[GRASS-SVN] r63246 - in grass/trunk: lib/gis raster/r.resamp.rst raster/r.shaded.relief raster/r.slope.aspect raster3d/r3.out.vtk vector/v.out.vtk vector/v.sample vector/v.surf.rst vector/v.vol.rst
Fri Nov 28 06:45:21 PST 2014
Author: martinl
Date: 2014-11-28 06:45:21 -0800 (Fri, 28 Nov 2014)
New Revision: 63246
   grass/trunk/lib/gis/renamed_options
   grass/trunk/raster/r.resamp.rst/main.c
   grass/trunk/raster/r.shaded.relief/main.c
   grass/trunk/raster/r.slope.aspect/main.c
   grass/trunk/raster3d/r3.out.vtk/parameters.c
   grass/trunk/vector/v.out.vtk/main.c
   grass/trunk/vector/v.sample/main.c
   grass/trunk/vector/v.surf.rst/main.c
   grass/trunk/vector/v.vol.rst/main.c
rename zmultiplier to zscale (#2409)
Modified: grass/trunk/lib/gis/renamed_options
--- grass/trunk/lib/gis/renamed_options	2014-11-28 14:41:54 UTC (rev 63245)
+++ grass/trunk/lib/gis/renamed_options	2014-11-28 14:45:21 UTC (rev 63246)
@@ -335,18 +335,18 @@
 r.resamp.rst|pcurv:pcurvature
 r.resamp.rst|mcurv:mcurvature
 r.resamp.rst|tcurv:trucravture
-r.resamp.rst|zmult:zmultiplier
+r.resamp.rst|zmult:zscale
 # r.slope.aspect
 r.slope.aspect|pcurv:pcurvature
 r.slope.aspect|tcurv:tcurvature
-r.slope.aspect|zfactor:zmultiplier
+r.slope.aspect|zfactor:zscale
 r.slope.aspect|min_slp_allowed:min_slope
 # r.spreadpath
 r.spreadpath|coordinate:coordinates
 # r.terraflow
 r.terraflow|stream_dir:directory
 # r.out.vtk
-r.out.vtk|elevscale:zmultiplier
+r.out.vtk|elevscale:zscale
 ### Raster 3D module changes
@@ -360,7 +360,7 @@
 # r3.out.ascii
 r3.out.ascii|null:null_value
 # r3.out.vtk
-r3.out.vtk|elevscale:zmultiplier
+r3.out.vtk|elevscale:zscale
 ### Vector module changes
@@ -438,12 +438,12 @@
 v.out.postgis|olayer:output_layer
 v.out.postgis|olink:output_link
 # v.out.vtk
-v.out.vtk|scale:zmultiplier
+v.out.vtk|scale:zscale
 # v.qcount
 v.qcount|n:nquadrants
 v.qcount|r:radius
 # v.sample
-v.sample|z:zmultiplier
+v.sample|z:zscale
 # v.segment
 v.segment|file:segments
 # v.surf.rst
@@ -451,7 +451,7 @@
 v.surf.rst|tcurv:tcurvature
 v.surf.rst|mcurv:mcurvature
 v.surf.rst|scolumn:smooth_column
-v.surf.rst|zmulti:zmultiplier
+v.surf.rst|zmulti:zscale
 # v.to.db
 v.to.db|qlayer:query_layer
 v.to.db|qcolumn:query_column
@@ -474,7 +474,7 @@
 v.vol.rst|devi:deviations
 v.vol.rst|scolumn:smooth_column
 v.vol.rst|wmulti:wmultiplier
-v.vol.rst|zmulti:zmultiplier
+v.vol.rst|zmulti:zscale
 v.vol.rst|cellout:cross_output
 v.vol.rst|elev:elevation
 v.vol.rst|aspect1:aspect_horizontal
Modified: grass/trunk/raster/r.resamp.rst/main.c
--- grass/trunk/raster/r.resamp.rst/main.c	2014-11-28 14:41:54 UTC (rev 63245)
+++ grass/trunk/raster/r.resamp.rst/main.c	2014-11-28 14:45:21 UTC (rev 63246)
@@ -224,7 +224,7 @@
     parm.overlap->guisection = _("Settings");
     parm.zmult = G_define_option();
-    parm.zmult->key = "zmultiplier";
+    parm.zmult->key = "zscale";
