[GRASS-SVN] r63293 - in grass/branches/releasebranch_7_0: . gui/wxpython gui/wxpython/mapdisp
Sat Nov 29 13:50:26 PST 2014
Author: annakrat
Date: 2014-11-29 13:50:26 -0800 (Sat, 29 Nov 2014)
New Revision: 63293
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/main.py
   grass/branches/releasebranch_7_0/gui/wxpython/wxgui.py
wxGUI: add set_raise_on_error(True) to prevent crashing gui when using grass.mapcalc
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62886,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,63089,
 63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63276,63279,63281,63283,63287,63290
   + /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62886,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,63089,
 63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63276,63279,63281,63283,63287,63290,63292
Modified: grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/main.py
--- grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/main.py	2014-11-29 21:48:13 UTC (rev 63292)
+++ grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/main.py	2014-11-29 21:50:26 UTC (rev 63293)
@@ -346,6 +346,7 @@
         if not globalvar.CheckWxVersion([2, 9]):
             wx.InitAllImageHandlers()
+        grass.set_raise_on_error(True)
         # actual use of StandaloneGrassInterface not yet tested
         # needed for adding functionality in future
         giface = DMonGrassInterface(None)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/wxgui.py
--- grass/branches/releasebranch_7_0/gui/wxpython/wxgui.py	2014-11-29 21:48:13 UTC (rev 63292)
+++ grass/branches/releasebranch_7_0/gui/wxpython/wxgui.py	2014-11-29 21:50:26 UTC (rev 63293)
@@ -26,6 +26,7 @@
 from core.utils import _
 from grass.exceptions import Usage
+from grass.script.core import set_raise_on_error
 import wx
 try:
@@ -133,6 +134,7 @@
     app = GMApp(workspaceFile)
     # suppress wxPython logs
     q = wx.LogNull()
+    set_raise_on_error(True)
     app.MainLoop()
