[GRASS-SVN] r62177 - in grass/branches/releasebranch_7_0: . gui/wxpython/wxplot include lib/gis raster/r.profile
svn_grass at osgeo.org
Sat Oct 4 12:14:57 PDT 2014
Author: annakrat
Date: 2014-10-04 12:14:57 -0700 (Sat, 04 Oct 2014)
New Revision: 62177
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/gui/wxpython/wxplot/profile.py
grass/branches/releasebranch_7_0/include/gis.h
grass/branches/releasebranch_7_0/lib/gis/proj2.c
grass/branches/releasebranch_7_0/lib/gis/proj3.c
grass/branches/releasebranch_7_0/lib/gis/units.c
grass/branches/releasebranch_7_0/raster/r.profile/local_proto.h
grass/branches/releasebranch_7_0/raster/r.profile/main.c
grass/branches/releasebranch_7_0/raster/r.profile/r.profile.html
r.profile: feet support (merge from trunk, r62035,r62046,r62060)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:60289,60696,61269,61380,61420,61422,61480,61500,61764,61793,61808,61829,61831,61840,61851-61854,61858,61888,61891,61905,61907,61913-61914,61916,61918,61920-61921,61938,61967-61968,61975,61980,61986,61993,62005,62095,62099,62114,62122,62128,62131,62148,62170,62174
+ /grass/trunk:60289,60696,61269,61380,61420,61422,61480,61500,61764,61793,61808,61829,61831,61840,61851-61854,61858,61888,61891,61905,61907,61913-61914,61916,61918,61920-61921,61938,61967-61968,61975,61980,61986,61993,62005,62035,62046,62060,62095,62099,62114,62122,62128,62131,62148,62170,62174
Modified: grass/branches/releasebranch_7_0/gui/wxpython/wxplot/profile.py
--- grass/branches/releasebranch_7_0/gui/wxpython/wxplot/profile.py 2014-10-04 18:48:38 UTC (rev 62176)
+++ grass/branches/releasebranch_7_0/gui/wxpython/wxplot/profile.py 2014-10-04 19:14:57 UTC (rev 62177)
@@ -44,21 +44,6 @@
from core.gcmd import RunCommand, GWarning, GError, GMessage
-def get_unit_conversion():
- """Get conversion factor to convert output from r.profile to current units.
- Module r.profile always outputs distance in meters.
- .. todo:: create a wrapper for g.proj in grass.core
- proj = RunCommand(prog='g.proj', read=True, flags='g').strip()
- if not proj:
- # TODO put some warning here
- return 1.
- proj = grass.parse_key_val(proj, sep='=')
- return 1 / float(proj.get('meters', 1))
class ProfileFrame(BasePlotFrame):
"""!Mainframe for displaying profile of one or more raster maps. Uses wx.lib.plot.
@@ -74,8 +59,8 @@
if sys.platform != 'darwin':
self.SetToolBar(self.toolbar)
self.SetTitle(_("GRASS Profile Analysis Tool"))
- self._units = units
- self._conversion = get_unit_conversion()
+ # in case of degrees, we want to use meters
+ self._units = units if 'degree' not in units else 'meters'
# Init variables
@@ -275,8 +260,7 @@
if dist == None or dist == '' or dist == 'nan' or \
elev == None or elev == '' or elev == 'nan':
continue
- # remove conversion if one day r.profile starts to output distance in projection units!