     parm.zmult->type = TYPE_DOUBLE;
     parm.zmult->answer = ZMULT;
     parm.zmult->required = NO;
Modified: grass/trunk/raster/r.shaded.relief/main.c
--- grass/trunk/raster/r.shaded.relief/main.c	2014-11-28 14:41:54 UTC (rev 63245)
+++ grass/trunk/raster/r.shaded.relief/main.c	2014-11-28 14:45:21 UTC (rev 63246)
@@ -134,7 +134,7 @@
     parm.azimuth->guisection = _("Sun position");
     parm.zmult->answer = "1";
Modified: grass/trunk/raster/r.slope.aspect/main.c
--- grass/trunk/raster/r.slope.aspect/main.c	2014-11-28 14:41:54 UTC (rev 63245)
+++ grass/trunk/raster/r.slope.aspect/main.c	2014-11-28 14:45:21 UTC (rev 63246)
@@ -236,7 +236,7 @@
     parm.dxy->guisection = _("Outputs");
     parm.zfactor = G_define_option();
-    parm.zfactor->key = "zmultiplier";
+    parm.zfactor->key = "zscale";
     parm.zfactor->description =
 	_("Multiplicative factor to convert elevation units to meters");
     parm.zfactor->type = TYPE_DOUBLE;
Modified: grass/trunk/raster3d/r3.out.vtk/parameters.c
--- grass/trunk/raster3d/r3.out.vtk/parameters.c	2014-11-28 14:41:54 UTC (rev 63245)
+++ grass/trunk/raster3d/r3.out.vtk/parameters.c	2014-11-28 14:45:21 UTC (rev 63246)
@@ -88,7 +88,7 @@
 	_("Three (x,y,z) 3D raster maps to create vector values [xmap,ymap,zmap]");
     param.elevscale = G_define_option();
-    param.elevscale->key = "zmultiplier";
+    param.elevscale->key = "zscale";
     param.elevscale->type = TYPE_DOUBLE;
     param.elevscale->required = NO;
     param.elevscale->description = _("Scale factor for elevation");
Modified: grass/trunk/vector/v.out.vtk/main.c
--- grass/trunk/vector/v.out.vtk/main.c	2014-11-28 14:41:54 UTC (rev 63245)
+++ grass/trunk/vector/v.out.vtk/main.c	2014-11-28 14:45:21 UTC (rev 63246)
@@ -70,7 +70,7 @@
 	_("Number of significant digits (floating point only)");
-    scale->key = "zmultiplier";
+    scale->key = "zscale";
Modified: grass/trunk/vector/v.sample/main.c
--- grass/trunk/vector/v.sample/main.c	2014-11-28 14:41:54 UTC (rev 63245)
+++ grass/trunk/vector/v.sample/main.c	2014-11-28 14:45:21 UTC (rev 63246)
@@ -99,7 +99,7 @@
     parm.method->answer = "nearest";
     parm.z = G_define_option();
-    parm.z->key = "zmultiplier";
+    parm.z->key = "zscale";
     parm.z->type = TYPE_DOUBLE;
     parm.z->required = NO;
     parm.z->answer = "1.0";
Modified: grass/trunk/vector/v.surf.rst/main.c
--- grass/trunk/vector/v.surf.rst/main.c	2014-11-28 14:41:54 UTC (rev 63245)
+++ grass/trunk/vector/v.surf.rst/main.c	2014-11-28 14:45:21 UTC (rev 63246)
@@ -310,7 +310,7 @@
     parm.dmax->guisection = _("Parameters");
Modified: grass/trunk/vector/v.vol.rst/main.c
--- grass/trunk/vector/v.vol.rst/main.c	2014-11-28 14:41:54 UTC (rev 63245)
+++ grass/trunk/vector/v.vol.rst/main.c	2014-11-28 14:45:21 UTC (rev 63246)
@@ -347,7 +347,7 @@
     parm.wmult->guisection = _("Settings");
