[GRASS-SVN] r62194 - grass/trunk/lib/python/pygrass/raster
svn_grass at osgeo.org
Mon Oct 6 05:26:37 PDT 2014
Author: zarch
Date: 2014-10-06 05:26:37 -0700 (Mon, 06 Oct 2014)
New Revision: 62194
grass/trunk/lib/python/pygrass/raster/abstract.py
pygrass: Fix raster range for for FCELL and DCELL rasters
Modified: grass/trunk/lib/python/pygrass/raster/abstract.py
--- grass/trunk/lib/python/pygrass/raster/abstract.py 2014-10-06 12:12:34 UTC (rev 62193)
+++ grass/trunk/lib/python/pygrass/raster/abstract.py 2014-10-06 12:26:37 UTC (rev 62194)
@@ -27,7 +27,7 @@
# import raster classes
-from grass.pygrass.raster.raster_type import TYPE as RTYPE
+from grass.pygrass.raster.raster_type import TYPE as RTYPE, RTYPE_STR
from grass.pygrass.raster.category import Category
from grass.pygrass.raster.history import History
@@ -65,10 +65,15 @@
self.name = name
self.mapset = mapset
self.c_region = ctypes.pointer(libgis.Cell_head())
- self.c_range = ctypes.pointer(libraster.Range())
+ self.c_range = None
def _get_range(self):
- libraster.Rast_read_range(self.name, self.mapset, self.c_range)
+ if self.mtype == 'CELL':
+ self.c_range = ctypes.pointer(libraster.Range())
+ libraster.Rast_read_range(self.name, self.mapset, self.c_range)
+ else:
+ self.c_range = ctypes.pointer(libraster.FPRange())
+ libraster.Rast_read_fp_range(self.name, self.mapset, self.c_range)
def _get_raster_region(self):
libraster.Rast_get_cellhd(self.name, self.mapset, self.c_region)
@@ -131,16 +136,42 @@
@property
def min(self):
+ if self.c_range is None:
+ return None
return self.c_range.contents.min
@property
def max(self):
+ return None
return self.c_range.contents.max
@property
def range(self):
+ return None, None
return self.c_range.contents.min, self.c_range.contents.max
+ @property
+ def mtype(self):
+ return RTYPE_STR[libraster.Rast_map_type(self.name, self.mapset)]
+ def _get_units(self):
+ return libraster.Rast_read_units(self.name, self.mapset)
+ def _set_units(self, units):
+ libraster.Rast_write_units(self.name, units)
+ units = property(_get_units, _set_units)
+ def _get_vdatum(self):
+ return libraster.Rast_read_vdatum(self.name, self.mapset)
+ def _set_vdatum(self, vdatum):
+ libraster.Rast_write_vdatum(self.name, vdatum)
+ vdatum = property(_get_vdatum, _set_vdatum)
def __repr__(self):
return INFO.format(name=self.name, mapset=self.mapset,
rows=self.rows, cols=self.cols,