- dist = self._conversion * float(dist)
+ dist = float(dist)
elev = float(elev)
datalist.append((dist,elev))
Modified: grass/branches/releasebranch_7_0/include/gis.h
--- grass/branches/releasebranch_7_0/include/gis.h 2014-10-04 18:48:38 UTC (rev 62176)
+++ grass/branches/releasebranch_7_0/include/gis.h 2014-10-04 19:14:57 UTC (rev 62177)
@@ -74,6 +74,7 @@
#define U_FEET 6
#define U_RADIANS 7
#define U_DEGREES 8
+#define U_USFEET 9
/* Temporal units from the datetime library */
#define U_YEARS DATETIME_YEAR
#define U_MONTHS DATETIME_MONTH
Modified: grass/branches/releasebranch_7_0/lib/gis/proj2.c
--- grass/branches/releasebranch_7_0/lib/gis/proj2.c 2014-10-04 18:48:38 UTC (rev 62176)
+++ grass/branches/releasebranch_7_0/lib/gis/proj2.c 2014-10-04 19:14:57 UTC (rev 62177)
@@ -23,6 +23,7 @@
- U_UNKNOWN (XY)
- U_METERS (UTM)
- U_FEET (SP)
+ - U_USFEET (a few SP)
- U_DEGREES (LL)
\return units code (see gis.h)
@@ -36,7 +37,7 @@
case PROJECTION_UTM:
return U_METERS;
case PROJECTION_SP:
- return U_FEET;
+ return U_FEET; /* TODO: what if U_USFEET as in CA and NC ? */
case PROJECTION_LL:
return U_DEGREES;
default:
Modified: grass/branches/releasebranch_7_0/lib/gis/proj3.c
--- grass/branches/releasebranch_7_0/lib/gis/proj3.c 2014-10-04 18:48:38 UTC (rev 62176)
+++ grass/branches/releasebranch_7_0/lib/gis/proj3.c 2014-10-04 19:14:57 UTC (rev 62177)
@@ -73,6 +73,8 @@
units = U_MILES;
else if (strcasecmp(name, "foot") == 0 || strcasecmp(name, "feet") == 0)
units = U_FEET;
+ else if (strcasecmp(name, "foot_us") == 0 || strcasecmp(name, "foot_uss") == 0)
+ units = U_USFEET;
else if (strcasecmp(name, "degree") == 0 || strcasecmp(name, "degrees") == 0)
units = U_DEGREES;
else
@@ -127,6 +129,7 @@
double factor;
int n;
+ /* TODO: sync with definitions in ../proj/units.table */
static const struct
char *unit;
@@ -134,7 +137,8 @@
} table[] = {
{"unit", 1.0},
{"meter", 1.0},
- {"foot", .3048},
+ {"foot", .3048},
+ {"foot_us", 1200/3937.},
{"inch", .0254},
{NULL, 0.0}
Modified: grass/branches/releasebranch_7_0/lib/gis/units.c
--- grass/branches/releasebranch_7_0/lib/gis/units.c 2014-10-04 18:48:38 UTC (rev 62176)
+++ grass/branches/releasebranch_7_0/lib/gis/units.c 2014-10-04 19:14:57 UTC (rev 62177)
@@ -26,6 +26,7 @@
- U_KILOMETERS
- U_MILES
- U_FEET
+ - U_USFEET
Returns a factor which converts meters to units (by multiplication).
@@ -52,6 +53,10 @@
return 3.28083989501312; /* 1 / (0.0254 * 12) */
break;
+ case U_USFEET:
+ return 3.28083333333333; /* 1 / (1200/3937) */
+ break;
default:
return 1.0;
break;
@@ -70,6 +75,7 @@
- U_HECTARES
- U_MILES
- U_FEET
+ - U_USFEET
Returns a factor which converts square meters to square units (by
multiplication).
@@ -102,9 +108,13 @@
break;
case U_FEET:
- return 10.7639104167097; /* 1 / (0.0254 * 12)^2 */
+ return 10.7639104167097; /* 1 / (0.0254 * 12)^2 */
break;
+ case U_USFEET:
+ return 10.7638673611111; /* 1 / (1200/3937)^2 */
+ break;
default:
return 1.0;
break;
@@ -135,6 +145,8 @@
return 1;
case U_FEET:
return 1;
+ case U_USFEET:
+ return 1;
case U_RADIANS:
return 1;
case U_DEGREES:
@@ -179,6 +191,7 @@
- U_HECTARES
- U_MILES
- U_FEET
+ - U_USFEET
\param units units code
\param plural plural form if true
@@ -241,6 +254,13 @@
return plural ? _("feet") : _("foot");
break;
+ case U_USFEET:
+ if (square)
+ return plural ? _("square US feet") : _("square US foot");
+ else
+ return plural ? _("US feet") : _("US foot");
+ break;
case U_DEGREES:
if (square)
return plural ? _("square degrees") : _("square degree");
@@ -286,6 +306,7 @@
- U_HECTARES
- U_MILES
- U_FEET
+ - U_USFEET
- U_YEARS
@@ -319,11 +340,14 @@
else if (strcasecmp(units_name, "foot") == 0 ||
strcasecmp(units_name, "feet") == 0)
return U_FEET;
