[GRASS-SVN] r63228 - grass/branches/releasebranch_7_0/gui/wxpython/iscatt
svn_grass at osgeo.org
Fri Nov 28 01:43:48 PST 2014
Author: turek
Date: 2014-11-28 01:43:48 -0800 (Fri, 28 Nov 2014)
New Revision: 63228
grass/branches/releasebranch_7_0/gui/wxpython/iscatt/controllers.py
iscatt: gThread class deleted, it was moved to core before
Modified: grass/branches/releasebranch_7_0/gui/wxpython/iscatt/controllers.py
--- grass/branches/releasebranch_7_0/gui/wxpython/iscatt/controllers.py 2014-11-28 09:43:14 UTC (rev 63227)
+++ grass/branches/releasebranch_7_0/gui/wxpython/iscatt/controllers.py 2014-11-28 09:43:48 UTC (rev 63228)
@@ -1111,99 +1111,3 @@
self.scatt_mgr.SetBands(bands)
-#TODO it uses also BufferedMapWindow class -> move to core?
-class gThread(threading.Thread, wx.EvtHandler):
- """Thread for scatter plot backend"""
- requestId = 0
- def __init__(self, requestQ=None, resultQ=None, **kwds):
- wx.EvtHandler.__init__(self)
- self.terminate = False
- threading.Thread.__init__(self, **kwds)
- if requestQ is None:
- self.requestQ = Queue.Queue()
- else:
- self.requestQ = requestQ
- if resultQ is None:
- self.resultQ = Queue.Queue()
- else:
- self.resultQ = resultQ
- self.setDaemon(True)
- self.Bind(EVT_CMD_DONE, self.OnDone)
- self.start()
- def Run(self, *args, **kwds):
- """Run command in queue
- :param args: unnamed command arguments
- :param kwds: named command arguments, keyword 'callable'
- represents function to be run, keyword 'ondone'
- represents function to be called after the
- callable is done
- :return: request id in queue
- gThread.requestId += 1
- self.requestQ.put((gThread.requestId, args, kwds))
- return gThread.requestId
- def GetId(self):
- """Get id for next command"""
- return gThread.requestId + 1
- def SetId(self, id):
- """Set starting id"""
- gThread.requestId = id
- def run(self):
- while True:
- requestId, args, kwds = self.requestQ.get()
- for key in ('callable', 'ondone', 'userdata'):
- if key in kwds:
- vars()[key] = kwds[key]
- del kwds[key]
- else:
- vars()[key] = None
- requestTime = time.time()
- ret = None
- exception = None
- time.sleep(.01)
- if self.terminate:
- return
- ret = vars()['callable'](*args, **kwds)
- return
- #except Exception as e:
- # exception = e;
- self.resultQ.put((requestId, ret))
- event = wxCmdDone(ondone=vars()['ondone'],
- kwds=kwds,
- args=args, #TODO expand args to kwds
- ret=ret,
- exception=exception,
- userdata=vars()['userdata'],
- pid=requestId)
- # send event
- wx.PostEvent(self, event)
- def OnDone(self, event):
- if event.ondone:
- event.ondone(event)
- def Terminate(self):
- """Abort command(s)"""
- self.terminate = True
