[GRASS-SVN] r63261 - in grass/trunk: display/d.rhumbline display/d.vect display/d.vect.chart imagery/i.fft imagery/i.landsat.toar raster/r.distance raster/r.fill.dir raster/r.horizon raster/r.lake raster/r.li/r.li.cwed raster/r.random raster/r.resamp.rst raster/r.sun raster/r.water.outlet raster3d/r3.gwflow scripts/d.rast.leg scripts/i.pansharpen scripts/i.spectral scripts/r.blend scripts/v.db.join scripts/v.db.update scripts/v.what.vect vector/v.clean vector/v.drape vector/v.edit vector/v.extrude vector/v.kcv vector/v.lrs/v.lrs.create vector/v.mkgrid vector/v.net vector/v.out.ogr vector/v.out.postgis vector/v.surf.rst vector/v.vol.rst
svn_grass at osgeo.org
Fri Nov 28 08:22:17 PST 2014
Author: martinl
Date: 2014-11-28 08:22:17 -0800 (Fri, 28 Nov 2014)
New Revision: 63261
grass/trunk/display/d.rhumbline/d.rhumbline.html
grass/trunk/display/d.vect.chart/d.vect.chart.html
grass/trunk/display/d.vect/d.vect.html
grass/trunk/imagery/i.fft/i.fft.html
grass/trunk/imagery/i.landsat.toar/i.landsat.toar.html
grass/trunk/raster/r.distance/r.distance.html
grass/trunk/raster/r.fill.dir/r.fill.dir.html
grass/trunk/raster/r.horizon/r.horizon.html
grass/trunk/raster/r.lake/r.lake.html
grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html
grass/trunk/raster/r.random/r.random.html
grass/trunk/raster/r.resamp.rst/r.resamp.rst.html
grass/trunk/raster/r.sun/r.sun.html
grass/trunk/raster/r.water.outlet/r.water.outlet.html
grass/trunk/raster3d/r3.gwflow/r3.gwflow.html
grass/trunk/scripts/d.rast.leg/d.rast.leg.html
grass/trunk/scripts/i.pansharpen/i.pansharpen.html
grass/trunk/scripts/i.spectral/i.spectral.html
grass/trunk/scripts/r.blend/r.blend.html
grass/trunk/scripts/v.db.join/v.db.join.html
grass/trunk/scripts/v.db.update/v.db.update.html
grass/trunk/scripts/v.what.vect/v.what.vect.html
grass/trunk/vector/v.clean/v.clean.html
grass/trunk/vector/v.drape/v.drape.html
grass/trunk/vector/v.edit/v.edit.html
grass/trunk/vector/v.extrude/v.extrude.html
grass/trunk/vector/v.kcv/v.kcv.html
grass/trunk/vector/v.lrs/v.lrs.create/v.lrs.create.html
grass/trunk/vector/v.mkgrid/v.mkgrid.html
grass/trunk/vector/v.net/v.net.html
grass/trunk/vector/v.out.ogr/v.out.ogr.html
grass/trunk/vector/v.out.postgis/v.out.postgis.html
grass/trunk/vector/v.surf.rst/v.surf.rst.html
grass/trunk/vector/v.vol.rst/v.vol.rst.html
update manuals (#2409)
Modified: grass/trunk/display/d.rhumbline/d.rhumbline.html
--- grass/trunk/display/d.rhumbline/d.rhumbline.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/display/d.rhumbline/d.rhumbline.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -24,7 +24,7 @@
g.region vect=world_political -p
d.mon wx0
d.vect world_political type=area
-d.rhumbline coor=55:58W,33:18S,26:43E,60:37N lcolor=yellow tcolor=red
+d.rhumbline coor=55:58W,33:18S,26:43E,60:37N line_color=yellow text_color=red
</pre></div>
<p><center>
Modified: grass/trunk/display/d.vect/d.vect.html
--- grass/trunk/display/d.vect/d.vect.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/display/d.vect/d.vect.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -17,7 +17,7 @@
</pre></div>
and areas can be made transparent with
<div class="code"><pre>
-d.vect map=vector_map fcolor=none
+d.vect map=vector_map fill_color=none
</pre></div>
<p>In order to display attributes in the map, <b>attribute_column</b> must
@@ -72,7 +72,7 @@
# display roads with category numbers:
-d.vect map=roads display=shape,cat lcolor=green
+d.vect map=roads display=shape,cat label_color=green
# display randomly colorized soils map with attributes
d.vect -c map=soils attribute_column=label
Modified: grass/trunk/display/d.vect.chart/d.vect.chart.html
--- grass/trunk/display/d.vect.chart/d.vect.chart.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/display/d.vect.chart/d.vect.chart.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -39,7 +39,7 @@
