[GRASS-SVN] r62185 - grass/trunk/raster/r.univar
svn_grass at osgeo.org
Sat Oct 4 20:12:22 PDT 2014
Author: wenzeslaus
Date: 2014-10-04 20:12:22 -0700 (Sat, 04 Oct 2014)
New Revision: 62185
grass/trunk/raster/r.univar/r.univar.html
grass/trunk/raster/r.univar/r3.univar.html
grass/trunk/raster/r.univar/r3.univar_main.c
r.univar and r3.univar: mention sum in manual, use 3D raster term, add trivial example for r3.univar
Modified: grass/trunk/raster/r.univar/r.univar.html
--- grass/trunk/raster/r.univar/r.univar.html 2014-10-04 21:45:54 UTC (rev 62184)
+++ grass/trunk/raster/r.univar/r.univar.html 2014-10-05 03:12:22 UTC (rev 62185)
@@ -2,8 +2,8 @@
<em>r.univar</em> calculates the univariate statistics of one or several raster
map(s). This includes the number of cells counted, minimum and maximum cell
-values, range, arithmetic mean, population variance, standard deviation, and
-coefficient of variation. Statistics are calculated separately for every
+values, range, arithmetic mean, population variance, standard deviation,
+coefficient of variation, and sum. Statistics are calculated separately for every
category/zone found in the <b>zones</b> input map if given.
If the <b>-e</b> extended statistics flag is given the 1st quartile, median,
3rd quartile, and given <b>percentile</b> are calculated.
Modified: grass/trunk/raster/r.univar/r3.univar.html
--- grass/trunk/raster/r.univar/r3.univar.html 2014-10-04 21:45:54 UTC (rev 62184)
+++ grass/trunk/raster/r.univar/r3.univar.html 2014-10-05 03:12:22 UTC (rev 62185)
@@ -1,9 +1,9 @@
<h2>DESCRIPTION</h2>
-<em>r3.univar</em> calculates the univariate statistics for raster3d maps.
+<em>r3.univar</em> calculates the univariate statistics for a 3D raster map.
This includes the number of cells counted, minimum and maximum cell values,
-range, arithmetic mean, population variance, standard deviation, and
+range, arithmetic mean, population variance, standard deviation,
@@ -31,6 +31,19 @@
calculating percentiles with large maps.
+<h2>EXAMPLE</h2>
+Computing univariate statistics of a 3D raster with randomly generated values:
+<div class="code"><pre>
+# generate random map
+r3.mapcalc "random_0_1 = rand(0., 1)" -s
+# compute univariate statistics
+r3.univar map=random_0_1
+</pre></div>
<h2>TODO</h2>
<i>mode, skewness, kurtosis</i>
Modified: grass/trunk/raster/r.univar/r3.univar_main.c
--- grass/trunk/raster/r.univar/r3.univar_main.c 2014-10-04 21:45:54 UTC (rev 62184)
+++ grass/trunk/raster/r.univar/r3.univar_main.c 2014-10-05 03:12:22 UTC (rev 62185)
@@ -100,7 +100,7 @@
G_add_keyword(_("univariate statistics"));
module->description =
- _("Calculates univariate statistics from the non-null 3d cells of a raster3d map.");
+ _("Calculates univariate statistics from the non-null cells of a 3D raster map.");
/* Define the different options */
set_params();
