[GRASS-SVN] r63266 - in grass/branches/releasebranch_7_0: include/vect lib/vector/Vlib lib/vector/diglib
svn_grass at osgeo.org
Fri Nov 28 12:01:30 PST 2014
Author: mmetz
Date: 2014-11-28 12:01:30 -0800 (Fri, 28 Nov 2014)
New Revision: 63266
grass/branches/releasebranch_7_0/include/vect/dig_externs.h
grass/branches/releasebranch_7_0/lib/vector/Vlib/build.c
grass/branches/releasebranch_7_0/lib/vector/Vlib/open_pg.c
grass/branches/releasebranch_7_0/lib/vector/diglib/plus_area.c
grass/branches/releasebranch_7_0/lib/vector/diglib/plus_line.c
grass/branches/releasebranch_7_0/lib/vector/diglib/update.c
diglib: change content of list of changed lines
Modified: grass/branches/releasebranch_7_0/include/vect/dig_externs.h
--- grass/branches/releasebranch_7_0/include/vect/dig_externs.h 2014-11-28 20:01:16 UTC (rev 63265)
+++ grass/branches/releasebranch_7_0/include/vect/dig_externs.h 2014-11-28 20:01:30 UTC (rev 63266)
@@ -252,7 +252,7 @@
/* update.c */
/* list of updated */
void dig_line_reset_updated(struct Plus_head *);
-void dig_line_add_updated(struct Plus_head *, int);
+void dig_line_add_updated(struct Plus_head *, int, off_t);
void dig_node_reset_updated(struct Plus_head *);
void dig_node_add_updated(struct Plus_head *, int);
Modified: grass/branches/releasebranch_7_0/lib/vector/Vlib/build.c
--- grass/branches/releasebranch_7_0/lib/vector/Vlib/build.c 2014-11-28 20:01:16 UTC (rev 63265)
+++ grass/branches/releasebranch_7_0/lib/vector/Vlib/build.c 2014-11-28 20:01:30 UTC (rev 63266)
@@ -523,18 +523,12 @@
G_debug(3, "\tfirst centroid -> attach to area");
Area->centroid = centr;
topo->area = sel_area;
- if (sel_area != orig_area && plus->uplist.do_uplist)
- dig_line_add_updated(plus, centr);
else if (Area->centroid != centr) { /* duplicate centroid */
/* Note: it cannot happen that Area->centroid == centr, because the centroid
* was not registered or a duplicate */
G_debug(3, "\tduplicate centroid -> do not attach to area");
topo->area = -sel_area;
- if (-sel_area != orig_area && plus->uplist.do_uplist)
@@ -849,7 +843,7 @@
plus->with_z = Map->head.with_z;
plus->spidx_with_z = Map->head.with_z;
- if (build == GV_BUILD_ALL) {
+ if (build == GV_BUILD_ALL && plus->build < GV_BUILD_ALL) {
dig_cidx_free(plus); /* free old (if any) category index */
dig_cidx_init(plus);
Modified: grass/branches/releasebranch_7_0/lib/vector/Vlib/open_pg.c
--- grass/branches/releasebranch_7_0/lib/vector/Vlib/open_pg.c 2014-11-28 20:01:16 UTC (rev 63265)
+++ grass/branches/releasebranch_7_0/lib/vector/Vlib/open_pg.c 2014-11-28 20:01:30 UTC (rev 63266)
@@ -955,8 +955,7 @@
if (plus->uplist.do_uplist) {
/* collect updated lines if requested */
- dig_line_add_updated(plus, n);
- plus->uplist.uplines_offset[plus->uplist.n_uplines - 1] = line->offset;
+ dig_line_add_updated(plus, n, line->offset);
plus->Line[n] = line;
Modified: grass/branches/releasebranch_7_0/lib/vector/diglib/plus_area.c
--- grass/branches/releasebranch_7_0/lib/vector/diglib/plus_area.c 2014-11-28 20:01:16 UTC (rev 63265)
+++ grass/branches/releasebranch_7_0/lib/vector/diglib/plus_area.c 2014-11-28 20:01:30 UTC (rev 63266)
@@ -210,8 +210,6 @@
Area->lines[i] = line;
Line = plus->Line[abs(line)];
topo = (struct P_topo_b *)Line->topo;
- if (plus->uplist.do_uplist)
- dig_line_add_updated(plus, abs(line));
if (line < 0) { /* revers direction -> area on left */
if (topo->left != 0) {
G_warning(_("Line %d already has area/isle %d to left"), line,
@@ -380,8 +378,6 @@
line = Area->lines[i]; /* >0 = clockwise -> right, <0 = counterclockwise ->left */
btopo = (struct P_topo_b *)Line->topo;
if (line > 0) {
G_debug(3, " Set line %d right side to 0", line);
btopo->right = 0;
@@ -415,8 +411,6 @@
else {
ctopo = (struct P_topo_c *)Line->topo;
ctopo->area = 0;
- dig_line_add_updated(plus, line);
@@ -712,8 +706,6 @@
Isle->lines[i] = line;
if (line < 0) { /* revers direction -> isle on left */
@@ -772,8 +764,6 @@
line = Isle->lines[i]; /* >0 = clockwise -> right, <0 = counterclockwise ->left */
if (line > 0)
topo->right = 0;
else
Modified: grass/branches/releasebranch_7_0/lib/vector/diglib/plus_line.c
--- grass/branches/releasebranch_7_0/lib/vector/diglib/plus_line.c 2014-11-28 20:01:16 UTC (rev 63265)
+++ grass/branches/releasebranch_7_0/lib/vector/diglib/plus_line.c 2014-11-28 20:01:30 UTC (rev 63266)
@@ -32,8 +32,7 @@
dig_spidx_add_line(plus, lineid, box);
- dig_line_add_updated(plus, lineid);
+ dig_line_add_updated(plus, lineid, offset);
if (type & GV_POINT) {
@@ -229,8 +228,7 @@
dig_spidx_del_line(plus, line, x, y, z);
- plus->uplist.uplines_offset[plus->uplist.n_uplines - 1] = -1 * Line->offset;
+ dig_line_add_updated(plus, line, -Line->offset);
if (!(Line->type & GV_LINES)) {
Modified: grass/branches/releasebranch_7_0/lib/vector/diglib/update.c
--- grass/branches/releasebranch_7_0/lib/vector/diglib/update.c 2014-11-28 20:01:16 UTC (rev 63265)
+++ grass/branches/releasebranch_7_0/lib/vector/diglib/update.c 2014-11-28 20:01:30 UTC (rev 63266)
@@ -34,7 +34,7 @@
\param line line id
\param offset line offset (negative offset is ignored)
-void dig_line_add_updated(struct Plus_head *Plus, int line)
+void dig_line_add_updated(struct Plus_head *Plus, int line, off_t offset)
int i;
@@ -43,6 +43,7 @@
/* Check if already in list */
for (i = 0; i < Plus->uplist.n_uplines; i++) {
if (Plus->uplist.uplines[i] == line) {
+ Plus->uplist.uplines_offset[i] = offset;
G_debug(3, "\tskipped");
return;
@@ -60,6 +61,7 @@
Plus->uplist.uplines[Plus->uplist.n_uplines] = line;
+ Plus->uplist.uplines_offset[Plus->uplist.n_uplines] = offset;
Plus->uplist.n_uplines++;
