[GRASS-SVN] r62141 - grass/trunk/scripts/r.reclass.area
svn_grass at osgeo.org
Wed Oct 1 00:09:51 PDT 2014
Author: lucadelu
Date: 2014-10-01 00:09:50 -0700 (Wed, 01 Oct 2014)
New Revision: 62141
grass/trunk/scripts/r.reclass.area/r.reclass.area.html
grass/trunk/scripts/r.reclass.area/r.reclass.area.py
r.reclass.area: added new method using v.clean with tool=rmarea
Modified: grass/trunk/scripts/r.reclass.area/r.reclass.area.html
--- grass/trunk/scripts/r.reclass.area/r.reclass.area.html 2014-09-30 21:47:22 UTC (rev 62140)
+++ grass/trunk/scripts/r.reclass.area/r.reclass.area.html 2014-10-01 07:09:50 UTC (rev 62141)
@@ -6,18 +6,27 @@
If the <em>-c</em> flag is used, <em>r.reclass.area</em> will skip the creation
of a clumped raster and assume that the input raster is already clumped.
-<h2>EXAMPLE</h2>
+<h2>EXAMPLES</h2>
-In this example, the ZIP code map in the
-North Carolina sample dataset location is filtered for large areas:
+In this example, the ZIP code map in the North Carolina sample dataset location
+is filtered for large areas (removing smaller areas from the map):
<div class="code"><pre>
g.region rast=zipcodes -p
r.report zipcodes unit=h
-# extract only areas > 2000 ha:
+# extract only areas > 2000 ha, NULL otherwise:
r.reclass.area input=zipcodes output=zipcodes_larger2000ha greater=2000
</pre></div>
+is filtered for smaller areas which are substituted with the value of the respective
+adjacent area with largest shared boundary:
+<div class="code"><pre>
+# reclass removing area minor of 1000 ha
+r.reclass.area input=zipcodes output=zipcodes_rmarea1000 lesser=1000 method=rmarea
+</pre></div>
<h2>SEE ALSO</h2>
<em>
Modified: grass/trunk/scripts/r.reclass.area/r.reclass.area.py
--- grass/trunk/scripts/r.reclass.area/r.reclass.area.py 2014-09-30 21:47:22 UTC (rev 62140)
+++ grass/trunk/scripts/r.reclass.area/r.reclass.area.py 2014-10-01 07:09:50 UTC (rev 62141)
@@ -5,6 +5,7 @@
# MODULE: r.reclass.area
# AUTHOR(S): NRCS
# Converted to Python by Glynn Clements
+# Added rmarea method by Luca Delucchi
# PURPOSE: Reclasses a raster map greater or less than user specified area size (in hectares)
# COPYRIGHT: (C) 1999,2008 by the GRASS Development Team
@@ -49,6 +50,15 @@
#% guisection: Area
#%end
+#%option
+#% key: method
+#% type: string
+#% description: Method used for reclassification
+#% options: reclass,rmarea
+#% answer: reclass
+#% guisection: Area
+#%end
#%flag
#% key: c
#% description: Input map is clumped
@@ -67,13 +77,13 @@
TMPRAST = []
-def main():
- infile = options['input']
- lesser = options['lesser']
- greater = options['greater']
- outfile = options['output']
- clumped = flags['c']
- diagonal = flags['d']
+def reclass(inf, outf, lim, clump, diag, les):
+ infile = inf
+ outfile = outf
+ lesser = les
+ limit = lim
+ clumped = clump
+ diagonal = diag
s = grass.read_command("g.region", flags='p')
kv = grass.parse_key_val(s, sep=':')
@@ -82,15 +92,6 @@
grass.fatal(_("xy-locations are not supported"))
grass.fatal(_("Need projected data with grids in meters"))
- if not lesser and not greater:
- grass.fatal(_("You have to specify either lesser= or greater="))
- if lesser and greater:
- grass.fatal(_("lesser= and greater= are mutually exclusive"))
- if lesser:
- limit = float(lesser)
- if greater:
- limit = float(greater)
if not grass.find_file(infile)['name']:
grass.fatal(_("Raster map <%s> not found") % infile)
@@ -107,17 +108,19 @@
if grass.find_file(clumpfile)['name']:
grass.fatal(_("Temporary raster map <%s> exists") % clumpfile)
if diagonal:
- grass.message(_("Generating a clumped raster file including diagonal neighbors..."))
- grass.run_command('r.clump', flags='d', input=infile, output=clumpfile)
+ grass.message(_("Generating a clumped raster file including "
+ "diagonal neighbors..."))