+ else if (strcasecmp(units_name, "foot_us") == 0 ||
+ strcasecmp(units_name, "foot_uss") == 0)
+ return U_USFEET;
else if (strcasecmp(units_name, "degree") == 0 ||
strcasecmp(units_name, "degrees") == 0)
return U_DEGREES;
else if (strcasecmp(units_name, "year") == 0 ||
- strcasecmp(units_name, "years") == 0)
+ strcasecmp(units_name, "years") == 0)
return U_YEARS;
else if (strcasecmp(units_name, "month") == 0 ||
strcasecmp(units_name, "months") == 0)
Modified: grass/branches/releasebranch_7_0/raster/r.profile/local_proto.h
--- grass/branches/releasebranch_7_0/raster/r.profile/local_proto.h 2014-10-04 18:48:38 UTC (rev 62176)
+++ grass/branches/releasebranch_7_0/raster/r.profile/local_proto.h 2014-10-04 19:14:57 UTC (rev 62177)
@@ -6,8 +6,8 @@
#include <grass/raster.h>
/* main.c */
-int do_profile(double, double, double, double, char *, int, double, int, int,
- FILE *, char *);
+int do_profile(double, double, double, double, int, double, int, int,
+ FILE *, char *, const char *, double);
/* read_rast.c */
int read_rast(double, double, double, int, int, RASTER_MAP_TYPE, FILE *,
Modified: grass/branches/releasebranch_7_0/raster/r.profile/main.c
--- grass/branches/releasebranch_7_0/raster/r.profile/main.c 2014-10-04 18:48:38 UTC (rev 62176)
+++ grass/branches/releasebranch_7_0/raster/r.profile/main.c 2014-10-04 19:14:57 UTC (rev 62177)
@@ -23,6 +23,9 @@
int main(int argc, char *argv[])
char *name, *outfile;
+ const char *unit;
+ int unit_id;
+ double factor;
int fd, projection;
FILE *fp, *coor_fp;
double res;
@@ -37,8 +40,8 @@
struct Cell_head window;
struct
- struct Option *opt1, *profile, *res, *output, *null_str, *coord_file;
- struct Flag *g, *c;
+ struct Option *opt1, *profile, *res, *output, *null_str, *coord_file, *units;
+ struct Flag *g, *c, *m;
parm;
struct GModule *module;
@@ -98,11 +101,15 @@
parm.c->description =
_("Output RRR:GGG:BBB color values for each profile point");
+ parm.units = G_define_standard_option(G_OPT_M_UNITS);
+ parm.units->options = "meters,kilometers,feet,miles";
+ parm.units->label = parm.units->description;
+ parm.units->description = _("If units are not specified, current location units are used. "
+ "Meters are used by default in geographic (latlon) locations.");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
clr = 0;
if (parm.c->answer)
clr = 1; /* color output */
@@ -116,18 +123,36 @@
G_get_window(&window);
projection = G_projection();
+ /* get conversion factor and units name */
+ if (parm.units->answer) {
+ unit_id = G_units(parm.units->answer);
+ factor = 1. / G_meters_to_units_factor(unit_id);
+ unit = G_get_units_name(unit_id, 1, 0);
+ /* keep meters in case of latlon */
+ else if (projection == PROJECTION_LL) {
+ factor = 1;
+ unit = "meters";
+ else {
+ /* get conversion factor to current units */
+ unit = G_database_unit_name(1);
+ factor = G_database_units_to_meters_factor();
if (parm.res->answer) {
res = atof(parm.res->answer);
/* Catch bad resolution ? */
if (res <= 0)
- G_fatal_error(_("Illegal resolution! [%g]"), res);
+ G_fatal_error(_("Illegal resolution %g [%s]"), res / factor, unit);
else {
/* Do average of EW and NS res */
res = (window.ew_res + window.ns_res) / 2;
- G_message(_("Using resolution [%g]"), res);
+ G_message(_("Using resolution: %g [%s]"), res / factor, unit);
G_begin_distance_calculations();
@@ -158,14 +183,14 @@
/* Done with file */
/* Show message giving output format */
- G_message(_("Output Format:"));
+ G_message(_("Output columns:"));
if (coords == 1)
sprintf(formatbuff,
- _("[Easting] [Northing] [Along Track Dist.(m)] [Elevation]"));
+ _("Easting, Northing, Along track dist. [%s], Elevation"), unit);
else