r.to.vect -s -v input=erode.index output=erode_index type=area
v.extract input=erode_index output=erode_index_ctrds type=centroid
d.rast aspect
-d.vect.chart map=erode_index_ctrds ctype=bar columns=cat \
+d.vect.chart map=erode_index_ctrds chart_type=bar columns=cat \
size=10 max_ref=12 scale=1.5 colors=yellow
d.vect erode_index_ctrds icon=basic/circle fcol=black col=black size=5
</pre></div>
Modified: grass/trunk/imagery/i.fft/i.fft.html
--- grass/trunk/imagery/i.fft/i.fft.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/imagery/i.fft/i.fft.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -27,7 +27,7 @@
g.region rast=lsat7_2002_70
-i.fft input_image=lsat7_2002_70 real=lsat7_2002_70.real imaginary=lsat7_2002_70.imag
+i.fft input=lsat7_2002_70 real=lsat7_2002_70.real imaginary=lsat7_2002_70.imag
# set region to resulting FFT output map (due to new FFT coordinate space):
g.region rast=lsat7_2002_70.real -p
Modified: grass/trunk/imagery/i.landsat.toar/i.landsat.toar.html
--- grass/trunk/imagery/i.landsat.toar/i.landsat.toar.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/imagery/i.landsat.toar/i.landsat.toar.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -187,22 +187,22 @@
files 293_39.61_toar and 293_39.62_toar:
-i.landsat.toar input_prefix=203_30. output_prefix=_toar \
+i.landsat.toar input=203_30. output=_toar \
metfile=p203r030_7x20010620.met
</pre></div>
or
-i.landsat.toar input_prefix=L5121060_06020060714. \
- output_prefix=L5121060_06020060714_toar \
+i.landsat.toar input=L5121060_06020060714. \
+ output=L5121060_06020060714_toar \
metfile=L5121060_06020060714_MTL.txt
</pre></div>
or
sensor=tm7 product_date=2004-06-07 date=2001-06-20 \
sun_elevation=64.3242970 gain="HHHLHLHHL"
</pre></div>
@@ -210,7 +210,7 @@
or
-i.landsat.toar input_prefix=LC80160352013134LGN03_B output_prefix=toar \
+i.landsat.toar input=LC80160352013134LGN03_B output=toar \
metfile=LC80160352013134LGN03_MTL.txt sensor=oli8 date=2013-05-14
</pre></div>
Modified: grass/trunk/raster/r.distance/r.distance.html
--- grass/trunk/raster/r.distance/r.distance.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/raster/r.distance/r.distance.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -42,7 +42,7 @@
awk and then into <em>d.graph</em>:
<p>
-r.distance maps=map1,map2 | \
+r.distance map=map1,map2 | \
awk -F: '{print "move",$4,$5,"\ndraw",$6,$7}' | d.graph -m
</pre></div>
@@ -51,7 +51,7 @@
awk and then into <em>v.in.ascii</em>:
<p>
awk -F: '{print $4,$5}' | v.in.ascii format=point output=name separator=space
</pre></div>
Modified: grass/trunk/raster/r.fill.dir/r.fill.dir.html
--- grass/trunk/raster/r.fill.dir/r.fill.dir.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/raster/r.fill.dir/r.fill.dir.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -65,7 +65,7 @@
<h2>EXAMPLE</h2>
-r.fill.dir input=ansi.elev output=ansi.fill.elev outdir=ansi.asp
+r.fill.dir input=ansi.elev output=ansi.fill.elev direction=ansi.asp
</pre></div>
Will create a depressionless (sinkless) elevation
Modified: grass/trunk/raster/r.horizon/r.horizon.html
--- grass/trunk/raster/r.horizon/r.horizon.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/raster/r.horizon/r.horizon.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -144,7 +144,7 @@
g.region rast=elevation -p
r.horizon elevation=elevation direction=215 step=0 bufferzone=200 \
- coordinate=638871.6,223384.4 maxdistance=5000
+ coordinates=638871.6,223384.4 maxdistance=5000
</pre></div>
<p>
<b>Example 2</b>: determine horizon values starting at 90 deg (North),
@@ -152,7 +152,7 @@
r.horizon elevation=elevation direction=90 step=5 bufferzone=200 \
- coordinate=638871.6,223384.4 maxdistance=5000 output=horizon.csv
+ coordinates=638871.6,223384.4 maxdistance=5000 file=horizon.csv
</pre></div>
<p>
@@ -162,7 +162,7 @@
