[GRASS-SVN] r63301 - grass-addons/grass7/vector/v.habitat.dem
svn_grass at osgeo.org
Sun Nov 30 06:48:24 PST 2014
Author: hellik
Date: 2014-11-30 06:48:24 -0800 (Sun, 30 Nov 2014)
New Revision: 63301
grass-addons/grass7/vector/v.habitat.dem/v.habitat.dem.py
v.habitat.dem: fix alignment to raster and vector
Modified: grass-addons/grass7/vector/v.habitat.dem/v.habitat.dem.py
--- grass-addons/grass7/vector/v.habitat.dem/v.habitat.dem.py 2014-11-30 13:50:20 UTC (rev 63300)
+++ grass-addons/grass7/vector/v.habitat.dem/v.habitat.dem.py 2014-11-30 14:48:24 UTC (rev 63301)
@@ -177,7 +177,10 @@
grass.message( "----" )
# Print and save current region
- grass.run_command('g.region', flags = 'p', save = saved_region, overwrite = True)
+ grass.message( "Current region:" )
+ grass.message( "n, s, e, w" )
+ grass.message( [current_region[key] for key in "nsew"] )
+ grass.run_command('g.region', save = saved_region, overwrite = True)
grass.message( "Current region saved." )
@@ -188,24 +191,34 @@
vect = v_habitat,
align = r_elevation)
grass.message( "Alignment done." )
+ aligned_region = grass.region()
+ Naligned = aligned_region["n"]
+ Saligned = aligned_region["s"]
+ Ealigned = aligned_region["e"]
+ Waligned = aligned_region["w"]
+ grass.message( "Aligned region:" )
+ grass.message( [aligned_region[key] for key in "nsew"] )
# Extend region
- grass.message( "Extend region ..." )
- grass.message( "n, s, e, w" )
- grass.message( [current_region[key] for key in "nsew"] )
- grass.message( "by" )
+ grass.message( "Extend region by" )
grass.message( regext )
grass.message( "in all directions" )
- grass.run_command('g.region', n = N+X,
- s = S-X,
- e = E+X,
- w = W-X)
+ grass.run_command('g.region', n = Naligned+X,
+ s = Saligned-X,
+ e = Ealigned+X,
+ w = Waligned-X)
grass.message( "Region extension done." )
+ extended_region = grass.region()
grass.message( "Extended region:" )
- grass.run_command('g.region', flags = 'p')
+ grass.message( [extended_region[key] for key in "nsew"] )
# Watershed calculation: accumulation, drainage direction, topographic index