- sprintf(formatbuff, _("[Along Track Dist.(m)] [Elevation]"));
+ sprintf(formatbuff, _("Along track dist. [%s], Elevation"), unit);
if (clr)
- strcat(formatbuff, _(" [RGB Color]"));
+ strcat(formatbuff, _(" RGB color"));
G_message(formatbuff);
/* Get Profile Start Coords */
@@ -186,8 +211,8 @@
G_fatal_error(_("Invalid coordinates %s %s"), ebuf, nbuf);
if (havefirst)
- do_profile(e1, e2, n1, n2, name, coords, res, fd, data_type,
- fp, null_string);
+ do_profile(e1, e2, n1, n2, coords, res, fd, data_type,
+ fp, null_string, unit, factor);
e1 = e2;
n1 = n2;
havefirst = TRUE;
@@ -211,8 +236,8 @@
n2 = n1;
/* Get profile info */
- do_profile(e1, e2, n1, n2, name, coords, res, fd, data_type, fp,
- null_string);
+ do_profile(e1, e2, n1, n2, coords, res, fd, data_type, fp,
+ null_string, unit, factor);
else {
for (i = 0; i <= k - 2; i += 2) {
@@ -225,8 +250,8 @@
G_projection());
- fp, null_string);
@@ -243,9 +268,9 @@
/* Calculate the Profile Now */
/* Establish parameters */
-int do_profile(double e1, double e2, double n1, double n2, char *name,
+int do_profile(double e1, double e2, double n1, double n2,
int coords, double res, int fd, int data_type, FILE * fp,
- char *null_string)
+ char *null_string, const char *unit, double factor)
float rows, cols, LEN;
double Y, X, AZI;
@@ -254,7 +279,7 @@
rows = n1 - n2;
LEN = G_distance(e1, n1, e2, n2);
- G_message(_("Approx. transect length [%f] m"), LEN);
+ G_message(_("Approx. transect length: %f [%s]"), LEN / factor, unit);
if (!G_point_in_region(e2, n2))
G_warning(_("Endpoint coordinates are outside of current region settings"));
@@ -264,7 +289,7 @@
/* Special case for no movement */
e = e1;
n = n1;
- read_rast(e, n, dist, fd, coords, data_type, fp, null_string);
+ read_rast(e, n, dist / factor, fd, coords, data_type, fp, null_string);
if (rows >= 0 && cols < 0) {
@@ -280,7 +305,7 @@
dist -= G_distance(e, n, e1, n1);
for (e = e1, n = n1; e < e2 || n > n2; e += X, n -= Y) {
/* d+=res; */
dist += G_distance(e - X, n + Y, e, n);
@@ -302,7 +327,7 @@
for (e = e1, n = n1; e < e2 || n < n2; e += X, n += Y) {
/* d+=res; */
dist += G_distance(e - X, n - Y, e, n);
@@ -321,7 +346,7 @@
for (e = e1, n = n1; e > e2 || n > n2; e -= X, n -= Y) {
/* d+=res; */
dist += G_distance(e + X, n + Y, e, n);
@@ -340,7 +365,7 @@
for (e = e1, n = n1; e > e2 || n < n2; e -= X, n += Y) {
/* d+=res; */
dist += G_distance(e + X, n - Y, e, n);
Modified: grass/branches/releasebranch_7_0/raster/r.profile/r.profile.html
--- grass/branches/releasebranch_7_0/raster/r.profile/r.profile.html 2014-10-04 18:48:38 UTC (rev 62176)
+++ grass/branches/releasebranch_7_0/raster/r.profile/r.profile.html 2014-10-04 19:14:57 UTC (rev 62177)
@@ -2,8 +2,8 @@
This program outputs two or four column (with <b>-g</b>) data to stdout or
an ASCII file. The default two column output consists of cumulative profile
-length (in meters) and raster value. The optional four column output consists
-of easting, northing, cumlative profile length (m), and raster value. Profile
+length and raster value. The optional four column output consists
+of easting, northing, cumulative profile length, and raster value. Profile
end or "turning" points can be set manually with the <b>coordinates</b>
argument. The profile resolution, or distance between profile
points, is obtained from the current region resolution, or can be manually
@@ -45,6 +45,9 @@
The optional RGB output provides the associated GRASS colour value for
each profile point.
+<p>Option <b>units</b> enables to set units of the profile length output.
+If the units are not specified, current location units will be used.
+In case of geographic locations (latitude/longitude), meters are used as default unit.
<h2>EXAMPLES</h2>
