[GRASS-SVN] r63277 - grass/trunk/raster/r.viewshed/testsuite
svn_grass at osgeo.org
Fri Nov 28 18:59:04 PST 2014
Author: annakrat
Date: 2014-11-28 18:59:03 -0800 (Fri, 28 Nov 2014)
New Revision: 63277
grass/trunk/raster/r.viewshed/testsuite/test_r_viewshed.py
r.viewshed: rename option - update testsuite
Modified: grass/trunk/raster/r.viewshed/testsuite/test_r_viewshed.py
--- grass/trunk/raster/r.viewshed/testsuite/test_r_viewshed.py 2014-11-29 02:58:40 UTC (rev 63276)
+++ grass/trunk/raster/r.viewshed/testsuite/test_r_viewshed.py 2014-11-29 02:59:03 UTC (rev 63277)
@@ -9,7 +9,7 @@
@classmethod
def setUpClass(cls):
cls.use_temp_region()
- cls.runModule('g.region', rast='elevation')
+ cls.runModule('g.region', raster='elevation')
@classmethod
def tearDownClass(cls):
@@ -18,7 +18,7 @@
def tearDown(cls):
"""Remove viewshed map after each test method"""
# TODO: eventually, removing maps should be handled through testing framework fucntions
- cls.runModule('g.remove', flags='f', type='rast',
+ cls.runModule('g.remove', flags='f', type='raster',
name=cls.viewshed)
def test_limits(self):
@@ -26,7 +26,7 @@
obs_elev = '1.72'
self.assertModule('r.viewshed', input='elevation',
coordinates=(634720,216180), output=self.viewshed,
- obs_elev=obs_elev)
+ observer_elevation=obs_elev)
self.assertRasterMinMax(map=self.viewshed, refmin=0, refmax=180,
msg="Viewing angle above the ground must be between 0 and 180 deg")
@@ -35,13 +35,13 @@
# test e flag
self.assertModule('r.viewshed', input='elevation', flags='e',
coordinates=(634720, 216180), output=self.viewshed,
minmax = 'null_cells=1963758\nmin=-24.98421\nmax=43.15356'
self.assertRasterFitsUnivar(raster=self.viewshed, reference=minmax, precision=1e-5)
# test b flag (#1788)
self.assertModule('r.viewshed', input='elevation', flags='b',
- obs_elev=obs_elev, overwrite=True)
+ observer_elevation=obs_elev, overwrite=True)
minmax = 'min=0\nmax=1\ndatatype=CELL'
self.assertRasterFitsInfo(raster=self.viewshed, reference=minmax,
msg="Values of binary output must be 0 or 1")
@@ -55,7 +55,7 @@
obs_elev = '500000'
@@ -67,7 +67,7 @@
g.region n=216990 s=215520 w=633730 e=635950 res=10 -p
r.out.ascii elevation out=data/elevation.ascii
- r.viewshed input=elevation output=lake_viewshed coordinates=634720,216180 obs_elev=1.72
+ r.viewshed input=elevation output=lake_viewshed coordinates=634720,216180 observer_elevation=1.72
r.out.ascii lake_viewshed out=data/lake_viewshed.ascii
@@ -91,10 +91,10 @@
@classmethod
cls.del_temp_region()
name=cls.elevation)
if cls.to_remove:
name=','.join(cls.to_remove))
def test_viewshed(self):
@@ -107,7 +107,7 @@
self.to_remove.append(ref_viewshed)
self.assertModule('r.viewshed', input=self.elevation,
- coordinates=(634720,216180), output=viewshed, obs_elev=obs_elev)
+ coordinates=(634720,216180), output=viewshed, observer_elevation=obs_elev)
self.to_remove.append(viewshed)
# check we have expected values
