[GRASS-SVN] r63264 - grass/branches/releasebranch_7_0/general/g.list
svn_grass at osgeo.org
Fri Nov 28 08:41:16 PST 2014
Author: mmetz
Date: 2014-11-28 08:41:16 -0800 (Fri, 28 Nov 2014)
New Revision: 63264
grass/branches/releasebranch_7_0/general/g.list/main.c
g.list: if possible, sort output by 1. type, 2. name, 3. mapset
Modified: grass/branches/releasebranch_7_0/general/g.list/main.c
--- grass/branches/releasebranch_7_0/general/g.list/main.c 2014-11-28 16:41:00 UTC (rev 63263)
+++ grass/branches/releasebranch_7_0/general/g.list/main.c 2014-11-28 16:41:16 UTC (rev 63264)
@@ -34,10 +34,20 @@
TYPE_OTHERS
+struct elist
+ char *type;
+ char *name;
+ char *mapset;
static int any = 0;
-static void make_list(FILE *, const struct list *, const char *,
- const char *, int, int, struct Cell_head *);
+static void make_list(struct elist **, int *, int *,
+ const struct list *, const char *,
+ struct Cell_head *);
+static void print_list(FILE *, struct elist *, int,
+ const char *, int, int);
static int region_overlaps(struct Cell_head *, const char *, const char *, int);
int main(int argc, char *argv[])
@@ -70,6 +80,8 @@
char *separator;
int use_region, use_pager;
struct Cell_head window;
+ struct elist *el;
+ int lcount, lalloc;
G_gisinit(argv[0]);
@@ -305,6 +317,9 @@
if (flag.pretty->answer || flag.full->answer)
dup2(fileno(fp), STDOUT_FILENO);
+ lcount = 0;
+ lalloc = 0;
+ el = NULL;
for (i = 0; i < num_types; i++) {
const struct list *elem;
@@ -340,11 +355,19 @@
const char *mapset;
for (j = 0; (mapset = G_get_mapset_name(j)); j++)
- make_list(fp, elem, mapset, separator, flag.type->answer,
- flag.mapset->answer, use_region ? &window : NULL);
+ make_list(&el, &lcount, &lalloc, elem, mapset,
+ use_region ? &window : NULL);
+ if (!flag.pretty->answer && !flag.full->answer) {
+ print_list(fp, el, lcount, separator, flag.type->answer,
+ flag.mapset->answer);
+ if (el)
+ G_free(el);
fclose(stdout);
else if (any)
@@ -364,15 +387,14 @@
exit(EXIT_SUCCESS);
-static void make_list(FILE *fp, const struct list *elem, const char *mapset,
- const char *separator, int add_type, int add_mapset,
+static void make_list(struct elist **el, int *lcount, int *lalloc,
+ const struct list *elem, const char *mapset,
struct Cell_head *window)
- static int first_mapset = 1;
char path[GPATH_MAX];
const char *element, *alias;
char **list;
- int count, first, i;
+ int count, i;
int type;
element = elem->element[0];
@@ -385,11 +407,11 @@
if ((list = G__ls(path, &count)) == NULL)
return;
- if (strcmp(alias, "rast") == 0)
+ if (strcmp(alias, "raster") == 0)
type = TYPE_RAST;
- else if (strcmp(alias, "rast3d") == 0)
+ else if (strcmp(alias, "3draster") == 0)
type = TYPE_RAST3D;
- else if (strcmp(alias, "vect") == 0)
+ else if (strcmp(alias, "vector") == 0)
type = TYPE_VECT;
else
type = TYPE_OTHERS;
@@ -397,56 +419,80 @@
/* Suppress "... found in more mapsets" warnings from G_find_file2. */
G_suppress_warnings(1);
- first = 1;
+ if (*lcount + count > *lalloc) {
+ *lalloc = *lcount + count + 10;
+ *el = G_realloc(*el, *lalloc * sizeof(struct elist));
for (i = 0; i < count; i++) {
- char *name = list[i];
- int need_mapset = 0;
/* If region= is used, read the map region. */
if (window) {
/* If the map region doesn't overlap with the input region, don't
* print the map. */
- if (!region_overlaps(window, name, mapset, type))
+ if (!region_overlaps(window, list[i], mapset, type))
continue;
- if (first) {
- first = 0;
+ (*el)[*lcount].type = G_store(alias);
+ (*el)[*lcount].name = list[i];
+ (*el)[*lcount].mapset = G_store(mapset);
+ (*lcount)++;
- if (any)
- fprintf(fp, "%s", separator);
- if (fp == stdout && isatty(STDOUT_FILENO))
- G_message(_("%s available in mapset <%s>:"),
- elem->text, mapset);
+ any++;
- if (any && i != 0)
+ G_suppress_warnings(0);
+ G_free(list);
+int cmp(const void *a, const void *b)
+ struct elist *al = (struct elist *)a;
+ struct elist *bl = (struct elist *)b;
+ int ret;
+ if (!(ret = strcmp(al->type, bl->type))) {
+ if (!(ret = strcmp(al->name, bl->name)))
+ ret = strcmp(al->mapset, bl->mapset);
+ return ret;
+static void print_list(FILE *fp, struct elist *el, int count,
+ const char *separator, int add_type, int add_mapset)
+ int i;
+ if (!count)
+ return;
+ qsort(el, count, sizeof(struct elist), cmp);
+ for (i = 0; i < count; i++) {
+ int need_mapset = 0;
+ if (i != 0)
if (add_type)
- fprintf(fp, "%s/", alias);
+ fprintf(fp, "%s/", el[i].type);
- fprintf(fp, "%s", name);
+ fprintf(fp, "%s", el[i].name);
- if (!add_mapset && !first_mapset) {
- const char *mapset2 = G_find_file2(element, name, "");
- if (mapset2)
- need_mapset = strcmp(mapset, mapset2) != 0;
+ if (!add_mapset) {
+ if (i + 1 < count)
+ need_mapset = strcmp(el[i].name, el[i + 1].name) == 0;
+ if (!need_mapset && i > 0)
+ need_mapset = strcmp(el[i].name, el[i - 1].name) == 0;
if (add_mapset || need_mapset)
- fprintf(fp, "@%s", mapset);
- G_free(name);
- any++;
+ fprintf(fp, "@%s", el[i].mapset);
- G_suppress_warnings(0);
fflush(fp);
- G_free(list);
- first_mapset = 0;
static int region_overlaps(struct Cell_head *window, const char *name,