+ grass.run_command('r.clump', flags='d', input=infile,
+ output=clumpfile)
else:
grass.message(_("Generating a clumped raster file ..."))
grass.run_command('r.clump', input=infile, output=clumpfile)
if lesser:
- grass.message(_("Generating a reclass map with area size less than " \
+ grass.message(_("Generating a reclass map with area size less than "
"or equal to %f hectares...") % limit)
else:
- grass.message(_("Generating a reclass map with area size greater " \
+ grass.message(_("Generating a reclass map with area size greater "
"than or equal to %f hectares...") % limit)
recfile = outfile + '.recl'
@@ -149,22 +152,88 @@
p2.wait()
if p2.returncode != 0:
if lesser:
- grass.fatal(_("No areas of size less than or equal to %f " \
+ grass.fatal(_("No areas of size less than or equal to %f "
"hectares found.") % limit)
else:
- grass.fatal(_("No areas of size greater than or equal to %f " \
+ grass.fatal(_("No areas of size greater than or equal to %f "
+ grass.mapcalc("$outfile = $recfile", outfile=outfile, recfile=recfile)
+def rmarea(infile, outfile, thresh, coef):
+ # transform user input from hectares to map units (kept this for future)
+ # thresh = thresh * 10000.0 / (float(coef)**2)
+ # grass.debug("Threshold: %d, coeff linear: %s, coef squared: %d" % (thresh, coef, (float(coef)**2)), 0)
+ # transform user input from hectares to meters because currently v.clean
+ # rmarea accept only meters as threshold
+ thresh = thresh * 10000.0
+ vectfile = "%s_vect_%s" % (infile.split('@')[0], outfile)
+ TMPRAST.append(vectfile)
+ grass.run_command('r.to.vect', input=infile, output=vectfile, type='area')
+ cleanfile = "%s_clean_%s" % (infile.split('@')[0], outfile)
+ TMPRAST.append(cleanfile)
+ grass.run_command('v.clean', input=vectfile, output=cleanfile,
+ tool='rmarea', threshold=thresh)
+ grass.run_command('v.to.rast', input=cleanfile, output=outfile,
+ use='attr', attrcolumn='value')
+def main():
+ infile = options['input']
+ lesser = options['lesser']
+ greater = options['greater']
+ outfile = options['output']
+ global METHOD
+ METHOD = options['method']
+ clumped = flags['c']
+ diagonal = flags['d']
+ islesser = False
+ in_proj = grass.parse_command('g.proj', flags='g')
+ # check non supported location
+ if in_proj['unit'].lower() == 'degree':
+ grass.fatal(_("Latitude-Longitude locations are not supported"))
+ if in_proj['name'].lower() == 'xy_location_unprojected':
+ grass.fatal(_("xy-locations are not supported"))
+ grass.fatal(_("Need projected data with grids in metric units"))
+ # check lesser and greater parameters
+ if not lesser and not greater:
+ grass.fatal(_("You have to specify one of lesser= or greater="))
+ if lesser and greater:
+ grass.fatal(_("lesser= and greater= are mutually exclusive"))
+ if lesser:
+ limit = float(lesser)
+ islesser = True
+ if greater and METHOD == 'rmarea':
+ grass.fatal(_("You have to specify lesser= with method='rmarea'"))
+ elif greater:
+ limit = float(greater)
+ if not grass.find_file(infile)['name']:
+ grass.fatal(_("Raster map <%s> not found") % infile)
+ if METHOD == 'reclass':
+ reclass(infile, outfile, limit, clumped, diagonal, islesser)
+ elif METHOD == 'rmarea':
+ rmarea(infile, outfile, limit, in_proj['meters'])
grass.message(_("Generating output raster map <%s>...") % outfile)
- grass.mapcalc("$outfile = $recfile", outfile=outfile, recfile=recfile)
def cleanup():
"""!Delete temporary maps"""
TMPRAST.reverse() # reclassed map first
- for rast in TMPRAST:
- grass.run_command("g.remove", flags='f', type='rast', pattern=rast, quiet=True)
+ for mapp in TMPRAST:
+ if METHOD == 'rmarea':
+ grass.run_command("g.remove", flags='f', type='vect', pattern=mapp,
+ quiet=True)
+ else:
+ grass.run_command("g.remove", flags='f', type='rast', pattern=mapp,
+ quiet=True)
if __name__ == "__main__":
options, flags = grass.parser()