g.region n=223540 s=220820 w=634650 e=638780 res=10 -p
r.horizon elevation=elevation direction=0 step=5 bufferzone=200 \
- coordinate=636483.54,222176.25 maxdistance=5000 -d output=horizon.csv
+ coordinates=636483.54,222176.25 maxdistance=5000 -d file=horizon.csv
</pre></div>
<center>
@@ -180,7 +180,7 @@
# we put a bufferzone of 10% of maxdistance around the study area
# compute only direction between 90 and 270 degrees
r.horizon elevation=elevation step=30 start=90 end=300 \
- bufferzone=200 basename=horangle maxdistance=5000
+ bufferzone=200 file=horangle maxdistance=5000
</pre></div>
Modified: grass/trunk/raster/r.lake/r.lake.html
--- grass/trunk/raster/r.lake/r.lake.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/raster/r.lake/r.lake.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -89,7 +89,7 @@
g.region rast=elev_lid792_1m -p
# water accumulation next to street dam
-r.lake elev_lid792_1m coordinates=638759.3,220264.1 wl=113.4 lake=flooding
+r.lake elev_lid792_1m coordinates=638759.3,220264.1 water_level=113.4 lake=flooding
# draw resulting lake map over shaded terrain map
r.shaded.relief elev_lid792_1m
Modified: grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html
--- grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -45,7 +45,7 @@
<em>my_conf</em> configuration file (previously defined with
<em>g.gui.rlisetup</em>) and saving results in <em>my_out</em>, run:
-r.li.cwed map=my_map conf=my_conf output=my_out \
+r.li.cwed input=my_map conf=my_conf output=my_out \
path=/path/to/weights.csv
</pre></div>
Modified: grass/trunk/raster/r.random/r.random.html
--- grass/trunk/raster/r.random/r.random.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/raster/r.random/r.random.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -72,7 +72,7 @@
g.region rast=elevation.10m -p
-r.random elevation.10m vector_output=elevrand n=100
+r.random elevation.10m vector=elevrand n=100
v.db.select elevrand
v.univar elevrand col=value type=point
</pre></div>
@@ -84,7 +84,7 @@
-r.random -d elevation.10m cover=landcover.30m vector_output=luserand3d n=100
+r.random -d elevation.10m cover=landcover.30m vector=luserand3d n=100
# data output (value: elevation, covervalue: landuse class):
v.db.select luserand3d
Modified: grass/trunk/raster/r.resamp.rst/r.resamp.rst.html
--- grass/trunk/raster/r.resamp.rst/r.resamp.rst.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/raster/r.resamp.rst/r.resamp.rst.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -103,7 +103,7 @@
g.region rast=elevation.dem -p
# resample to 15m
-r.resamp.rst input=elevation.dem ew_res=15 ns_res=15 elev=elev15
+r.resamp.rst input=elevation.dem ew_res=15 ns_res=15 elevation=elev15
# set computation region to resulting map
g.region rast=elev15 -p
Modified: grass/trunk/raster/r.sun/r.sun.html
--- grass/trunk/raster/r.sun/r.sun.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/raster/r.sun/r.sun.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -280,7 +280,7 @@
g.region rast=elev_ned_30m -p
# considering cast shadows
-r.sun elevation=elev_ned_30m lin=2.5 alb=0.2 day=172 \
+r.sun elevation=elev_ned_30m linke_value=2.5 albedo_value=0.2 day=172 \
beam_rad=b172 diff_rad=d172 \
refl_rad=r172 insol_time=it172
Modified: grass/trunk/raster/r.water.outlet/r.water.outlet.html
--- grass/trunk/raster/r.water.outlet/r.water.outlet.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/raster/r.water.outlet/r.water.outlet.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -35,7 +35,7 @@
# the watershed outlet position should be placed on a stream (from
# accumulation map):
-r.watershed elev_lid792_1m thresh=5000 accum=accum_5K drain=draindir_5K basin=basin_5K
+r.watershed elev_lid792_1m thresh=5000 accum=accum_5K drain=draindir_5K output=basin_5K
r.water.outlet input=draindir_5K output=basin_A30 coord=638740.423248,220271.519225
d.mon wx0
Modified: grass/trunk/raster3d/r3.gwflow/r3.gwflow.html
--- grass/trunk/raster3d/r3.gwflow/r3.gwflow.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/raster3d/r3.gwflow/r3.gwflow.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -84,8 +84,8 @@
r3.mapcalc expression="syield = 0.0001"
r.mapcalc expression="recharge = 0.0"
-r3.gwflow solver=cg phead=phead status=status hc_x=hydcond hc_y=hydcond \
- hc_z=hydcond q=well s=syield r=recharge output=gwresult dt=8640000 vx=vx vy=vy vz=vz budget=budget
+r3.gwflow solver=cg phead=phead statuyield=status hc_x=hydcond hc_y=hydcond \
+ hc_z=hydcond sink=well yield=syield r=recharge output=gwresult dt=8640000 vx=vx vy=vy vz=vz budget=budget
# The data can be visualized with ParaView when exported with r3.out.vtk
r3.out.vtk -p in=gwresult,status,budget vector=vx,vy,vz out=/tmp/gwdata3d.vtk
@@ -113,8 +113,8 @@
r3.mapcalc expression="hydcond = if(depth() < 10 && depth() > 7 && col() < 60, 0.000025, hydcond)"
- hc_z=hydcond q=well s=syield output=gwresult dt=8640000 vx=vx vy=vy vz=vz budget=budget
+ hc_z=hydcond sink=well yield=syield output=gwresult dt=8640000 vx=vx vy=vy vz=vz budget=budget
# The data can be visualized with paraview when exported with r3.out.vtk
r3.out.vtk -p in=gwresult,status,budget,hydcond,well vector=vx,vy,vz out=/tmp/gwdata3d.vtk
Modified: grass/trunk/scripts/d.rast.leg/d.rast.leg.html
--- grass/trunk/scripts/d.rast.leg/d.rast.leg.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/scripts/d.rast.leg/d.rast.leg.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -28,7 +28,7 @@
North Carolina sample dataset location is generated:
-g.region rast=landclass96 -p
+g.region raster=landclass96 -p
d.rast.leg landclass96
</pre></div>
Modified: grass/trunk/scripts/i.pansharpen/i.pansharpen.html
--- grass/trunk/scripts/i.pansharpen/i.pansharpen.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/scripts/i.pansharpen/i.pansharpen.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -89,9 +89,9 @@
r=p034r032_7dt20010924_z13_30
# i.pansharpen with IHS algorithm
-i.pansharpen ms3=p034r032_7dt20010924_z13_30 ms2=p034r032_7dt20010924_z13_20
- ms1=p034r032_7dt20010924_z13_10 pan=p034r032_7dp20010924_z13_80
- output_prefix=ihs321 sharpen=ihs
+i.pansharpen red=p034r032_7dt20010924_z13_30 green=p034r032_7dt20010924_z13_20
+ blue=p034r032_7dt20010924_z13_10 pan=p034r032_7dp20010924_z13_80
+ output=ihs321 method=ihs
# display at 15m
g.region rast=ihs321_blue -p
@@ -150,10 +150,10 @@
d.rgb b=lsat7_2002_10 g=lsat7_2002_20 r=lsat7_2002_30
-i.pansharpen ms3=lsat7_2002_30 at PERMANENT \
- ms2=lsat7_2002_20 ms1=lsat7_2002_10 \
- pan=lsat7_2002_80 sharpen=ihs \
- output_prefix=lsat7_2002_ihs
+i.pansharpen red=lsat7_2002_30 at PERMANENT \
+ green=lsat7_2002_20 blue=lsat7_2002_10 \
+ pan=lsat7_2002_80 method=ihs \
+ output=lsat7_2002_ihs
# display at 14.25m
g.region rast=lsat7_2002_ihs_red -p
Modified: grass/trunk/scripts/i.spectral/i.spectral.html
--- grass/trunk/scripts/i.spectral/i.spectral.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/scripts/i.spectral/i.spectral.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -14,7 +14,7 @@
g.region rast=lsat7_2002_10 -p
-i.spectral -g raster=lsat7_2002_10,lsat7_2002_20,lsat7_2002_30,lsat7_2002_40,lsat7_2002_50,lsat7_2002_70 \
+i.spectral -g input=lsat7_2002_10,lsat7_2002_20,lsat7_2002_30,lsat7_2002_40,lsat7_2002_50,lsat7_2002_70 \
coordinates=636069,215440,637958,223393,633277,223605
</pre></div>
@@ -30,7 +30,7 @@
LIST=`g.list type=rast pattern="lsat7_2002_[1-5,7]0" separator=","`
-i.spectral raster=$LIST coordinates=637502.25,221744.25
+i.spectral input=$LIST coordinates=637502.25,221744.25
</pre></div>
This will search all LANDSAT map for 2002 but select only the B, G, R,
Modified: grass/trunk/scripts/r.blend/r.blend.html
--- grass/trunk/scripts/r.blend/r.blend.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/scripts/r.blend/r.blend.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -11,7 +11,7 @@
g.region rast=aspect -p
-r.blend first=aspect second=elevation output_prefix=elev_shade_blend
+r.blend first=aspect second=elevation output=elev_shade_blend
d.mon wx0
d.rgb blue=elev_shade_blend.b green=elev_shade_blend.g red=elev_shade_blend.r
</pre></div>
Modified: grass/trunk/scripts/v.db.join/v.db.join.html
--- grass/trunk/scripts/v.db.join/v.db.join.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/scripts/v.db.join/v.db.join.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -50,7 +50,7 @@
# join soils_legend into mysoils attribute table
-v.db.join mysoils col=label otable=soils_legend ocol=shortname
+v.db.join mysoils col=label other_table=soils_legend ocol=shortname
# verification of join
v.db.select mysoils
Modified: grass/trunk/scripts/v.db.update/v.db.update.html
--- grass/trunk/scripts/v.db.update/v.db.update.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/scripts/v.db.update/v.db.update.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -68,7 +68,7 @@
g.copy vect=precip_30ynormals,myprecip_30ynormals
v.db.addcolumn myprecip_30ynormals column="logjuly double precision"
-v.db.update myprecip_30ynormals column="logjuly" qcolumn="log(jul)" \
+v.db.update myprecip_30ynormals column="logjuly" query_column="log(jul)" \
sqliteextra=$HOME/sqlite_extensions/libsqlitefunctions.so
v.db.select myprecip_30ynormals columns=jul,logjuly
Modified: grass/trunk/scripts/v.what.vect/v.what.vect.html
--- grass/trunk/scripts/v.what.vect/v.what.vect.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/scripts/v.what.vect/v.what.vect.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -28,7 +28,7 @@
g.copy vect=hospitals,myhospitals
v.db.addcolumn myhospitals column="urb_name varchar(25)"
-v.what.vect myhospitals qmap=urbanarea column=urb_name qcolumn=NAME
+v.what.vect myhospitals query_map=urbanarea column=urb_name query_column=NAME
# verification:
v.db.select myhospitals
</pre></div>
@@ -46,8 +46,8 @@
# add new column
v.db.addcol corine_code111_112_cities column="gnameid double precision"
# transfer geonameid (3000m maximal distance between points and centroids)
-v.what.vect corine_code111_112_cities qmap=geonames_IT_cities column=gnameid \
- qcolumn=geonameid dmax=3000
+v.what.vect corine_code111_112_cities query_map=geonames_IT_cities column=gnameid \
+ query_column=geonameid dmax=3000
# now gnameid can be used for v.db.join to join further
# attributes in from geonames.org
</pre></div>
Modified: grass/trunk/vector/v.clean/v.clean.html
--- grass/trunk/vector/v.clean/v.clean.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/vector/v.clean/v.clean.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -210,7 +210,7 @@
<h3>Snap lines to vertex in threshold</h3>
-v.clean input=testmap output=cleanmap tool=snap thresh=1
+v.clean input=testmap output=cleanmap tool=snap threshold=1
</pre></div>
<h3>Cleaning OGR imported data (Simple Feature data) such as SHAPE file</h3>
@@ -277,7 +277,7 @@
v.clean input=testmap output=cleanmap type=line \
- tool=rmdangle,rmdangle,rmdangle,rmdangle thresh=5,10,20,50
+ tool=rmdangle,rmdangle,rmdangle,rmdangle threshold=5,10,20,50
</pre></div>
<h2>SEE ALSO</h2>
Modified: grass/trunk/vector/v.drape/v.drape.html
--- grass/trunk/vector/v.drape/v.drape.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/vector/v.drape/v.drape.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -29,7 +29,7 @@
Spearfish example:
-v.drape in=roads rast=elevation.10m method=bilinear out=roads3d
+v.drape in=roads elevation=elevation.10m method=bilinear out=roads3d
v.info roads3d
</pre></div>
@@ -38,7 +38,7 @@
road height to 1000 m for all parts without height information.
