[GRASS-SVN] r63238 - in grass/trunk: db/drivers/sqlite scripts/v.db.update
svn_grass at osgeo.org
Fri Nov 28 02:15:16 PST 2014
Author: neteler
Date: 2014-11-28 02:15:16 -0800 (Fri, 28 Nov 2014)
New Revision: 63238
grass/trunk/db/drivers/sqlite/db.c
grass/trunk/scripts/v.db.update/v.db.update.html
grass/trunk/scripts/v.db.update/v.db.update.py
v.db.update: add support for extended SQLite functions
Modified: grass/trunk/db/drivers/sqlite/db.c
--- grass/trunk/db/drivers/sqlite/db.c 2014-11-28 10:10:56 UTC (rev 63237)
+++ grass/trunk/db/drivers/sqlite/db.c 2014-11-28 10:15:16 UTC (rev 63238)
@@ -110,6 +110,9 @@
return DB_FAILED;
+ /* enable loading of extensions */
+ sqlite3_enable_load_extension(sqlite, 1);
/* set the sqlite busy handler */
sqlite3_busy_handler(sqlite, sqlite_busy_callback, NULL);
Modified: grass/trunk/scripts/v.db.update/v.db.update.html
--- grass/trunk/scripts/v.db.update/v.db.update.html 2014-11-28 10:10:56 UTC (rev 63237)
+++ grass/trunk/scripts/v.db.update/v.db.update.html 2014-11-28 10:15:16 UTC (rev 63238)
@@ -14,6 +14,8 @@
<h2>EXAMPLES</h2>
+<h3>Replacing of NULL values</h3>
In this example, selectively display lakes without (blue) and with
NULL (red) are shown to find out which type is undefined. In the
original map there are lakes missing FTYPE attribute which are
@@ -37,7 +39,9 @@
v.db.select mylakes
</pre></div>
-Spearfish example: adding new column, copying values from other table
+<h3>Updating of columns with on the fly calculation</h3>
+Spearfish example: adding new column, copying values from another table
column with on the fly calculation:
<div class="code"><pre>
g.copy vect=fields,myfields
@@ -46,6 +50,8 @@
v.db.select myfields
</pre></div>
+<h3>Type casting</h3>
Type cast (type conversion) of strings to double precision
(unsupported by DBF driver):
@@ -54,7 +60,28 @@
where="z_value <> 'N/A'"
</pre></div>
+<h3>Updating of columns with on the fly calculation (SQLite extended functions)</h3>
+North Carolina data set example: adding new column, copying values from
+another table column with on the fly calculation:
+<div class="code"><pre>
+g.copy vect=precip_30ynormals,myprecip_30ynormals
+v.db.addcolumn myprecip_30ynormals column="logjuly double precision"
+v.db.update myprecip_30ynormals column="logjuly" qcolumn="log(jul)" \
+ sqliteextra=$HOME/sqlite_extensions/libsqlitefunctions.so
+v.db.select myprecip_30ynormals columns=jul,logjuly
+jul|logjuly
+132.842|4.88916045210132
+127|4.84418708645859
+124.206|4.82194147751127
+104.648|4.65060233738593
+98.298|4.58800368106618
+</pre></div>
<h2>SEE ALSO</h2>
<em>
Modified: grass/trunk/scripts/v.db.update/v.db.update.py
--- grass/trunk/scripts/v.db.update/v.db.update.py 2014-11-28 10:10:56 UTC (rev 63237)
+++ grass/trunk/scripts/v.db.update/v.db.update.py 2014-11-28 10:15:16 UTC (rev 63238)
@@ -43,6 +43,12 @@
#%end
#%option G_OPT_DB_WHERE
#%end
+#%option G_OPT_F_INPUT
+#% key: sqliteextra
+#% description: Name of SQLite extension file for extra functions (SQLite backend only)
+#% gisprompt: old,bin,file
+#% required: no
+#%end
import sys
import os
@@ -55,6 +61,7 @@
value = options['value']
qcolumn = options['query_column']
where = options['where']
+ sqlitefile = options['sqliteextra']
mapset = grass.gisenv()['MAPSET']
@@ -71,6 +78,13 @@
database = f['database']
driver = f['driver']
+ # check for SQLite backend for extra functions
+ if sqlitefile and driver != "sqlite":
+ grass.fatal(_("Use of libsqlitefunctions only with SQLite backend"))
+ if driver == "sqlite" and sqlitefile:
+ if not os.access(sqlitefile, os.R_OK):
+ grass.fatal(_("File <%s> not found") % sqlitefile)
# checking column types
try:
coltype = grass.vector_columns(vector, layer)[column]['type']
@@ -93,8 +107,12 @@
if where:
cmd += " WHERE " + where
+ # SQLite: preload extra functions from extension lib if provided by user
+ if sqlitefile:
+ sqliteload = "SELECT load_extension('%s');\n" % sqlitefile
+ cmd = sqliteload + cmd
grass.verbose("SQL: \"%s\"" % cmd)
grass.write_command('db.execute', input = '-', database = database, driver = driver, stdin = cmd)
# write cmd history:
