p->key, "rast3d") == 0)
+ if (strcmp(p->key, "raster") == 0 || strcmp(p->key, "3draster") == 0)
p->guisection = _("Raster");
- else if (strcmp(p->key, "vect") == 0 || strcmp(p->key, "oldvect") == 0 ||
- strcmp(p->key, "asciivect") == 0)
+ else if (strcmp(p->key, "vector") == 0 ||
+ strcmp(p->key, "oldvector") == 0 ||
+ strcmp(p->key, "asciivector") == 0)
p->guisection = _("Vector");
else if (strcmp(p->key, "region") == 0 || strcmp(p->key, "region3d") == 0)
p->guisection = _("Region");
Modified: grass/trunk/raster/r.reclass/reclass.c
--- grass/trunk/raster/r.reclass/reclass.c 2014-11-28 09:19:18 UTC (rev 63225)
+++ grass/trunk/raster/r.reclass/reclass.c 2014-11-28 09:30:10 UTC (rev 63226)
@@ -230,7 +230,7 @@
if (G_find_file2("cell", new_name, G_mapset()) &&
Rast_map_type(new_name, G_mapset()) != CELL_TYPE) {
M_read_list(FALSE, NULL);
- if (M_do_remove(M_get_element("rast"), new_name) == 1)
+ if (M_do_remove(M_get_element("raster"), new_name) == 1)
G_fatal_error(_("Cannot overwrite existing raster map <%s>"),
new_name);