-v.drape input=roads type=line rast=elevation.dem output=roads_3d \
+v.drape input=roads type=line elevation=elevation.dem output=roads_3d \
method=nearest scale=1.0 where='cat=5' layer=1 null_value=1000
</pre></div>
@@ -46,7 +46,7 @@
#export the vector data
-v.drape in=roads out=roads3d rast=elevation.10m
+v.drape in=roads out=roads3d elevation=elevation.10m
v.out.pov roads3d out=roads3d.pov
#export the raster data
r.out.pov elevation.10m tga=elevation.tga
Modified: grass/trunk/vector/v.edit/v.edit.html
--- grass/trunk/vector/v.edit/v.edit.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/vector/v.edit/v.edit.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -21,7 +21,7 @@
v.edit map=roads tool=select \
coord=599505,4921010,603389.0625,4918292.1875 \
- thresh=10000 where="label='interstate'"
+ threshold=10000 where="label='interstate'"
</pre></div>
selects all features (and prints their id's to standard output)
@@ -228,7 +228,7 @@
v.edit map=roads tool=delete \
coord=592542.892,4924766.996,603389.062,4918292.187 \
- thresh=1000 cat=1,2
+ threshold=1000 cat=1,2
</pre></div>
<h3>Copy selected features from background map</h3>
@@ -253,7 +253,7 @@
distance 10 map units:
-v.edit tool=move map=roads cat=1 move=1000,-1000 snap=node thresh=-1,10
+v.edit tool=move map=roads cat=1 move=1000,-1000 snap=node threshold=-1,10
</pre></div>
Move all features defined by bounding box
@@ -301,7 +301,7 @@
Split line id 810 on coordinates 604268,4923570 in threshold 50 map units:
-v.edit map=roads tool=break coords=604268,4923570 id=810 thresh=50
+v.edit map=roads tool=break coords=604268,4923570 id=810 threshold=50
</pre></div>
<h3>Break selected lines at each intersection</h3>
@@ -317,7 +317,7 @@
Snap all lines using threshold distance 20 map units:
-v.edit map=roads id=1-9999 tool=snap thresh=-1,20 type=line
+v.edit map=roads id=1-9999 tool=snap threshold=-1,20 type=line
</pre></div>
<h3>Connect lines</h3>
@@ -332,7 +332,7 @@
50. Maximum threshold distance is 700 map units:
-v.edit map=roads tool=connect id=48,565,60,50 thresh=-1,700
+v.edit map=roads tool=connect id=48,565,60,50 threshold=-1,700
</pre></div>
<h3>Add vertex</h3>
@@ -341,7 +341,7 @@
set to 1 map unit:
-v.edit tool=vertexadd map=roads coords=600952,4926107 thresh=1
+v.edit tool=vertexadd map=roads coords=600952,4926107 threshold=1
</pre></div>
<h3>Delete vertices</h3>
@@ -351,7 +351,7 @@
v.edit tool=vertexdel map=roads coord=593191.608,4925684.849 \
- thresh=1-e1 cats=1
+ threshold=1-e1 cats=1
</pre></div>
<h3>Move vertices</h3>
@@ -361,7 +361,7 @@
v.edit tool=vertexmove map=roads cats=1-10 coord=604441,4921088 \
- thresh=100 move=1000,1000
+ threshold=100 move=1000,1000
</pre></div>
<h3>Select features and print their id's</h3>
@@ -380,19 +380,19 @@
d.vect roads;
d.vect -i map=roads cats=`v.edit map=roads tool=select \
coord=592542.89243878,4924766.99622811,603389.0625,4918292.1875 \
- thresh=1000 --q` col=red
+ threshold=1000 --q` col=red
</pre></div>
Select all lines shorter (or equal) than 10 map units:
-v.edit map=roads tool=select query=length thresh=-1,0,-10
+v.edit map=roads tool=select query=length threshold=-1,0,-10
</pre></div>
Select from given bounding box all lines longer then 200 map units:
-v.edit map=roads tool=select bbox=598260,4919730,605100,4926240 query=length thresh=-1,0,200
+v.edit map=roads tool=select bbox=598260,4919730,605100,4926240 query=length threshold=-1,0,200
</pre></div>
<h3>Fix height of contours</h3>
