[GRASS-SVN] r63255 - in grass/trunk: lib/python/temporal raster/r.in.poly/testsuite scripts/i.pansharpen scripts/v.out.gps
svn_grass at osgeo.org
Fri Nov 28 08:04:18 PST 2014
Author: martinl
Date: 2014-11-28 08:04:18 -0800 (Fri, 28 Nov 2014)
New Revision: 63255
grass/trunk/lib/python/temporal/stds_export.py
grass/trunk/raster/r.in.poly/testsuite/test_rinpoly.py
grass/trunk/scripts/i.pansharpen/i.pansharpen.py
grass/trunk/scripts/v.out.gps/v.out.gps.py
fix renamed options in scripts (#2409)
Modified: grass/trunk/lib/python/temporal/stds_export.py
--- grass/trunk/lib/python/temporal/stds_export.py 2014-11-28 16:00:15 UTC (rev 63254)
+++ grass/trunk/lib/python/temporal/stds_export.py 2014-11-28 16:04:18 UTC (rev 63255)
@@ -154,7 +154,7 @@
list_file.write(string)
# Export the vector map with v.out.ogr
try:
- gscript.run_command("v.out.ogr", input=name, dsn=(name + ".xml"),
+ gscript.run_command("v.out.ogr", input=name, output=(name + ".xml"),
layer=layer, format="GML")
except CalledModuleError:
shutil.rmtree(new_cwd)
Modified: grass/trunk/raster/r.in.poly/testsuite/test_rinpoly.py
--- grass/trunk/raster/r.in.poly/testsuite/test_rinpoly.py 2014-11-28 16:00:15 UTC (rev 63254)
+++ grass/trunk/raster/r.in.poly/testsuite/test_rinpoly.py 2014-11-28 16:04:18 UTC (rev 63255)
@@ -102,7 +102,7 @@
self.tmpFile.write(input1)
self.tmpFile.close()
self.assertModule('r.in.poly', input=self.tmpFile.name, output=self.rinpoly, type='DCELL')
- category = read_command('r.category', map=self.rinpoly, vals=[-8, 3, 10.01]).strip()
+ category = read_command('r.category', map=self.rinpoly, values=[-8, 3, 10.01]).strip()
self.assertEqual(first="-8\t\n3\tlabel2\n10.01\tlabel1", second=category,
msg="Labels do not match")
Modified: grass/trunk/scripts/i.pansharpen/i.pansharpen.py
--- grass/trunk/scripts/i.pansharpen/i.pansharpen.py 2014-11-28 16:00:15 UTC (rev 63254)
+++ grass/trunk/scripts/i.pansharpen/i.pansharpen.py 2014-11-28 16:04:18 UTC (rev 63255)
@@ -2,7 +2,7 @@
-# MODULE: i.pansharpen
+# MODULE: i.panmethod
# AUTHOR(S): Overall script by Michael Barton (ASU)
# Brovey transformation in i.fusion.brovey by Markus Neteler <<neteler at osgeo org>>
@@ -214,7 +214,7 @@
grass.message(_("Creating PCA images and calculating eigenvectors..."))
#initial PCA with RGB channels
- pca_out = grass.read_command('i.pca', quiet=True, rescale='0,0', input='%s,%s,%s' % (ms1, ms2, ms3), output_prefix='tmp%s.pca' % pid)
+ pca_out = grass.read_command('i.pca', quiet=True, rescale='0,0', input='%s,%s,%s' % (ms1, ms2, ms3), output='tmp%s.pca' % pid)
if len(pca_out) < 1:
grass.fatal(_("Input has no data. Check region settings."))
Modified: grass/trunk/scripts/v.out.gps/v.out.gps.py
--- grass/trunk/scripts/v.out.gps/v.out.gps.py 2014-11-28 16:00:15 UTC (rev 63254)
+++ grass/trunk/scripts/v.out.gps/v.out.gps.py 2014-11-28 16:04:18 UTC (rev 63255)
@@ -281,7 +281,7 @@
tmp_gpx = tmp + ".gpx"
try:
- grass.run_command('v.out.ogr', input=tmp_vogb, dsn=tmp_gpx,
+ grass.run_command('v.out.ogr', input=tmp_vogb, output=tmp_gpx,
type=type, format='GPX', lco=linetype,
dsco="GPX_USE_EXTENSIONS=YES", quiet=True)