Modified: grass/trunk/vector/v.extrude/v.extrude.html
--- grass/trunk/vector/v.extrude/v.extrude.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/vector/v.extrude/v.extrude.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -52,7 +52,7 @@
<h3>3D houses with individual height</h3>
-v.extrude input=houses output=houses3D elevation=dem hcolumn=height type=area
+v.extrude input=houses output=houses3D elevation=dem height_column=height type=area
</pre></div>
<h3>Convert 2D points to 3D vertical lines with fixed height</h3>
Modified: grass/trunk/vector/v.kcv/v.kcv.html
--- grass/trunk/vector/v.kcv/v.kcv.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/vector/v.kcv/v.kcv.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -35,13 +35,13 @@
g.copy vect=geonames_wake,my_geonames_wake
-v.kcv map=my_geonames_wake column=part k=10
+v.kcv map=my_geonames_wake column=part npartitions=10
</pre></div>
<p>
g.copy vect=geodetic_pts,my_geodetic_pts
-v.kcv map=my_geodetic_pts column=part k=10
+v.kcv map=my_geodetic_pts column=part npartitions=10
</pre></div>
<h2>SEE ALSO</h2>
Modified: grass/trunk/vector/v.lrs/v.lrs.create/v.lrs.create.html
--- grass/trunk/vector/v.lrs/v.lrs.create/v.lrs.create.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/vector/v.lrs/v.lrs.create/v.lrs.create.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -38,7 +38,7 @@
590346,4927246,590414,4927210,590438,4927096,590468,4926966,\
590491,4926848,590566,4926798,590637,4926753,590701,4926698,\
590830,4926726,590935,4926751,590993,4926830,590972,4926949,\
-590948,4927066,590922,4927182,590957,4927251 thresh=5
+590948,4927066,590922,4927182,590957,4927251 threshold=5
# vector line needs to be polyline
v.build.polylines busroute_tmp2 out=busroute_tmp3
@@ -124,7 +124,7 @@
v.lrs.create busroute points=busstops out=route_lrs err=lrs_error \
- lidcol=lid pidcol=lid rstable=route_lrs thresh=50
+ lidcol=lid pidcol=lid rstable=route_lrs threshold=50
</pre></div>
This creates the maps 'route_lrs' containing the LRS and 'lrs_error'
Modified: grass/trunk/vector/v.mkgrid/v.mkgrid.html
--- grass/trunk/vector/v.mkgrid/v.mkgrid.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/vector/v.mkgrid/v.mkgrid.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -59,7 +59,7 @@
Creating a 4x3 grid, cells 20km a side, with lower left corner at 2716500,6447000:
-v.mkgrid map=coro_grid grid=4,3 position=coor coor=2716500,6447000 box=20000,20000
+v.mkgrid map=coro_grid grid=4,3 position=coor coordinates=2716500,6447000 box=20000,20000
</pre></div>
<h3>Creating a positioned grid in a latitude-longitude</h3>
@@ -71,7 +71,7 @@
just use <em>d.grid -w</em> from the projected location for the same effect):
-v.mkgrid map=p2min_grid grid=10,12 position=coor coor=167:52E,47:06S box=0:02,0:02
+v.mkgrid map=p2min_grid grid=10,12 position=coor coordinates=167:52E,47:06S box=0:02,0:02
</pre></div>
<h3>Creating a simple point pattern</h3>
Modified: grass/trunk/vector/v.net/v.net.html
--- grass/trunk/vector/v.net/v.net.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/vector/v.net/v.net.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -157,7 +157,7 @@
v.net input=streets_wake points=firestations out=streets_net \
- operation=connect thresh=500
+ operation=connect threshold=500
</pre></div>
For generating network for given vector point map is required input
Modified: grass/trunk/vector/v.out.ogr/v.out.ogr.html
--- grass/trunk/vector/v.out.ogr/v.out.ogr.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/vector/v.out.ogr/v.out.ogr.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -105,7 +105,7 @@
(generates '/tmp/testogr.gml' file with layer 'testogr'):
-v.out.ogr input=multi type=line output=/tmp/testogr.gml olayer=testogr format=GML
+v.out.ogr input=multi type=line output=/tmp/testogr.gml output_layer=testogr format=GML
</pre></div>
<h3>Export to PostgreSQL/PostGIS</h3>
@@ -113,7 +113,7 @@
Export areas from GRASS vector map to PostGIS database:
-v.out.ogr input=polygons type=area output="PG:host=localhost dbname=postgis user=postgres" olayer=polymap format=PostgreSQL
+v.out.ogr input=polygons type=area output="PG:host=localhost dbname=postgis user=postgres" output_layer=polymap format=PostgreSQL
</pre></div>
<i>Note:</i> For exporting GRASS vector data to PostGIS database can
@@ -127,7 +127,7 @@
Export faces (3D vectors) from GRASS vector map to KML format for Google Earth:
-v.out.ogr input=buildings_3d output=buildings_3d.kml olayer=buildings_3d format=KML type=face
+v.out.ogr input=buildings_3d output=buildings_3d.kml output_layer=buildings_3d format=KML type=face
</pre></div>
<p>
Modified: grass/trunk/vector/v.out.postgis/v.out.postgis.html
--- grass/trunk/vector/v.out.postgis/v.out.postgis.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/vector/v.out.postgis/v.out.postgis.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -170,7 +170,7 @@
schema "grassout".
-v.out.postgis input=bridges output="PG:dbname=grass" olayer=grassout.bridges
+v.out.postgis input=bridges output="PG:dbname=grass" output_layer=grassout.bridges
</pre></div>
<h3>Export data with creation options</h3>
@@ -194,7 +194,7 @@
as a link to the PostGIS feature table.
-v.out.postgis input=busstopsall at PERMANENT output="PG:dbname=grass" olink=busstopsall_pg
+v.out.postgis input=busstopsall at PERMANENT output="PG:dbname=grass" output_link=busstopsall_pg
</pre></div>
Created link can be checked
Modified: grass/trunk/vector/v.surf.rst/v.surf.rst.html
--- grass/trunk/vector/v.surf.rst/v.surf.rst.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/vector/v.surf.rst/v.surf.rst.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -310,13 +310,13 @@
# interpolation based on all points
-v.surf.rst elevrand zcol=value elev=elev_full
+v.surf.rst elevrand zcol=value elevation=elev_full
r.colors elev_full rast=elevation.10m
d.rast elev_full
d.vect elevrand
# interpolation based on subset of points (only those over 1300m/asl)
-v.surf.rst elevrand zcol=value elev=elev_partial where="value > 1300"
+v.surf.rst elevrand zcol=value elevation=elev_partial where="value > 1300"
r.colors elev_partial rast=elevation.10m
d.rast elev_partial
d.vect elevrand where="value > 1300"
Modified: grass/trunk/vector/v.vol.rst/v.vol.rst.html
--- grass/trunk/vector/v.vol.rst/v.vol.rst.html 2014-11-28 16:16:19 UTC (rev 63260)
+++ grass/trunk/vector/v.vol.rst/v.vol.rst.html 2014-11-28 16:22:17 UTC (rev 63261)
@@ -69,7 +69,7 @@
# preparation as in above example
-v.vol.rst elevrand_3d wcol=soilrange elev=soilrange zmult=100 where="soilrange > 3"
+v.vol.rst elevrand_3d wcol=soilrange elevation=soilrange zmult=100 where="soilrange > 3"
</pre></div>
@@ -209,7 +209,7 @@
### Second part: 3D interpolation from 3D point data
# interpolate volume to "soilrange" voxel map
-v.vol.rst input=elevrand_3d wcol=soilrange elev=soilrange zmult=100
+v.vol.rst input=elevrand_3d wcol=soilrange elevation=soilrange zmult=100
# visualize I: in GRASS GIS wxGUI
g.gui
